Captive nut on Door Striker? | FerrariChat
Discussion in 'Mondial' started by Alden, Nov 30, 2023.
  1. Alden
    Alden F1 Rookie
    3,365
    Central Florida
    Can anyone tell me if the door strikers on my 1988 3.2 cabriolet are held in by a captive nut on the other side of the door jamb? Mine keeps loosening up, and I would like to remove it to put some thread locking compound on the threads, but I don't want to if the retaining nut is going to fall behind the sheet metal.
    Alden
  2. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,575
    Argent/Brasil
    Guido
  3. Alden
    Alden F1 Rookie
    3,365
    Central Florida
    Thanks for the info Guido, so if I remove the striker from the door jamb side will the plate and nut stay in place on the inside of the fender?
    Alden
  4. theunissenguido
    Jan 21, 2004
    2,575
    Argent/Brasil
    Guido
    Plate is hold by 2 lips, 1 on upper and 1 on lower side. It moves horizontal and a little bit vertical. Plate can be removed on the inner side of that fender piece but will stay in place when you remove the door lock bolt. I dont remember if there is a nut soldered on that little plate or that the door bold screws directly on that plate.
  5. Alden
    Alden F1 Rookie
    3,365
    Central Florida
    Thanks for the clarification Guido, as long as I know if I remove the striker that the entire assembly won't fall down inside the fender, I'm sure it is possible to access the inside of the fender, but I really don't want to do that much disassembly unless absolutely necessary, I just want to get the striker bolt out to add some threadlocker, and reinstall it in the proper position so that the door will close properly. I have made this adjustment several times over the years, but now the retaining nut on the other side of the fender is spinning. When I try to tighten the striker bolt, by putting some pressure on the assembly from the door jamb side, I'm able to tighten it up, but it always seems to loosen up again. I think some threadlocker will keep this from happening. Thanks again.
    Alden
  6. theunissenguido
    Jan 21, 2004
    2,575
    Argent/Brasil
    Guido
    #6 theunissenguido, Dec 1, 2023
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,913
    Isle of man- uk
    When you refit it, if you leave it slightly loose then slam the door shut , it should move to correct position against the seals. Then nip it up- saves a lot of adjusting attempts.
  8. Alden
    Alden F1 Rookie
    3,365
    Central Florida
    I've adjusted it several times over the years, it usually just needs a tap to get it back to the proper adjustment, followed by tightening it up, but lately it's loosening up quicker and quicker, I will check the assembly for the correct washer/gasket, I have the parts drawings on my computer but I wasn't sure (and still can't tell from the drawings) if the nut within the fender assembly was captive, I assume it's not going to fall out, but whatever was keeping it from turning behind there is no longer functioning, so I have to put outward pressure on the striker in order to get the assembly to tighten up.
    Alden
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,913
    Isle of man- uk
    From what I recall there is a soft black plastic lipped washer the pin sits in, held in place by an Allen screw through the centre ? I think you have an extra washer in yours ?
    I think you can remove the red panel as well to give you access to the captive nut
  10. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    522
    NYC
    Joe
    As Guido said, the nut plate is caged. You can remove the allen bolt, surrounding hardware (see pic of plated pieces below) and the large plastic washer without fear of the nut plate becoming inaccessible...there is also black plastic on the part of the striker that meets the door latch (will try to find a better picture)...
