Cam Timing | FerrariChat
Cam Timing
Discussion in 'Boxers/TR/M' started by Nick G48, Feb 28, 2021.
  1. Nick G48
    Nick G48 Karting
    Aug 18, 2016
    57
    Clinton Township, Michigan 48316
    Nick
    Have the engine out of my 86 TR for the 30K. Presently doing the Valve Timing procedure. I feel comfortable that we are doing the procedure and measuring valve clearance correctly. Here is my question: We determined the size shim to use on number 1 and number 7 for intake and exhaust. Example: One shim will be 3.93. Since a standard shim is 3.90 and 3.95, can I use either one or do I have to grind a shim to 3.93?
    I thought I read somewhere that you just use the next closest size. If this true?
    Thanks for the help
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,920
    romano schwabel
    you are right with the standard shims with 3,90 and 3,95 - but when you meassure you see sometimes that they are not 100% correct, so plus/minus 1/100 in not unusual
    so when you do the adjustment not only check when intake and outlet valve will open, also when will close. and when you then have the ° when opening and closing same far away than standard you are right
  3. Tegethoff
    Tegethoff Formula Junior
    Jul 19, 2014
    301
    Los Feliz
    Adam
    If you're not grinding shims to fit use the smaller size, I.e. 3.90 for a 3.93, better to lose a bit of duration than the alternative.
    IMHO, you're looking at .0011" vs .0007" either way, not enough to get too concerned about for a street driven engine.
    turbo-joe likes this.
  4. Nick G48
    Nick G48 Karting
    Aug 18, 2016
    57
    Nick
  5. Nick G48
    Nick G48 Karting
    Aug 18, 2016
    57
    Nick
  6. Nick G48
    Nick G48 Karting
    Aug 18, 2016
    57
    Nick
    Thank you for the information
  7. Nick G48
    Nick G48 Karting
    Aug 18, 2016
    57
    Nick
  8. Nick G48
    Nick G48 Karting
    Aug 18, 2016
    57
    Nick
    Thanks. I ordered a complete set of shims today from a company in Germany. I should have every size that I need
  9. Nick G48
    Nick G48 Karting
    Aug 18, 2016
    57
    Nick
  10. Nick G48
    Nick G48 Karting
    Aug 18, 2016
    57
    Nick
    Thanks for the info. Much appreciated
  11. turbo-joe
    Apr 6, 2008
    8,920
    romano schwabel
    would be good if you will fill out your information to know in what area of our small world you are living. then I think you will get some more detailed help. also would be great to introduce yourself a little
  12. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,899
    Troy, Michigan
    James
    Nick's in Metro Detroit. I helped him pull his motor a few weeks ago. He has an '86 Black Testarossa.
    Nick G48 likes this.
  13. Nick G48
    Nick G48 Karting
    Aug 18, 2016
    57
    Nick
    I added info. I am located in Michigan, near Detroit
