488 - Can you use ceramic brake pads for steel roters on Ferrari Carbon Ceramic brake system? | FerrariChat
488 Can you use ceramic brake pads for steel roters on Ferrari Carbon Ceramic brake system?
Discussion in '458 Italia/488/F8' started by 488gtbb, Feb 21, 2023.
  1. 488gtbb
    488gtbb Rookie
    Aug 6, 2022
    28
    Blackice
    I was wondering if you can use ceramic pads that are designed for steel brake systems, on a Ferrari
    that is using Carbon ceramic rotors.
    Since all Ferrari's are equipped with CCB, only brake pad choice we have is stock Brembo pads for CCB
    or Pagid Rsl series pads.
    It would be nice if there were a lot of pad choices ~ like Ferrodo, Endless, PFC ect.
  2. Giallo27
    Giallo27 Formula Junior
    Sep 21, 2020
    264
    JB
    Sorry, you can’t.
    Basically CCM pads brake because they are “melting” with discs when they reach the right temperature.
    Steel pads brake because of the friction with disc. Moreover these pads have different metal in its composition, and it would damage the ccm rotors.
    488gtbb likes this.
  3. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,653
    France
    Pagid RSC are also adapted to CC rotors; that's the ones I use.
  4. Kent Adams
    Kent Adams F1 Rookie
    2,932
    Not all Ferrari's have CCB, the newer one's do. Frankly, I prefer steel brakes but it's no longer an option.
    mdrums likes this.
  5. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,189
    Tampa FL
    Stick with the stock pads or Pagid pads designed for CCM rotors like the rsc1
  6. 488gtbb
    488gtbb Rookie
    Aug 6, 2022
    28
    Blackice
    Thank you~ looks time to search some stock pads from Brembo.
  7. 488gtbb
    488gtbb Rookie
    Aug 6, 2022
    28
    Blackice
    How does it feel, compare to the stock CCB pad? If its aggressive to the rotors Im sticking with the stock pads.
  8. 488gtbb
    488gtbb Rookie
    Aug 6, 2022
    28
    Blackice
    Ow I see.
    I also prefer steel systems. So manys pads to choose from.
    I saw some 488s with Gyrodisc still rotors,
    Thats not possible?
  9. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,653
    France
    The 488 used for rentals on track are all equipped with steel discs, so kits certainly exist.
    Regarding the Pagid RSC they are a great combo with the Surface Transforms CC discs; I assume they'd be also good with the Brembo discs.
  10. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Surface Transforms now has a U.S. distributor. There is no way I’d compromise braking and other performance by going to heavy steel rotors. At these prices plus the ability to refurbish, they’re less than the cost of more frequent iron rotor replacements while keeping all the advantages of carbon ceramics. Use with Pagid RSC-1 for slightly better street performance, or RSC-2 for street/track.
    From their site.
    “ST vs Iron Rotors
    Up to 70% weight savings compared to iron brakes - typically 40lbs of unsprung weight
    Improved handling and drivability
    Improved NVH (less noise, vibration, and harshness)
    Improved performance in both wet and dry conditions
    Reduced brake wear / increased life
    Reduced brake dust
    Corrosion-free, no more rust!
    Outstanding performance, even from cold
    ST vs Traditional Carbon-Ceramic Rotors
    Approximately 50% less expensive than OEM CCB rotor replacements
    Able to be refurbished up to 3 times (see below for details)
    Average expected track life is 4000 to 5000 miles*
    Street life should exceed the life of the car*
    Available for both existing CCB and cast iron fitments without replacing calipers
    Better braking performance
    Significant improvement in brake modulation - better trailbraking
    Option to run a much more aggressive pad for track applications
    Working with more brake pad manufacturers to offer different compounds
    Operating temperatures approximately 200 degrees lower than traditional CCBs”
    https://hinzmotorsport.com/collections/surface-transforms-for-ferrari-models
  11. PowerLabs
    PowerLabs Rookie
    Apr 26, 2010
    46
    That is a very odd description, given that:
    - Carbon has no melting point, it sublimes (transitions from a solid to a gas) at ~6400F. Your brakes never actually reach that temperature, they mostly “wear” by oxidizing when exposed to air at high temperature, which is why the service life of carbon rotors is a function of rotor mass: once enough material has oxidized away they need to be replaced.
    - All brakes work “because of the friction between the pad and the disk”. There is no other mechanism by which train, airplane, or car brakes work, regardless of what materials are used.
    To answer the OP’s question, it is not uncommon to use aftermarket brake pads with carbon rotors in things like corvette ZR1 brake rotor swaps into other cars, it seems to work OK but is not something I would personally experiment with. Some brake pads such as metallic compounds are likely to transfer pad material to the rotor and cause uneven spots, leading to vibration, noise, etc.
