Can’t release “P” after the battery charge | FerrariChat
Discussion in 'California/Portofino/Roma' started by Broiler010, Aug 24, 2019.
  1. Broiler010
    Broiler010 Rookie
    Mar 27, 2019
    6
    hiroaki hayashi
    My 2010 Cali.’s battery had died after 10 days of not driving. So I charged it with a charger and the engine had started, tie air, the stereo all work fine.
    But the trunk doesn’t close nor the fuel lid doesn’t open, and the worst of all, I can’t release the parking brake that I can’t go anywhere.
    Are there ways to solve this, or do I just wait till the battery gets charged more?
    I’ve been sitting like 20, 30 minutes with the engine running that it might even be out of gas before anything.
  2. vjd3
    vjd3 F1 Rookie
    2,565
    Massachusetts
    Vic
    I would shut it down, disconnect the negative terminal on the battery for a few minutes, reconnect, cross your fingers and restart.
    Broiler010 likes this.
  3. ttforcefed
    ttforcefed F1 World Champ
    18,753
    yep exactly. id actually just buy a new interstate battery and go from there. if that battery is original its overstayed its welcome by a long shot.
    Broiler010, Fireman1291 and BOKE like this.
  4. Randy R
    Randy R Formula Junior
    334
    SF Bay Area
    '14 Cal 30 TDF/Tan
    Try holding the key fob unlock and trunk release buttons simultaneously for 5 seconds.
  5. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Disconnect the battery for 10 minutes. Then reconnect. Follow the reset procedure as shown in your owners manual, where there is a guide for resetting the system after having the battery disconnected.
    If that does not work, I'm afraid you're looking at either having a tech come to you, or manually releasing the brake and then taking the car to the dealer.
    But try a "hard" reset first with the battery disconnected for 10+ minutes. Reattach and follow the steps as oer your manual. It is very likely to fix it.
  6. Broiler010
    Broiler010 Rookie
    Mar 27, 2019
    6
    hiroaki hayashi
    Thank you everyone!
    This is what I tried and worked.
    I shut the car off, left it for a few hours, and then opened the trunk, this time with the key remote,
    and it worked.
    And then for some reason, the button for the trunk and and the fuel lid by the seat, started to work as well.
    And then started the engine, and was able to release the parking brake too.
  7. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    If you read the owners manual, you would see that you have to initialize the door lock system by locking and unlocking the doors after disconnecting the battery.
    Otherwise the trunk, fuel door release and top operation will be deactivated.
    Broiler010 and BOKE like this.
  8. Broiler010
    Broiler010 Rookie
    Mar 27, 2019
    6
    hiroaki hayashi
    So it's more like "as it says in the manual" and not "for some reason"!!
    thank you very much :)
  9. Carnut
    Carnut F1 Rookie
    3,797
    Gladwyne PA
    Morrie
    I do agree that you might want to get a new battery OP. These cars are tricky when it comes to batteries, and my cars sit without chargers for longer than 10 days very often and they all start up. I keep a spare battery for all my cars and I have a shop type battery recycler that can also test the batteries ability to hold a charge
