Car design is harder than I had thought... help please | FerrariChat
Discussion in 'Creative Arts' started by Bounce, Mar 10, 2012.
  1. Bounce
    Bounce Formula 3
    Nov 30, 2009
    1,024
    Perth, Australia
    Patrick
    #1 Bounce, Mar 10, 2012
    Hey guys, just would like some opinions on how to fix this concept I have in my head.
    I use Google Sketchup as I'm able to create a workflow that is close to how I would build an object with my own hands which is why I stay away from dedicated 3D modelling programs.
    I basically "saw" a concept in my head and tried to recreate it, the idea was an open top track orientated Ferrari.
    I'm sure you'll see many different styling cues, perhaps a little too much 458 influence crossed with Lamborghini.
    I'd love to do this in clay though.
    So any ideas are welcome! (to be honest I have no idea how I even got this far...) thanks
  2. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,814
    Old Dominion
    #2 soucorp, Mar 10, 2012
  3. Jeff Kennedy
    Jeff Kennedy F1 Veteran
    Oct 16, 2007
    6,579
    Edwardsville, IL
    Jeff Kennedy
    The reason to work in something like Alias is so that you can develop complex surface cross sections and work the transitioning forms. You need to start thinking of how reflections move across surfaces.
    For clay you want to get it from Chavant.
    Jeff
  4. HotShoe
    HotShoe F1 Veteran
    7,524
    Lake Worth, FL
    Anthony Lauro
    You need to put down your mouse and pick up a pencil.
    Cars are designed by doing thousands of sketches and then narrowing it down to a theme. Once you have a grasp of your final form you can take it into alias or 3d software but it isn't necessary. Google sketchup is not a viable option for this. Concepts are never done off the bat with 3d modeling. You need to be able to sketch cars with your eyes closed until you should a jump to 3d. The reason is if you can't draw forms you'll never understand enough about them to model them in the tube.
    I would recommend sketching and then doing a front and side tape of the final design if you really want to do a clay. Then you can mock up your buck and start spreading the clay.
  5. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    18,014
    michigan
    john
    +1000 & 1 !!
  6. tritone
    tritone F1 Veteran
    6,882
    On the Rock
    James
    Patrick - Pretty cool so far....I'm shocked you got this far in skup!
    I use it a lot for architectural design, and I've never had much joy trying to model the subtle curves of an envelope body!
    My suggestion (if you don't think your hand sketches are great); print some of your skup's and sketch over the top of them; you can really begin to model the shapes without losing the overall form if you're happy with it....
    extruding stuff in skup is way more time-consuming (for me) than just a quick pencil over an underlay. The subtle curves and intersections of form are what makes a body design stand out...those will flow out of a pencil quicker & more freely.
    However you go, show us some more!
  7. Qvb
    Qvb F1 Rookie
    2,827
    Newport Beach Ca.
    John Dixon
    Getting your design on paper is definitely a good start, it can help solidify what you are thinking of quickly. That way when you start to build a 3D model, you know what you are trying to make as opposed to trying to visualize it as you build. Building models is very helpful in understanding where things are in space. Designers who only sketch can easily draw things that do not actually make sense in 3D. Building clay models is the best for understanding surfaces and how they relate and transition. Building computer models is much more difficult.
    Of course you want to build computer models, so you should. But I would recommend that you use different software (I don't know anything about Sketchup but I don't think it will do what you need it to, at least not very easily). Unfortunately there is no simple way to build complex 3D models. Complex models, and all realistic cars are complex, require complex tools to make complex surfaces and transitions, so it takes a commitment to learn the software if you really want to build car data. I would recommend getting the free trials of Rhino3D (www.rhino3d.com/) and Alias (http://usa.autodesk.com/alias/) and watching all the tutorials on their websites. Start simple to learn the tools. Then learn how to add complexity. Continue drawing sketches of your design so it becomes more thought out. Having shapes on paper that you understand will make building them much easier.
  8. wingfeather
    wingfeather F1 Rookie
    Feb 1, 2007
    3,653
    rock bottom
    Google Sketchup is simply the wrong tool for the job. It would be like using Legos to build a life size Ferrari. Fun, but limiting.
    I'd say if you haven't developed a skill for visualization using markers, then approach it with clay. At first the mockups may look rudimentary, but it may just motivate you to seek instruction on conventional Industrial Design methodologies & really ignite your imagination! What do you have to lose?
  9. HotShoe
    HotShoe F1 Veteran
    7,524
    Lake Worth, FL
    Anthony Lauro
    I'm sorry but if you want to design cars you HAVE to draw. Other disciplines may very but if you can't draw cars you will never design them. I'm not trying to discourage you, just trying to put you on the right track to a solid foundation. Ask yellow 439, he's a transportation professor at CCS.
  10. Qvb
    Qvb F1 Rookie
    2,827
    Newport Beach Ca.
    John Dixon
    I am pretty sure that no one is disagreeing with you.
  11. HotShoe
    HotShoe F1 Veteran
    7,524
    Lake Worth, FL
    Anthony Lauro
    Sorry. I wasn't trying to be arguementive. I just thought the statement below was misleading. I come across a lot of high school kids who want to be car designers and tell themselves that same statement as a crutch to poor drawing skills. Just like to make sure I get it across early to aspiring designers that it all begins with the pencil.
    Again, my apologies. Sometimes I just get a little too enthusiastic.
  12. Bounce
    Bounce Formula 3
    Nov 30, 2009
    1,024
    Perth, Australia
    Patrick
    Thanks for all the replies guys didn't expect this much helpful information!
    It is just something on the side for me to do, I have a lot of hobbies and sometimes I need to take a break from one another.
    I agree with all points that have been said, I just enjoy using sketchup I've used it for projects in the past and it just got things done.
    But yes, for cars it isn't very good because curves take a lot of work which in dedicated 3D modelling software is more straight forward.
    I've started sketching out what I see the final design now based on what I have so far and I'll move it over to Blender and start from scratch.
    Thanks again!
  13. Qvb
    Qvb F1 Rookie
    2,827
    Newport Beach Ca.
    John Dixon
    No worries, I wasn't trying to discount the importance of sketching, at Art Center everything else was secondary. I was more addressing that making computer models is difficult because you need to know where things are in relationship to each other and that learning form relationships in clay is very helpful in understanding how surfaces work. I think I sort of glossed over the drawing aspect as you had already discussed it and I also felt that the OP wanted to make models.
  14. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    18,014
    michigan
    john
    I would just like to add that I think it's great to have a passion for wanting to design vehicles,and if you enjoy doing it,by all means,enjoy yourself.But,I'll also say what I tell aspiring students that spend over $100K,and study for 4+ years:"if it were easy,anyone could do it". And trust me,it ain't easy.
    I would encourage you to keep working with whatever medium you are comfortable with,i.e.,computer,pencil/paper,pens,markers,clay,foam,plywood,whatever.If it's something you just have to do,by all means,have at it.But to the OP's original comment:correct.......it's not easy.Hard work & perspiration are usually the means to that end. :)
  15. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    18,014
    michigan
    john
    #15 jm2, Mar 18, 2012
    Just received this in the mail and thought it might be of some value to aspiring car designers/would be "stylists". I have no affiliation with the creator of the video other than some brief conversations,and I have no stake in the sale of the videos,but I believe it's a good place to start for someone who might be curious about drawing/sketching cars.I think it will get someone that has very little or no experience in drawing vehicles a fundamental starting off point.There is also an associated website: www.howtodrawcarsnow.com
  16. anunakki
    anunakki Seven Time F1 World Champ
    72,934
    Las Vegas Nevada
    Jerry
    Is P40 still the go-to clay for auto sculpture ?
    Back in the 90s I did side work for Honda in LA on the 5th gen Civic. Sculpted a few different concepts and I believe it was P40 chavant.
    These days I use Chavant NSP for stuff outside auto design.
    +10000
  17. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    18,014
    michigan
    john
  18. TheMayor
    TheMayor Nine Time F1 World Champ
    98,784
    Vegas baby
    Bingo.
  19. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    18,014
    michigan
    john
  20. anunakki
    72,934
    Las Vegas Nevada
    Jerry
    Yeah I use Chavant NSP (no sulphur content) for toys and effects but I think even the hardest grade would be too soft for auto sculpture.
    I also use some art products from Japan. They have a great selection of sculpture epoxies and seem to take the craft of sculpture more seriously then the US.
    I didnt know you started as a sculptor. Thats cool. My brief foray was in the very early 90s. I was freelance sculpting for Imagineering and one of the guys there said that Honda was looking for some fresh blood to do some sculpting. I went in and got the gig to work on sculpts of a couple , fairly radical, designs for a new Civic.
    I had never done anything like that but I loved cars and they gave me a shot. It was fun for a couple months but I went back to movies right after.
  21. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    31,564
    Seattle Area
    Dave
    Did any of your work end up on a "finished product" car?
    Jedi
  22. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    18,014
    michigan
    john
    #22 jm2, Mar 19, 2012
    I was wrong,we are currently using Chavant.My former employer stopped using it,but the place I'm at now uses it.At school,I think we are using another mfg.
    The Honda guys in SoCal were always up to some cool stuff.I walked around the Det. Auto Show with Dave Merek from Honda R&D (Acura showcar).He was explaining the car to our group of guys.
    Watching you sculpt on the show,I figured you had some form of training because your stuff looked so good.The sculptors I work with now are all veteran "styling" guys,and their work always amazes me.
  23. anunakki
    72,934
    Las Vegas Nevada
    Jerry
    Not directly for Honda. The ones I worked on were concepts.
    However, I did meet a guy who on the side was creating aftermarket body kits for Hondas and I later went and sculpted some that did make it into the marketplace.
    A little surprised to see you guys use the I-307 since it still has some sulfur in it. The P-40 and Y2 clays, also from Chavant as just as good and sulfur free.
    Honestly I cant remember the names of anyone from Honda except for my direct boss who was Evan.
    I learned alot about sculpting clean and symmetrical there. Great experience.
  24. HotShoe
    HotShoe F1 Veteran
    7,524
    Lake Worth, FL
    Anthony Lauro
    Man I hated that egg smell that chavant had back in the day. That was some nasty stuff that would stick with you for day's. It was nasty but it did finish up great. We used to just shoot sandy fill right on top and then paint. The downside was longevity.
  25. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    18,014
    michigan
    john
    #25 jm2, Mar 19, 2012
    You're right.People that didn't work in the studios all day always complained about the smell of the clay.I was so used to it I couldn't smell it.Kinda like garbage collector's inability to smell their work I guess.... :)
    Still scrapin' the clay off the bottoms of my shoes at my current jobs.Always envied people that had shoe bottoms that were clean.The stuff gets in the grooves of the gas & brake pedals of my cars.That sh.. gets everywhere!
