Cam timing diagram | FerrariChat
Cam timing diagram
Discussion in '348/355' started by taz355, Apr 14, 2021.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,965
    Indio Ca/ Alberta
    Grant
  2. Qavion
    Qavion F1 World Champ
    11,533
    Ian Riddell
    Here's a degree wheel for the 512TR.
    Due North is top dead centre for chosen piston. Due south is bottom dead centre.
    The outer shaded area is intake valve open duration. The inner shaded area is exhaust valve open duration.
    Now the big debate on how to find TDC :p
    I see Dave Rocks has a handy tool for finding TDC using the piston stop method.
    Tolerances are shown on page B14 of the WSM.
    Are the values the same for the 2.7 and 5.2? I see the values are different on the 512TR for USA cars.
  3. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    853
    Europa
    Bob
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,965
    Indio Ca/ Alberta
    Grant
    Thanks guys
    Mitchell was also on the job
    Qavion likes this.
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,965
    Indio Ca/ Alberta
    Grant
    Another question I had is I just looked at my cam seals
    I do not see any drain holes
    My car is a 99 so is it possible it has diffferent seals
    I am looking at the part number 27
    My part numbers 26 have grooves cut at the 5 and 7 o’clock position that look,like they drain oil that might be trapped within the seal back into
    The head
    Any ideas because I have new seals from ricambi and there are no holes in them.
    Am I missing something
