Carpet resurrection? | FerrariChat
Discussion in '348/355' started by vjlax18, Dec 22, 2015.
  1. vjlax18
    vjlax18 Formula Junior
    686
    Nottingham, MD
    #1 vjlax18, Dec 22, 2015
    Has anyone had any luck with re-dying their 348 carpet? My 90TS beige carpet is very faded and it's almost yellow in color. I looked around on the old Interwebz to see what people are doing. I already knew spray dye was a bad idea, but then I found Rit mentioned over and over. I've used it before in my youth with 80's tie-dye tee-shirts as well as dying lacrosse stick heads for years even into college.
    I gave Rit a try on a piece of cotton and it looked close and so I then gave it a try on a random piece of carpet that was sitting behind the armrest. It had a clear fade line down it, but after sitting in a small pickle jar of water and dye mix for a few hours, it came out pretty close to the original color. I'm thinking about doing the rest of the carpet in the next few weeks.
    Any constructive criticism?
  2. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I don't know about the carpet dye but I bought the last complete brand new OEM black coupe carpet set in the USA 2 years ago.....thankful I did :)
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,004
    Indio Ca/ Alberta
    Grant
    That looks very good to me but my 355 carpet looks more like your faded stuff and its not faded. Maybe mine is just a diff color.
  4. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,749
    Boston, MA
    John E. Kenney
    That's a good match. It's trashed anyway faded right? Go for it but back off the time a little. It looks a little darker than the good spots.
  5. vjlax18
    686
    Nottingham, MD
    The shade is done by adding more or less water, so I'll need to get the percentage down before the rest of the carpet. I'm going to have a get a big tub to soak it all in, so I'll test with fabric before attempting the carpet. I'll have to make enough of it so that I can soak each piece in the same bath.
    john a barnes likes this.
  6. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Spray bottle?
  7. vjlax18
    686
    Nottingham, MD
    #7 vjlax18, Dec 26, 2015
    I tried to use a spray bottle and it didn't work, so it's the soak method.
    I'm slowly mixing the dye and water together in a big tub to get it close to the factory color.
    I'm not sure what the deal is with the passenger side carpet, but it looks like something or someone died in the car...
  8. Roger348
    Roger348 Karting
    Feb 10, 2013
    104
    Reno, Nevada
    Roger Cody
    Are you opposed to new carpet? If not you can purchase complete carpet kit for your car from World Carpet & Interior in So. California. I purchased a set and it looks great and gives it that new car smell and appearance. FYI if you remove the Mad Mouse Seatbelt system and install the Three point seatbelts then you are going to want the carpet kit, otherwise the carpet comes up short at the area where the old seatbelts where at.
    Just a thought.
    Roger
  9. vjlax18
    686
    Nottingham, MD
    I'm not opposed to replacing the carpet at all. And it's really only 13 pieces of flatish carpet too.
    However, if $5 worth of dye brings the color back close to original, it's worth it to me to try.
  10. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    looks like water damage....
  11. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    no harm trying
  12. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,316
    Palos Verdes
    Vince V
    Mine were tan and the stock set was pretty stained. Got a whole new interior carpet for about a grand installed.
  13. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    did they mold it or glue it to the old carpet to get the contour?
  14. vjlax18
    686
    Nottingham, MD
    #14 vjlax18, Jan 1, 2016
    Well, for $5 it was worth it. The carpet isn't perfect as the color isn't uniform all throughout, but it's not yellow anymore.
    I'll probably end up replacing the carpet next year when I pull the mouse belts out completely. For my car, the carpet is a bunch of individual flat pieces cut and glued down.
  15. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    #15 cf355, Jan 1, 2016
    yeah the color is all over the place.....time for new carpets
  16. vjlax18
    686
    Nottingham, MD
    It's actually a lot better than it was, but yeah, I'll replace them in the future.
  17. vjlax18
    686
    Nottingham, MD
    #17 vjlax18, Jan 9, 2016
  18. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    it is an improvement but I wonder if you could dye them a second time to try and get the color more consistent (?)
  19. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    490
    Victoria, B.C, Can.
    John Glen Wesanko
    Why not just source some nice quality auto grade carpeting and get out the scissors ?
  20. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    On the 355 carpets there are plenty of corners that are molded.....as such I replaced my carpets with OEM.
    But on the 348.....looking at the posted pics .....you are right.....just cut and fit.
  21. vjlax18
    686
    Nottingham, MD
    For $5 it was worth dying the carpet. It looks a lot better than it did.
    That being said, I will be replacing the carpet in the future. I plan on removing the mouse belts, and to do so, th e carpet needs to be replaced. I'll remove the mouse belts after I get all of the pieces together for a conversion to the 1989 style shoulder location.
  22. Gialllo uno
    Gialllo uno Formula Junior
    Jul 5, 2014
    344
    Reisterstown, Maryland
    Mark
    I am in Finksburg and have a 355, and would love to see your car one day. I think it is in May that Radcliffe motor cars in Reisterstown Md. has an all Italian car show, really cool and the owner Richard is really a great guy.
  23. vjlax18
    686
    Nottingham, MD
    I planned to go to his gathering/show last year, but I had the motor out at the time. :) I'll be there this year.
