Carbon Ceramic Brakes | FerrariChat
Discussion in '360/430' started by ferraritime, Aug 6, 2008.
  1. ferraritime
    ferraritime Karting
    Aug 22, 2007
    246
    Washington DC Area
    Jerry H.
    I need some information RE the carbon ceramic brakes. . . Particularly, what is the pad life given typical street use? Any other issues with these on the street or are they a complete waste of $$ unless you plan to take the car to the track?
    Thanks.
  2. Fiorano1
    Fiorano1 Formula Junior
    Dec 7, 2004
    741
    Coral Springs, FL
    Haywood Jabloemi
    They are great for not producing any brake dust on the rims...:D
    Well worth the money even for everyday driving.
  3. RotKopf
    RotKopf Karting
    Jul 27, 2004
    208
    That's any easy one: They are awesome. Whether on track or street, you'll want them.
    And once you've lived with them, you'll never want to be without again!
  4. marknkidz
    marknkidz Formula 3
    1,323
    so cal
    mark
    Exactly what i was thinking!! My calipers look like the day i bought the car...not a spec of dirt on my calipers...Forget the fact the brakes Work awesome...forget the fact the discs fill up an otherwise useless void in the wheel.... Its the lack of dust!!
  5. frefan
    frefan F1 Veteran
    Apr 21, 2004
    7,370
    serious waste for street use. but they look cool
  6. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,795
    I've heard that the rotors will last the life of the car.
    What does that actually mean? More than 100K miles?
    Xenon HID headlights are supposed to last 'the life of a car'. I had to replace mine at 8 years and 180K miles in my mercedes
    The CC pads are supposed to last 3 time that of the standard pads. Since I got new standard brakes on my 360 at 30K miles maybe that means the pads will last 90K miles.
  7. toshiba
    toshiba Formula Junior
    Jan 14, 2008
    725
    Santa
    here is ferrari's dirty trick
    replacement of the brake pads cost thousands. rotors, don't even ask!
    hmmmmm replace people whining about belts, then trick them with brake pads costs
    CC rotors are for racing, not the street. it's like having a parachute on the back of your car for the street. it's just not needed
  8. marknkidz
    marknkidz Formula 3
    1,323
    so cal
    mark
    Yea....neither is 500+ Horse power, but we all want it!!
  9. ferraritime
    ferraritime Karting
    Aug 22, 2007
    246
    Washington DC Area
    Jerry H.
    Thanks for the posts.
    Yes, the lack of brake dust is sure nice, but I'd really like to understand life expectancy for the pads and rotors given the high cost of replacement.
    Also, assuming I find a the F430 I'm looking for I plan to eventually track the car, but I've never heard any complaints from F-car owners with standard brakes at the track. . .so, again, not sure it's worth the extra $$.
  10. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    ++++ Get them!!!
    1) Little brake dust.
    2) Looks amazing.
    3) If untracked, will last for a VERY long time.
    4) Work fantastic.
    5) Did I mention they look amazing???
    BTW, they're now standard on all F-cars.
  11. PCH
    PCH F1 Rookie
    Apr 7, 2004
    3,007
    For the relatively small fee one would pay for a CCB equipped car in the pre-owned market it's a no brainer.
  12. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    #12 vm3, Aug 7, 2008
    CC brakes look very cool and stop a few percent better, but that is irrelevant on the street. They are mostly for avoiding brake fade on the track during repeated hard braking.
    I had a set replaced for $4,000 when the dealer said they cracked after one track day.
    The set of rotors is nearly $40,000. The dealer said they have to be replaced maybe every 3 pad changes.
    Porterfield makes low dust brake pads for steel brakes. They are available from Ricambi.
  13. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,152
    Wash DC area
    Robert
    Jerry,
    Just buy the F430, you know you want one!!!!!!!
    I have heard many a discussion on properly warming up the CS brakes on the track. There were 2 gentlemen with CS brakes at the last FOW track days that had worn their CS brakes out within 5k miles, one on a CS on the other a F430, I was surprised.
    I have the Porterfield R4S pads, little brake dust and little fade, seem to be holding up well.
    See you around.
    Robert
  14. mousecatcher
    mousecatcher Formula 3
    Dec 18, 2007
    2,116
    san mateo, ca
    actually that is readily accomplished with any standard (performance) iron setup. you just need good pads and good fluid. the CC brakes are really for unsprung weight reduction, which is irrelevant even for most track use. (of the 1% that track their F-car, only 1% are likely to be at the level where they can even feel the handling difference let alone take advantage of it. so this is a worthwhile option for maybe 10 people worldwide ...)
    there you go -- the real point on a street car or even street/track combo car is to put $$$ into ferrari's pocket.
    that said, they do look pretty damn cool and i would get them.
  15. ferraritime
    ferraritime Karting
    Aug 22, 2007
    246
    Washington DC Area
    Jerry H.
    Thanks for the additional posts!
    Robert, you are right! I'm looking around for a nice one. Glad to read about the low dust pads for the steel set-up. I take it you have no brake fade issues at the track?
    Are you going to the Redskins Rides Sunday?
  16. jsanocki
    jsanocki Formula Junior
    Aug 30, 2006
    785
    NJ
    In the used car market I don't think you will be paying significantly more for CCB, especially since they were standard equipment in most recent model years.
    I agree, its a chunk of change and I don't know if I'd bite the bullet if ordering a car new, but since that is no longer an option, try to find a car with CCB...you can probably pick up a higher mileage car with versus a low miles without so there won't be any "cost" associated with them-
  17. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    My 360's steel rotors were originally smooth, but became grooved after just a couple of track days. Some guys at the track said they replace steel rotors after several track days. My CS's rotors are still mirror smooth after several track days.
    I think most of the handling difference between the 360 and the CS is due to the tires.
  18. Ferrari 360 CS
    Ferrari 360 CS F1 Veteran
    Dec 4, 2004
    6,849
    Cape Town,SA
    Jacques
    Interesting, did you have a look at the cracked discs? Reason I ask is that there are some cars down here that get tracked regularly and none have suffered either of these problems...and our track is pretty heavy on the brakes.
  19. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    No I didn't, and I wonder if they were really cracked. The car was serviced by an authorized dealer so I trusted them on blind faith.
  20. Testacojones
    Testacojones F1 Veteran
    Nov 3, 2003
    5,198
    Florida
    Luix
    I hear quotes of over $25,000 for replacing pads and rotors. For me they are a waste of money since the car is never going pro racing.
  21. Matt Andrews
    Matt Andrews Formula Junior
    Dec 31, 2006
    515
    Newport Beach, CA
    I can't speak for ferraris. But many porsche club guys I run with actually remove the carbon brakes for track days and put on traditional steel ones. Performance may not be quite as good, but replacing them is a heck of a lot cheaper. Budget no option, go with the carbon ceramics. But unless you have the car set up properly, are using the right temp range pads, the right tires, proper shock dampening, alignment settings, etc, there are better things to spend your money on at the track.
  22. Ferrari_Michael
    Ferrari_Michael Formula Junior
    Nov 30, 2006
    614
    CCM is a must have for me, my first F430 was a coupe, it had steels, then I had a spider i tool the chance to spec CCM on, since then, 4-5 cars on ALL have carbon ceramic.
    Replacing the pads can be expensive, however you could buy, from a selection of original Ferrari supplied Brembo pads, F430 front Carbon Ceramic pads from my friend who replaces them for me, fitted, for £300... The fronts will almost always need replacing first, and they are the most expensive ones.
    Get friends who work in the dealer network as technicians guys!!!
    Regards
    Michael James
  23. J2J
    J2J Formula Junior
    Jan 11, 2008
    271
    Clean wheels, cool looks, and bragging rights to all your friends that DIDN'T get them should be enough! Seriously though...I asked the F folks about replacement and they said that unless you track the car on average most F cars keep original rotors for over 10 years.
    One question I have for you guys....can non carbon be converted to carbon with ease?
  24. CChung
    CChung Formula Junior
    Dec 10, 2003
    286
    Southern California
    I have an '08 F430 and was wondering if the brake pads for CCBs are the same ones used on the steel brake rotors or are they made out of a different material. Thanks for any replies.
  25. 360Grigiotitanio
    360Grigiotitanio Formula Junior
    May 17, 2004
    436
    Bay Area, California
    I think they might pay for themselves for a car that is out of waranty.
    My 360 was hardly ever tracked but went through a set of rotors by 10,000 miles which was under warranty. I think a set of rotors installed on 360 for example is ilke $10K, but I am not certain. An F430 is no doubt more.
    I was told that the CC rotors last 100,000 miles.
