Can low battery cause erroneous error messages? | FerrariChat
Discussion in '360/430' started by RedNeck, Jan 5, 2017.
  1. RedNeck
    RedNeck F1 World Champ
    11,971
    The CSA
    Me
    Maybe I'm just hoping for the best here...but my car sat for about a week and a half before I put it on the tender..left it on overnight and it wasn't fully charged. Drove the car for a few miles, stopped for gas, and when I started it back up, I saw ASR OFF, then the display cycled ASR(orange)/Suspension and the ABS light came on. Brought it back home and stuck it back on the tender...almost 2 days to get to fully charged after turning the magic kill knob. Probably wont be able to take it out again until next week, but wondering if anyone else has had this experience.
  2. RedNeck
    11,971
    The CSA
    Me
    Also, I asked the seller if it was jumped before it was shipped, he said it was on a slow charger for 3 hours and then started. None of this turned up in the PPI and the car was only driven from the shop to the dealer afterwards.
  3. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    Yuuuupp!
    I had multiple ASR errors and other weird warning lights and it was caused by an old battery years ago.
    This is the first thing I'll do, swap batteries.
  4. RedNeck
    11,971
    The CSA
    Me
    Awesome....hope that's it then. The battery is an Interstate, only a couple months old, but if there happens to be a battery that has proven itself to work well for these cars, I'll switch. I measured it at 12.00V after the first night, but it must have been very low since it took so long to reach full charge.
  5. andy308
    andy308 Formula 3
    Jan 16, 2005
    2,024
    Sarasota, FL
    Andy
    I had this happen last winter, battery was 7 years old. Called Matt at FOA and he told me they recommend the Interstate MT7-34R AGM battery. Bought one for about $275 and it fixed all the weird things happening to the car. Make sure you turn the cut off switch in the front before you remove the battery. Also, after you put the new battery in the drive cycle will have to be completed before you can pass emissions. I had driven mine for 5 months (over 1000 miles) and the drive cycle still had not been completed. Tried it myself and could not do it, took it to FOA and they were able to get the drive cycle completed, it can be tricky to complete correctly.
  6. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    Mine was Interstate too and they replaced it through warranty coverage. They verified that there was a dead cell or something molecular unit in then battery.
    They replaced it and since then I started utilizing trickle charger. Never happened again.
  7. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Battery "tenders" are not the same as battery "chargers." Tenders are not really made to recharge but to maintain a decent charge. A charger will provide more current to bring the battery back to where it belongs more quickly.
    Charging any battery at the slowest acceptable rate (lowest current) is always the best for battery longevity. It's a matter how how quickly you MUST have it fully charged.
  8. HIO Silver
    HIO Silver Formula Junior
    Mar 12, 2016
    497
    Northern California
    Alonso C.
    A battery tender can eventually charge a dead battery. Some circuits work on threshold voltage so if the voltage isn't there, false logic (digital) can result.
    Plus it seems Germany's Bosch ECUs lose IQ points when it is inserted an Italian steed.
    Here's a trend I have noticed about my 360... it is more likely to trigger a CEL when it has less than a half a tank of fuel. I have checked for stored codes and nothing comes up. If I go through the reset procedure and fill it up, the CEL doesn't come back. I have even tried to replicate what I was doing and nothing.
    I'm on my third "half-tank" fill-up since the last CEL incident and all is clear. Weird.
  9. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,751
    England
    Mark
    Low battery in these cars can cause all sorts of issues.
  10. vrsurgeon
    vrsurgeon F1 World Champ
    16,436
    Charleston, SC
    Curt
    You guys keep reusing these batteries that should be replaced. Can afford a Ferrari but don't replace a $120 battery. Then you get these funky electrical warnings and presume that the cars are junk. 1) Tenders won't charge a battery 2) if a battery has drained to the paint of death.. GET A NEW ONE. The electrochemical reaction is depeted. It'll never be 100% again. Then.. you overheat your alternator diodes trying to charge a crap battery. 1-2 years later the alternator or cable needs replacing.
    My car has NEVER had a CEL or ANY electrical funkiness.. because I replace my battery with a new one every 3-4 years! Hint: It also saves your alternator!
  11. marknkidz
    marknkidz Formula 3
    1,323
    so cal
    mark
    Sure Curt... let me guess, you probably replace your timing belts every 3-5 years, when they are perfectly good!! ; ) LOL...
  12. RedNeck
    11,971
    The CSA
    Me
    It's a new battery. It was never flat, I just suspect that it was low because it sat for over a week and hoping it proves to be the source of multiple error messages.
  13. RedNeck
    11,971
    The CSA
    Me
    I understand the function of both, I was just making a point to show how low the battery was, even though it measured 12v (a perfectly healthy and fully charged battery should read around 12.7), and if that was enough to trigger gremlins.
  14. vrsurgeon
    16,436
    Charleston, SC
    Curt
    Oh no. I make an exception for the battery.
    Per usual used Ferrari ownership protocol, my belt service interval is NEVER or engine seizes. Whichever comes first. Back in the day I owned my Honda Civic for 25 years and never changed a timing belt. ;)
    RedNeck, not to put you on the spot.. I just read it soon often on this board. Something is causing a draw. Check for stereo equipment (Amps, etc.) and tracking devices, the usual culprits. When I first bought mine I went through and found not one but two devices hand twisted into the wiring loom, covered with electrical tape. Cold weather can also make things wonky.. I suspect by diminishing the battery output.
  15. djempire
    djempire Formula Junior
    Apr 30, 2012
    613
    Toronto
    Serf
    A weak battery can/will bring about "false positive" codes. Get them cleared and ensure the battery maintains its charge and the codes shouldn't return unless there is a fault.
    To clarify, a trickle charger can charge a weak battery but can't maintain a battery that is past it's prime. A new battery is needed.
  16. RedNeck
    11,971
    The CSA
    Me
    I though the same thing. There is actually a big-azz amp in the "trunk", but the was disconnected at the amp prior to shipping and I haven't connected it back yet...still debating whether I want to just remove it completely. It is wired up with large gauge wiring straight to the battery.
  17. Rifledriver
    36,747
    Still worth testing. Radio equipment installers do the dumbest things. Car should have no more than 25 or so mA draw.
    vrsurgeon's advice on batteries is a very good one. I also advocate plugging the car into a quality tender every time you park it. Lots intend to drive the car tomorrow and tomorrow comes in a week or two. Many modern cars have small 100+ amp alternators including all Ferraris built since the TR and those little alternators have the same thing in common, they are electronically fragile and simply cannot survive constantly being used in a car with a compromised battery. Damage to them is so common we test every single cars charging system and a high percentage put out below spec because of that. We keep an alternator repair shop busy because of those tinker toy alternators. No test but a load test on an alternator is worth doing. If it will not go past 125 amps easily it is circling the drain.
  18. RedNeck
    11,971
    The CSA
    Me
    Awesome info, thank you. I've been connecting it to a Deltran plus when its parked (I have a Ferrari tender also but didn't realize that the tender connection was an "option" that I didn't have when I bought it). It might also be worth mentioning that the battery is missing it's hold down so who knows how long it has been driven without being properly secured. I have one on order and will install it before driving the car again.
  19. LorenzoR
    LorenzoR F1 Rookie
    I agree with vrsurgeon also. Just not worth it. I replace my battery every 3 years regardless
  20. Drestless
    Drestless Formula 3
    Oct 1, 2014
    1,251
    Riverside, CA
    Jam
    Also worth cleaning up your mailbox Lorenz. Can't respond to your PM. :p
  21. Joey911
    Joey911 Rookie
    Jan 5, 2017
    23
    NYC
    Dr. Joe
    100% can and will
    A low battery in my 911 wont even charge (air cooled weak alternator) even causes backfire
    You'll throw codes.
    I use a battery tender trickle charger in the 911.
    full charge it use a multimeter see if it holds 12.6 volts about clear codes and see if they return
  22. LorenzoR
    LorenzoR F1 Rookie
    All clean....sorry
  23. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Not the ones I own. If the battery voltage is too low to start with the battery tender will not even try to charge the battery. I think that's what you're saying regarding the threshold voltage.
  24. RedNeck
    11,971
    The CSA
    Me
    The Deltran is >=3.0VDC
  25. RedNeck
    11,971
    The CSA
    Me
    Haven't taken it out yet, but at the time, it was measuring exactly 12.00VDC
