Carb tuning question | FerrariChat
Discussion in '308/328' started by snowsports1, Oct 11, 2014.
  1. snowsports1
    snowsports1 Formula Junior
    Jan 31, 2013
    918
    Brian
    Hi I am trying to tune my webers. Can someone please explain what the small fuel outlets do at the top inside of the carbs. Are they overflows? When my carbs are cold fuel comes out of these when I blip the throttle. , when it's warm this stops and fuel pops out of the emulsion tubes. Generally I have popping and banging upto 3000 Revs then it is ok above this. Have tried adjusting the slow running needles but this doesn't stop this happening. Could it be float level not set properly?
  2. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
  3. snowsports1
    Jan 31, 2013
    918
    Brian
    Yes and it seems to be the same on all carbs. Adjusting The idle mixture screw doesn't seem help
  4. snowsports1
    Jan 31, 2013
    918
    Brian
    I have correctly adjusted the float level which was out but this hasn't removed pops and bangs
  5. Squirrelmonkey
    Squirrelmonkey Karting
    Dec 27, 2010
    126
    Manitoba ,Canada
    Tom Thieme
    I'm Thinking you have plugged holes or air leaks in there somewhere..usually the popping and spitiing is an indication of too lean a mixture..Bidmans tutorial is excellent and if you follow his procedure it is actually quite easy to get the carbs to work correctly..cleaning and changing gaskets and O-rings is the first step and unless you have done that there is no chance that you can properly tune the carbs..
  6. snowsports1
    Jan 31, 2013
    918
    Brian
    Should I be opening the idle mixture screws a bit, I started with two turns open
  7. Steve Magnusson
    26,504
    Unfortunately, the "nominal" number of turns open for the mixture screws varies on Weber DCNF due to differences in the shape/angle of the mixture screw ends and the thread pitch -- some are 2 turns and some are 4 turns. The usual strategy is to start rich, turn in to lean it out until the cylinder under adjustment starts to miss at warm idle, then turn back out a fixed rotation amount to re-richen (like 1/4~1/2 turn).
  8. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,593
    Toronto / SoCal
    Rob C.
    #8 Nuvolari, Oct 11, 2014
    Idle jets are too small. Please take the time to read the carb tuning posts in the blog at Dino 246?Home and a detailed explanation of why your jets are small are there
    I will add that the needle screws are for adjusting mixture at idle only. If you have a running problem at anything over idle the problem is with the jets. Lots of mechanics start turning screws to try and correct running issues and that is the litmus test to show that they have no clue of what they are doing or know how the carb operates.
  9. rkljr
    rkljr Formula Junior
    May 16, 2011
    723
    South of Boston, MA
    Richard
    Sounds like it is too lean (that is how they US cars are out of the box) and an air leak. Rejet your carbs and you will feel the difference in how the car runs. There is plenty of information on rejetting else where and I would offer my recommendation but it would result in yet another carb tuning thread/discussion.
    Please note, it is not just the jets but the air correctors, emulsion tubes, and jets.
    You may want to check that your sniffer tubes have no leaks and if there are no sniffer tubes that the ports are all well plugged. An easy way to test is to run the car in the dark, when it pops you may see the flame. That is how I found my problem, the PO had removed the sniffers and plugged all but one.
  10. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,252
    Black Forest Germany
    Martin N.
    If I have understood his first post correctly,there's no fuel coming out of the accelerator jets, when the engine is warm. This has absolutely nothing to do with jets or adjustment.
    Accelerator pump seems to work o.k., since fuel is coming when cold. But stops, when warm. Seems, that there's not enough fuel in the float chambers after running for a while. Since it's on all carbs I would suspect the fuel pump first. Then needle valves and the small filters on each inlet.
    Best Regards from Germany
    Martin
  11. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    I like Martin's thoughts there.
    Did run well recently?
    If the solution remains elusive, I'd think about rebuilding the carbs. And installing sealed shaft bearings. When the fuel supply is correct and the carbs are known clean and adjusted, you'll be driving happy!
  12. snowsports1
    Jan 31, 2013
    918
    Brian
    an update on progress.... I have checked and put new o ring seals on all the idle jets. All the idle jets were clean though and generally the carbs look very clean. I still have popping upto 3000 revs. At tick over the popping is minimal but as soon as you touch the throttle the popping is bad to a point where the car isn't drivable. With the idle mixture screws at 2 turns open I need to set the tick over quite high to keep the it running.
  13. snowsports1
    Jan 31, 2013
    918
    Brian
    Hi Rob I have read your blog and has been really useful for my 246 restoration, but I don't understand as your blog seems to contradict what you posted, your blog states "2. Idle Jets control the flow of fuel from idle to about 3000 rpm".
  14. snowsports1
    Jan 31, 2013
    918
    Brian
    I have checked my jets and I have 50 idle, 130 main and 220 emulsion tube. uk at 80m above sea level. I am using 97 Ron super unleaded. I am thinking about buying 55 idle jets to hopefully resolve this lean running below 3000 revs.
  15. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Waynesboro, Virginia
    Jeff Ward
    I think he is consistent. Idle jets control from idle to midrange (3000 or so) but the idle mixture screws don't affect the mixture significantly once off idle. If you look at a schematic of a Weber 40 DCNF it will make sense.
  16. snowsports1
    Jan 31, 2013
    918
    Brian
    yes I understand this now, the needle adjust the idle mixture but the idle jet controls fuel delivery upto 3000 revs roughly.
  17. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,593
    Toronto / SoCal
    Rob C.
    Main jets, air correctors, and emulsion tubes control the fuel flow past 3000rpm. Because your problem is below this speed the place to look first are the idle jets. As a general rule I have found 50 idle jets to be too small. I had a serious popping problem that was cured by going to 55 idle jets.
    Rifledriver likes this.
  18. BigTex
    79,321
    Houston, Texas
    Bubba
    Modern fuel blends have pretty much negated the "original selection" of the Factory.
    Read up on some current tunings and get the jets and emulsion tubes sized properly...
    Or, go find some leaded, no ethanol gas...:D :D :D
    It's the ethanol, that is doing heavy damage to any rubber parts of the fuel system.
  19. jessup
    jessup Formula Junior
    Apr 26, 2014
    403
    Santa Clara CA USA
    Jessup
    Sounds like you are lean on your idle jets. Also if you have the square tip idle mixture screws 4 turns out will "probably" be better. The lean backfire causes fuel to be pushed out of the bowls. This is why you will see fuel dribbling. I recommend getting a pin gauge to measure the jets. I had some jets that were bigger/ smaller than stamped.
    I rebuilt and synced my carbs with 55 low speed jets, 135 main 200 AC F36 emulsion. 48mm float. 3.5psi fuel pressure. Best lean idle + 1/4.
    60 jet was good, but a little rich. 55's are good but I can hear a little lean pop on light accel when cruising.
  20. Foxie
    Foxie Karting
    Oct 9, 2011
    65
    Wexford, Ireland
    Sean Murray
  21. miked
    miked Formula Junior
    Feb 7, 2001
    891
    Cincinnati, Ohio
    It's called a "fast idle device" in the owner's manual. In the 20+ years that I have owned my car I have found it to be useless. It may be that my thermo spring is not up to spec but it never seems to rotate to the desired amount or there is drag preventing it from doing so. BTW, I found early on that the choke is useless as well.
    Foxie likes this.
  22. Rifledriver
    36,745
    Most carburetor problems are in the distributors.
    Is your car otherwise in a perfect state of tune? If not or unknown do that first. There is a reason that when a tune up is performed in order
    Adjust valves
    Adjust cam timing
    Service distributors and time them.
    Make all other ignition components work perfectly.
    Then and only then do you touch the carbs.
    I will never bring in a car for carburetor work. It gets a complete tune up or nothing. I hate wasting time.
  23. Rifledriver
    36,745
    Hydrocarbons are so high with 50's there was no way to pass smog. It took 55-60.
  24. Steve Magnusson
    26,504
    There is additional information about it on pages O4 & O5 of the 308GT4 WSM, but most people disable it (as yours is shown with the adjustment screw fully backed out), and use the acc. pedal to squirt extra fuel and add some extra air to keep the RPMs up at cold start-up (though not to that kind of crazy 3100 RPM level ;)).
    Foxie likes this.
  25. Foxie
    Foxie Karting
    Oct 9, 2011
    65
    Wexford, Ireland
    Sean Murray
    Thanks for some great information !
    I have the car 11 years. It seems the fast idle never worked.
    I certainly couldn't live with a 3100 rpm idle !
