Carb Sync Tools | FerrariChat
Carb Sync Tools
Discussion in '308/328' started by sltillim, May 16, 2015.
  1. sltillim
    sltillim Formula 3
    1,649
    San Diego
    #1 sltillim, May 16, 2015
    Hi all,
    I need to get a carburetor synchronizer tool. There are two kinds I see. The single meter and one with the four dials. Is there a real advantage to getting the more complex tool? Any recommendations?
    I will also add this is my first time adjusting them myself. I plan on using the bird man tutorial. I have a misfire in my midrange under any significant acceleration.
    Thank you in advance!
  2. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    Get the single but get at least 3 of them. That way you have front back and left right covered. Makes it so easy. A fourth is cool too but you will find you rarely move carbs with three. It helps to have a color tune or gas analyzer for the idle screw. Doing it by ear/rpm is not an exact science. Get a good long flat screw driver and a 10mm (iirc) for the front linkage nut. You need to be able to do that one by feel as it's hard to see especially if you do it with the deck lid on. Deck lid off makes everything much easier.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    Three is overkill. One will do.
  4. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,547
    Scottsdale AZ
    Stu Boogie
    OK, use 1. Spend 45 mins under a hot engine lid moving them back and forth trying to get them just right. Or spend a couple of extra bucks, put on three and tune in 5 mins.
    Your choice:)
  5. yelcab
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    Spencer
    Come borrow mine.
  6. Rifledriver
    36,744
    Three is a waste of time and will not achieve better faster results than one. A false sense of a good job maybe but nothing else.
    If you had said eight you would have a point but not three.
  7. sltillim
    sltillim Formula 3
    1,649
    San Diego
    Thanks Brian! I'm gonna get 8.
  8. Rifledriver
    36,744
    Quite a few shops do just that.
    Just don't buy Uni-Syn's.
  9. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    I think the reading coming from the same tool on all carbs make it more accurate.
    It's like using different voltmeter for a voltage drop diagnostic.
    But this is just my way of thinking. :D
  10. Rifledriver
    36,744
    That depends on what tool you are using. And confirming consistency is about as simple as it gets.
  11. sltillim
    sltillim Formula 3
    1,649
    San Diego
    I don't know if I sounded satirical enough on my last posting but since the consensus is one is enough I will go with that. It looks like the model to get is the STE-SK.
  12. Rifledriver
    36,744
    I only use one.
    That's a good tool.
