cam tensioner bolt | FerrariChat
cam tensioner bolt
Discussion in '308/328' started by conan, Nov 23, 2020.
  1. conan
    conan Formula Junior
    Nov 13, 2011
    389
    Hi, just wondering about the 111458 bolt. How many of those have sheared off over the years? Threads stripped?
    I am just thinking about my seat bolt that snapped right off one day ...
    I plan to use some crack detecting fluid next cam belt change, but thought someone may have some insight into this?
  2. Martin308GTB
    Martin308GTB F1 Rookie
    4,228
    Black Forest Germany
    Martin N.
    I think, you cannot compare that bolt with a seat bolt. Look at the thread diameters. I think, before this bolts snaps, you will crush or crack the light alloy tensioner bracket.
    Best from Germany
    Martin
  3. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Unless you have reason to believe that the bolt has been over-tightened, I believe the potential for cracks is extremely unlikely.
  4. GordonC
    GordonC F1 Rookie
    4,121
    Calgary, AB, Canada
    Gordon
    I've just had my timing belt tensioner assemblies out to replace the belts and pulleys, and was impressed again at the bolt that holds the pulley. No way would the threads get stripped on the bolt, that will strip the hole in the head long before it's own threads let go! (which bears reminding, use a torque wrench always! ;) ) The bolt won't ever get stretched, stripped, or otherwise damaged at the recommended torque value.
    Cheers,
    Gordon
    waymar likes this.
  5. conan
    Nov 13, 2011
    389
    Thanks for all comments. I guess risks are low with this bolt, but for curiosity reasons I will probably do a check for cracks and compare the two bolts.
  6. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,691
    Mike 996
    "The bolt won't ever get stretched, stripped, or otherwise damaged at the recommended torque value."
    As is true with all fasteners! :)
