Car wash soap stained paint | FerrariChat
Discussion in 'Detailing & Showroom' started by ncjetskier, Dec 23, 2016.
  1. ncjetskier
    ncjetskier Formula 3
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    I hand wash the 360, however I have a 2012 GMC Sierra that is metallic black. Nice truck, but I don't have the time to hand wash it all the time. I used a touchless car wash and the soap left iridescent stains on / in the clear coat. I will try to buff it out, as it will not come off by rubbing your finger back and forth over it. I will try to buff it out this weekend.
    Has this happened to anybody else?
    On a side note, we wash a lot of cars at the house (about 5 each weekend). I go through a lot of soap. Does anybody have any recommendations for "Bulk" soap purchases (at least five gallons). This soap does not need to be top shelf, as it is used mostly on work trucks and we normally apply with a foam cannon. Just looking for soap and not a "wash and wax" as the wash and wax normally does not do well in a foam cannon.
  2. SizzleChest
    SizzleChest Formula Junior
    Dec 15, 2014
    255
    Naples, FL
    Scott
    I have seen this happen. The soaps used on a lot of car washes is very caustic...it's harsh to say the least. You should be able to polish/compound the spots off. What happened is the soap actually etched into the clear.
    And here is a link to some bulk quality car shampoo:
    Car Wash Shampoo | Car Wash Supply | Car Washing Soap
    Hope this helps!
  3. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Thanks Scott. Yes, I plan on washing and buffing the truck this weekend. I figured it would buff out - still amazing that the soap is that strong.
  4. bigblock427
    bigblock427 Rookie
    Sep 26, 2015
    47
    Edmond, OK
    Brent
    Regarding the car shampoo/soap I agree. I have used Adams products for several years and find them to be excellent products. I get great results with their products and am very satisfied with them.
    Their car shampoo/soap is fairly concentrated and has quite a bit of lubricity to it.
    Regarding the damage left by the soap from the car wash. That may be very difficult to correct. I would try a small area of the car, and remove the old wax, followed by using a clay bar, followed by the least aggressive polish available. If the least aggressive polish does not remove the damage, I would try a more aggressive polish, and if that does not work possibly another aggressive polish. Numerous companies make different levels of polishing compounds so do a little bit of research and select a line of polishing compounds. You might try Griots or Autogeek on line.
    Good luck and let us know your results.
  5. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    It happened to my yellow TR once I was in a hurry to a car show and car was dirty after driving there for a fairly long distance I went in a touchless carwash too. I was furious when I saw that. After hand washing the car a few times it disapeared.
  6. Walt Gamble
    Walt Gamble Formula Junior
    May 22, 2014
    425
    Sorry but ..."you put your Ferrari through a car wash?"
    360 is the next 275GTB
  7. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    My exact experience last year. In a hurry and arrived at a show after a 3 hour drive. No place to wash so I went to a wash station and used the hand wash bay with there soap. No problems on the exterior paint but it did stain some engine bay parts. I just recently started to clean them up and I think all will be well after several hours work. Never again.
  8. Streetsurfer
    Streetsurfer Formula Junior
    Dec 16, 2015
    934
    near Chicago
    Ron
    I have a feeling it has more to do with the recycled water (full of petroleum and mineral contaminants) used at car washes, rather than the soap they use. Iridescent stains speaks to petroleum products, imo. I've used soaps similar to what I suspect many car washes use, for the grungier tasks (simple green for the green soaps, and sodium metasilicates such as in the pink or purple cleaners), and have never noticed the issue.
  9. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,062
    NYC. / E. Hampton
    Michael
    If you have a clear coat...it will polish out.
    Start with s scratch remover polish and ease into a fine grade polish.
    Todays clear coats are impervious to just about anything that comes along.
  10. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Ron, you are probably correct. I never thought about the problem being recycled water with petroleum residuals. Good point.
  11. Caeruleus11
    Caeruleus11 F1 World Champ
    11,419
    I think thats a good point about the recycled water.
    If this happened to my car, I would go right for my favorite "miracle" product: Klasse All In One. Its not the newest thing out there but it works and is generally harmless unless you use way too much, let it dry too long, and then wipe it off with too much pressure- basically you can scratch your clear coat. Anyway, its a very good cleaner wax, and it has the benefit of lasting- I will do a car and then drive through winter and water is still beading...
    https://www.amazon.com/Klasse-ALL-IN-ONE-Polish-10-oz/dp/B00CZD7QOS/ref=sr_1_2?s=automotive&ie=UTF8&qid=1482808914&sr=1-2&keywords=klasse+all+in+one
  12. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    In my case it was NOT recycled water. The last stage of soap or wax or whaterver it was in the process was multicolored and that is what stained the paint.
    Anyway these car wash are totally useless!
  13. Streetsurfer
    Dec 16, 2015
    934
    near Chicago
    Ron
    #13 Streetsurfer, Dec 27, 2016
    I believe you there, godabitibi. I had forgot about those multicolored products as foams I've seen. I first envisioned the rainbow sheen oils mixed with water gives. The soot from an oil consuming engine shows it when hit by water, for example. I could have misread the type of staining ncjetskier meant.
  14. Jsf721
    Jsf721 Karting
    May 15, 2015
    93
    They acid washed your car. I had a white M3 I put in the hand wash in the winter.
    They were to use nothing but wash soap. It was very dirty and salty, and some rocket scientist put it in for an acid wash. Got the car with streaks of gray all over the Alpine White Paint.
    A good paint cleaner and polishing took care of the issue.
  15. Einsteiger
    Einsteiger Karting
    Oct 9, 2014
    125
    Overland Park, KS US
    Kevin
    #15 Einsteiger, Dec 29, 2016
    I think for a bulk product that would be good for your other vehicles, check out Meguiars. Their basic wash product would be effective on the trucks but mild enough not to strip the paint. :) Also works pretty well in a foam gun.
    I know it comes in gallons, but if you need 5 gallons at a time this might be an alternative: Heads Up - Vehicle Wash and Wax In One - 5 Gallon Pail [expensive stuff, though]
  16. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
    Why, will it disintegrate?
  17. BigTex
    79,321
    Houston, Texas
    Bubba
    Not so.....
    The modern low VOC paints are water based....
    I had a white car brand new, heavily damaged when the gas cap seal failed and blew fuel all down the quarter panel on a two hour drive.
    They had to respray half of the two week old car!
    Anyway, that gives legs to the comment on some type of petro contamination in the water.
  18. Envious Eric
    Envious Eric Karting
    Sep 21, 2009
    238
    Orange County, CA
    Eric
    meguiars hyper wash in 5gal is readily available from online detailing.com
  19. phrogs
    phrogs F1 Veteran
    7,312
    Michigan
    The clearcoat isn't water based..
