Car won't lock | FerrariChat
Car won't lock
Discussion in '348/355' started by gobble, Nov 8, 2013.
  1. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Having an issue with a 355 where either by using the fob or switch inside to lock the car the car beeps 4 times and door immediately unlocks. Basically the car won't lock. Has anyone ever come across this issue?
  2. F355steve
    F355steve Formula 3
    Apr 9, 2008
    2,086
    Honolulu - Seattle - Okinawa
    Steve
    Sounds like one of your doors/hood is not fully closed.
  3. Turbo Ron
    Turbo Ron Formula Junior
    Nov 3, 2003
    262
    West Los Angeles, CA
    Ron Stavis
    I leave my hood partially open all the time in the garage with a trickle charger wire hanging out. I hit the key fob once and get 2 beeps. I hit it a second time the doors lock and I get a series of 4 beeps, and I believe it sets the alarm also. The alarm light in the center vent flashes. This is only on 99 355's
  4. fatbillybob
    Aug 10, 2002
    28,538
    socal
    Sometimes that will happen if the rods inside the door move out of adjustment. Then you hit the switch and it does not work or locks/unlocks or if locked it will unlock then lock before you can get out. All Ferraris have these wonderful mechanisms
  5. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    I had the same thing when the wiring at the connectors on the door jambs went on the fritz. It's a notorious area for problems, and if one of the locks isn't locking because of a bad wire connection, the system goes bonkers. Check your connectors for corrosion, and check where the wires connect to the plugs... they like to break off there. Check both the door fitting and the body side one.
  6. ff355b
    ff355b Karting
    Feb 26, 2010
    218
    Did Ferrari use solid copper wires rather than stranded copper wires? Why would wires become defective after years of service?
