can a coil have a short and still work? | FerrariChat
Discussion in 'Technical Q&A' started by Pantdino, Jan 4, 2011.
  1. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    #1 Pantdino, Jan 4, 2011
    My 246GT has a short somewhere. With the ignition on but the switch to the fuel pump off it shows about 10 Amps discharge on the ammeter.
    Disconnecting the wires to the + terminal of the coil and removing all the fuses in the front boxes, then replacing them sequentially shows that there is no significant drain thru any of the fuses. However, when the + wires are placed back on the coil the 10A drain reappears.
    The coil is the traditional cylindrical type and the car uses an Allison / Crane optical trigger with associated box.
    The car starts and runs.
    Can a bad / failing coil do this?
    Jim
  2. DGS
    DGS Six Time F1 World Champ
    69,580
    MidTN
    DGS
    With an aftermarket ignition system, you'll probably have to consider the entire package.
    On a standard breaker point ignition, you'd be running plain voltage (usually through a ballast resistor) to the primary coil circuit, and interrupting the ground path, to force the magnetic field to collapse on the secondary windings, creating the voltage spike to fire the plugs.
    On a CDI system, though, (especially an early design) the coil wiring is often more complex, involving dumping capacitor energy into the coil.
    The Crane XR700 has been around roughly forever --- how old is the one in your machine?
    For a capacitive discharge system, I would expect the capacitors to start going bad by the time it's 20 years old.
  3. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    you can disconnect the coil and test it easily enough, use a multi-meter and check the resistance (ohm), depends on the rating of that coil, but typically is 10K to 11K, any more or less then it's time to change it
  4. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    Do you mean the resistance between the pos and neg terminals?
    I have seen other resistances listed in specs too- presumably between the pos or neg and output socket of the coil.
    Which resistance is which?>
    This is not a CD system-- it is a plain old fashioned coil with an optical trigger in the dizzy in place of points.
    Thanks,
    Jim
  5. Steve Magnusson
    26,504
    #5 Steve Magnusson, Jan 5, 2011
    This sounds quasi-normal to me -- i.e., if the optical wheel in the dist is blocking the light path, the Crane box should be trying to put current thru the coil primary winding and a rough static I= V/R for a coil is in the 10 amp ballpark. Is this a new (unexpected) behavior of the ammeter that you've noted, or has it always been this way?
  6. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Quick test, with the ignition switched on pull the molex connector from the Crane XR700/3000 ignition to the distributor pickup wire, your ammeter should now go back to normal.
    • If it does, the Crane box should be ok but your coil might have several shorts in the primary winding, measure the resistance between the two screw terminals (remove one of the wires first), you should see a value somewhere around 1.6-3 Ohm.
    • If the ammeter does still indicate a 10 ampere load, the Crane/Allison box might be defective. What happens if you remove the red wire coming from the Crane/Allison box, do you still see the 10 ampere load?
  7. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    This is a new problem. I do not recall seeing that much discharge ever before.
    My tach has also been acting a little strange lately, which is probably related.
  8. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    I'll do these diagnostic steps after work today.
    If there are shorts in the primary winding, does the resistance go up or down? I presume it would go down if the shorts are to the case and the case is in contact with the negative terminal.
    I'll have to see where the Molex connector is. It is probably buried in the area between the engine and rear compartments and will require pulling the wheel and inner fender liner.
    I could also take the dummy way out and just replace the coil-- but I like to avoid "throwing parts at" a car :)
    Jim
  9. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    Don't forget to do the simplest test of all with car ignition problems. Have a look at what's happening under the hood when it's dark. Get someone to start the car too and see of there are sparks anywhere there shouldn't be.
  10. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    The resistance goes down, the primary winding does not touch the case but the insulation between the primary windings itself breaks down.
    It's quite possible to retrieve the wire with the molex connector from above without having to remove the wheel and liner, give it a try.
    Good luck,
    Adrian
  11. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Whether your ignition coil or a transformer in your washing machine, a common failure mode is insulation breakdown causing adjacent turns shorting yet it functions adequately. A shorted turn causes heat, then more insulation breakdown, then another shorted turn, more heat, more shorted turns until the smoke escapes. A resistance measurement is meaningless now when looking for a 20% change as you don't know what resistance it started at.
    The other obvious possibility is the amplifier which simply supplies a closed position simulating breaker points but has advantages over them. They are supposed to present an open with engine not running not all early ones did. My bet is here.
    The XR700 uses a standard (non internal ballast resistor) coil, which are about $20. Why not start minor money throwing and remove any doubt about the coil? I pulled the 246 wiring diagram and find a spare ignition coil marked 'emergency'. Worse case you will be back to original with a spare coil. But it will end your doubts.
  12. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    When I remove the red wire to the Crane box the load goes away.
    I measure 1.7 ohms resistance from the pos to neg terminal. I don't know what it was when it was new, but it is a Jacobs Electronic coil, from before they were bought out by Accel. Looks like coils designed for non-CD systems now are made with about 1.4 ohms resistance, so 1.7 is within that range or greater..
    http://www.accel-ignition.com/ProductDetails.aspx?modelNumber=8145C&productID=6773&majID=505&minID=5057&selection=0&minselection=6
    http://www.cranecams.com/416.pdf
    Beginning to sound like it is the Allison / Crane box that is bad?
    Jim
  13. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    #13 Pantdino, Jan 5, 2011
    here's what I wrote to the Crane tech site-- sort of summarizes the situation, I think.
    In about 1990 I installed an XR700 module with light bulb type optical trigger and have driven the car about 5000 miles since. I have a new problem-- a current loss which I have isolated to the ignition system. With the ignition on and the electric fuel pump off I show about a 10A drain at the ammeter. If I disconnect the red wire to the XR700 box (but the coil still hooked up) the drain goes away. The car does run, but the tach acts a bit strange and I have a discharge situation even at 2000 rpm, at which time I show 14.2v at the battery terminal of the voltage regulator. Replacing the voltage regulator made no difference. The coil is an old-fashioned cylindrical type Jacobs Electronics and shows 1.7ohms between the neg and pos terminals, which is probably what it was new.
    Could a bad XR700 box do this?
    Thank you.
  14. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    That is interesting, good chance that the box is shot. While you did that test the coil was still connected to the red +12V wire from the car wiring?
    Background, the red wire to the Crane box only supplies the electronics, which switches ground to the coil, e.g. there should be virtually no load (<0.5 A) issued by the box itself.
    That sounds normal for an inductive coil, although the Crane XR700 usually wants to see a ballast resistor in front of the coil. The coil current (~7 ampere) with your current setup might have been a bit too much for the ignition box.
    Looks like it, i don't think that the coil is responsible for the issues you see. Would be great if you could have a try at the Molex removal test, though.
    BTW, could you check if your XR600 box is potted (filled with epoxy)? If not, it should be quite straightforward to fix it.
  15. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    Here's the response from the Crane tech guy. He writes XRi but I think he knows I have an XR700.
    "Good morning Jim,
    We don't think there's any way for an XR-i to cause a 10 amp draw,
    especially if it's still operational. Are you using a hand held or dash mounted
    ammeter? We would be happy to test your XR-i if you'd like to send it to us. If
    you decide to have it tested send me your shipping address and daytime telephone
    number and I'll send you a return authorization number and shipping
    instructions."
    Results from tonight's tests:
    The line from the battery to the + coil terminal shows 12.2v without the engine running.
    If I touch that wire to the red wire from the Crane box WHEN THEY ARE NOT TOUCHING THE COIL TERMINAL, there is no change in the ammeter needle. Only when all 3 are touching does the needle dive to the -10A position.
    A probably basic question:
    Does the Crane box open the grounding circuit for the coil? So if the Crane box is not attached to the + coil terminal (not energized), the - coil terminal is not grounded? Therefore there is no current flow under that condition, no matter how badly the coil is shorted internally?
    I did read that the XR700 box will fail unless there is a ballast resistor in the line, so unless I totally screwed up 20 years ago it makes sense that my coil was >= 3 ohms when it was new. So maybe it's bad despite its 1.7ohms being on the high side for coils sold these days for other applications. Also, if I really did mess up way back then the box probably would have failed long before now, no?
    I found what I think was the coil that was on the car when I got it, and it measures 3.1 ohms. That would make sense.
    So I'm thinking if the answer to the question above is, "Yes, the coil is only grounded when the Crane module is energized," then the coil is probably bad and is the problem.
    Or is that not correct?
    Thank you
  16. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    As I wrote above, I think the XR700 is bad but recommended buying another coil as a cheap way to sort things out.
    The function of an amplifier is to provide a short to ground for the coil when, and only when, the distributor rotates to that precise magic point dictated by points or sensor. Having a short at all times (10A) is unusual but you claim the engine runs, so it's hard to beat reality. Somehow the full short might somehow clear and return to the normal few milliseconds short to achieve spark. The coil must then be returned to open-no current condition to ready itself for the next spark.
    Ballast resistor - Ignition coils are wound for a specific input voltage. Early cars simply applied the full battery voltage to coils designed to run at battery voltage. The ballast resistor was an innovation around the 60's. It's purpose is to help engines start easier by providing a high spark plug voltage during cranking then dropping back to an adequate voltage for normal running.
    The 246 doesn't have provision to switch the ballast resistor out during start, therefore requires a coil designed for no ballast resistor, i.e. the full nominal 12v of the battery. And your original resistance of 3.1 ohms sounds right for a 12v coil. I was in O'Relieys yesterday for wiper blades and they said such a coil is about $20.
    Yes, when it's working properly regardless of manufacturer or type.
    True, the only ground for the coil is through the boxes output transistor.
    Yes
    I read otherwise. The box will ultimately fail if the coil requires a ballast resistor and it's not used...but not all coils require a ballast resistor, again, depends on it's design.
  17. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    You are right-- I was assuming we were talking about the coils I had seen advertised on line, which seemed to have resistances of 0.4 - 1.4 ohms.
    My working hypothesis at this point is that the coil is shorted internally but not to the point where it is not making any spark-- hence the car runs.
    Probably won't have time to switch the coils until tomorrow or Saturday
    thanks for your help
    Jim
  18. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    #18 alhbln, Jan 7, 2011
    Ignore the coil for a moment, the question is why there is ground switched through the coil when the engine is not running. Either you always park the Dino with the rotor blocking the optical switch (not very likely) or there might be a defect with the optical switch/trigger input stage of the XR700 leading to such a symptom. Your last test proved that the output stage of the XR700 is ok, so we need to focus on the input stage/optical trigger.
    With the ignition switched on and the ammeter showing -10 ampere, try to either temporarily remove the molex connector going through the distributor pickup, or put the Dino in fourth gear and push it an inch or two so the trigger wheel in the distributor passes the optical switch.
    Check if the ammeter still shows -10 ampere or goes (temporarily) back to normal.
    With the molex connector pulled, there should be no current flowing through the coil at all.
  19. DGS
    69,580
    MidTN
    DGS
    #19 DGS, Jan 7, 2011
    Um, I'm not all that familiar with the Crane*, but in a normal breaker points system, the connection to ground *opens* when you want the coil to fire.
    The ignition voltage creates a current through the primary windings, establishing a magnetic field on the core. The current through a coil resists changing instantly. So when you open the breaker points, interrupting the current, the magnetic field then creates a very large voltage spike on the secondary windings, causing a spark at the plug (dumping the magnetic field energy to the plug).
    (This is also why you sometimes see burnt contacts on 308 ignition key switches: the current in the starter solenoid will resist a sudden disconnect, and you can get a negative voltage spike which can arc across the key switch contacts.)
    So it's when you want the coil to fire that you *open* the ground connection.
    (The "condenser" in a points system is to prevent arcing across the breaker points.)
    So you'd expect the current to build through the coil (primary) to a steady state value, except when the coil is firing (the dwell period).
    Some early electronic ignition systems ignored the field collapse effect, and used a coil as a simple transformer, dumping a spike of energy into the primary (usually from a capacitor). But if the Crane isn't a CDI system, I'd expect that it'd be opening the ground contact to fire the coil.
    (* I looked into after-market ignition systems for the Alfa, back around 1980, but my mechanic put it in perspective: you can buy many sets of points for the cost of an electronic system (back then). ;))
  20. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Fully correct :) In an 'inductive' electronic ignition such as Jim's Crane XR700 the transistor does the job of the points switch, as transistors can handle a much higher current (points can go up to 4-5 ampere only) and you can do nice things on top such as electronic control of dwell and maximum coil current.
    BTW, the Dinoplex ignition which was factory installed in the Dino is a 'CDI' capacitive ignition.
  21. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    No
  22. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    So I first substituted an old coil I have with 3.5 ohms resistance. As expected, there was noticeably less current drain when the ignition switch was turned on. Unfortunately I think the connector in the socket for the high tension lead to the distributor was damaged, so I couldn't start the car to check the charging status
    I put an old VW / Audi coil with 2.1ohms resistance in and got virtually the same ammeter readings as with the 1.7 ohm coil that is in the car- about 10A draw with ignition on and not running, maybe 5A discharge at 2000 rpm. So the 1.7 ohm coil is not grossly defective.
    I haven't mentioned that I also have an aftermarket rev limiter on the car. Maybe time to see if I can take it out of the system? I'll have to check the wiring diagram to see how it works.
    Or maybe my new voltage regulator is no good? Wouldn't be the first time I got an electronic device that didn't work right.
    I'll have to pull the wheel and inner fender liner to disconnect the Molex connector of the Crane box- I conscientiously wire-tied it up where I can barely feel it at the rear portion of the engine bay.
    Jim
  23. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    #23 Pantdino, Jan 7, 2011
    Here's the wiring diagram of the rev limiter, called Rev Safe. I think it's an analog device, as it has a continuously variable knob.
    Looks to me like it provides a path of least resistance for the current from the coil to ground, which prevents the collapse of the magnetic field in the primary winding when the points open or the ignition box tries to do the equivalent.
    So if this is defective, could it be dumping amps all the time, not just when it is supposed to?
  24. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Yes, absolutely! Please remove the green wire and check your ammeter again.
  25. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    update--
    I checked the system for ballast resistance per the Crane installation instructions and I get 7.5v at the + coil terminal with the - terminal wires removed but that terminal shunted to ground. According to Crane this means there is ballast resistance somewhere in the system-- must be between the coil and ground because I get 12v at the + coil terminal when the negative is not shunted to ground.
    So this 1.7ohm coil is the correct one for the system.
    I removed the green 12v line to the rev limiter-- no difference. Removing the black ground in addition makes no difference either. When I hook it back up again the "Power" LED in rev limiter is not lit, but it does limit the revs when tested by setting it at 2000 rpm.
    When running the car cannot quite get to 0 on the ammeter, even at 3000 rpm. Maybe the alternator is the problem?
    Time to check the outputs of the alternator at the voltage regulator again.
