Cam Covers- to paint or powder-coat | FerrariChat
Discussion in 'Technical Q&A' started by F&M racing, Nov 15, 2007.
  1. F&M racing
    F&M racing Formula Junior
    Feb 26, 2006
    668
    Michigan
    JimF
    I would like to get my cam covers done in a wrinkle red. Should I be concerned about having them done in a Powder-coat? Has anyone had bad results with this process? Has anyone tried wrinkle spray paint with good results? My concern is media blasting and the heat cycle involved when applying the powder-coating to the Cam cover. I've had alot of parts powdercoated on my 911 but they were steel with excellent results, but nothing in Alum.
    Jim
  2. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I powder coated my 3.2 covers in dull crinkle red with very good long term results.
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Bead blasting is no problem (avoid the inside surfaces). The aerosol wrinkle paints are pretty easy to use (I use one or two halogen floodlights positioned close to supply the necessary heat to initiate the wrinkling). Do it in a well ventilated area (the smell is terrible).
    Powder coating is also no problem and will have a little different "look".
  4. rizzo308
    rizzo308 F1 Rookie
    2,748
    Perth, Australia
    riggio
    #4 rizzo308, Nov 15, 2007
  5. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    #5 FasterIsBetter, Nov 15, 2007
    I painted my cam covers and timing belt covers with VHT wrinkle red spray paint. I cleaned them up very carefully, did not bead blast them, and made sure they were thoroughly degreased before painting them. The "trick" in getting the wrinkle to come out right is to be sure that you do it in a warm environment, relatively low humidity. Follow the directions on the can, especially with regard to second and third coats, very carefully, and it should come out fine. I did not paint the raised lettering. Rather, I painted it all red, and then after it was thoroughly dry, I used very fine sandpaper to sand down the surface of the raise lettering. You can pick up the VHT paint at most auto parts stores or hot rod shops. I'm not the worlds best painter, but I like the way they came out.
  6. davem
    davem F1 World Champ
    10,003
    Stepford, Connecticut
    dave m
    There is a poster here who just did his covers with a smooth glossy powdercoat finish. Not as original looking, but the nice part is grime wont stick like it will with a crinkle finish.
  7. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    Some of the "better" powder coating places will do PC in a wrinkle red finish that is as near to original as a can of VHT. The difference between this great PC and a can of VHT is about $200 - I used a can of VHT :)
    Dave (el cheapo) T
  8. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Way to go Dave.....my kind of man..lol
    Now with the big$$ savings you can take the wife out for a night on the town.
  9. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Came out better than the supposedly professional refinish done on my magnesium wheels...lol
  10. FasterIsBetter
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    And so far <knock on wood> it's holding up perfectly! Very proud of my work. :)
  11. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,113
    Norfolk - UK
    Tony
    #11 TonyL, Nov 15, 2007
  12. rizzo308
    rizzo308 F1 Rookie
    2,748
    Perth, Australia
    riggio
    steve ... great job mate!!! looks very nice indeed
  13. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Tony,
    Beautiful job, I know it takes a zillion hours to do all of the little details to build an engine to this point, ( :) not that mine ever looked this good).
    You have a good point about kepin it clean. Wrinkle looks good initially, but how do you keep all of the dirt and schmutz out of the wrinkles so it loks good??
    Maybe a smoth PC with a polish on the reised letters and numbers???
    Nice Job,
    best,
    chris
  14. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    Occasional/frequent washing with a toothbrush...
    Tony,
    Was must have spent 3 minuites trying to figure what it was about your engine that didn't look quite right. Finally hit me, it's missing a pair of cylinders & you can't see the backs of the cam gears(DUH)... ;)
  15. F&M racing
    Feb 26, 2006
    668
    Michigan
    JimF
    I decided to go the powdercoating route. The parts are in the shop now. Red wrinkle cam covers with black wrinkle belt covers. Thanks for the input!
  16. Air_Cooled_Nut
    Air_Cooled_Nut Formula Junior
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Based upon my personal experience with paint and powder coating engine parts, I'd go with powder coating. Much more durable! And nowadays they have a plethora of colors and "chromes" that rival paints.
  17. staatsof
    95,282
    Fuggetaboutitland
    Bob
    I would concour.
    I did a set of valve covers from my Maserati 2 years ago in powder wrinkle red and they looked great but it's a smaller wrinkle size. It's very tough but the VHT previously mentioned is also reasonably tough. With practice you can control the size of the wrinkles via amount of heat and thickness of coating. I suggest a self etching primer for much better adhesion. I've also had good luck with touch-ups using the VHT as long as the paint hasn't dis-colored significantly with age. You can apply a small area heavy coat over a gouge or scratch and it will almost dissapear.
    The real issue with the powder coating is making certain that the morons (they usually are) that do this absolutely do not blast the the interior portions. It has to be very well masked. My experience was that they didn't care because they don't think it's a potential issue. But the glass bead fragments can become imbedded in the aluminum and then only come back out with repeated heat cycles and not with thorough washings before assembly. You know what that means ... So if you see that familar bead blast look on the insides you know you're in trouble.
    The heat was an issue on my covers because they had SS baffles which were peened onto the tops of some cast interiors posts and one of them let go so I had to drill&tap the post.
    Have fun ...
    Bob S.
  18. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    #18 Brian Harper, Nov 20, 2007
    I painted mine exactly the same way. I have to be careful when using the final degreaser and get it unloaded before my wife finds out. Also notice the heater behind the cover in the wet shot.
    I polished the ribs and Ferrari script and then painted the cam covers. What was original? Painted all over, painted a different color or letters left bare aluminum?
  19. staatsof
    95,282
    Fuggetaboutitland
    Bob
    Doesn't everyone wash car parts in the dishwasher and bake-paint or heat-up parts in the oven? ;>)
  20. BigTex
    79,321
    Houston, Texas
    Bubba
    In my apartment, yes...in her house......no! LOL!
  21. F&M racing
    Feb 26, 2006
    668
    Michigan
    JimF
    Man if I'd did that my wife would call up the cement contractor and I'd be part of a driveway.
  22. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I do it so often that I don't even get comments anymore. Except when foraging in the freezer once in a while my wife mentions that we can have corn, peas or bearings. Also beware of having someone preheat the oven to 400*F while paint is curing at whatever the pilot light provides. Both the nasty smell and nasty looks tend to linger.
    She also tells people that I rebuilt a Mercedes engine on our first apartment's coffee table which is such a lie. It was just the head and even then a shop pressed in the guides. Sheeesh.
  23. staatsof
    95,282
    Fuggetaboutitland
    Bob
    Yeah I know what you mean. Sometimes they just can't help but exaggerate the facts. I did all of the measuring and weighing for my race engine on the dinning room table this
    spring-summer-fall because it was the only location with a big uncluttered workspace (except when I was there) and a great outdoor light source. I always managed to get every thing packed up into very tidy boxes that were stacked nicely in the living room before meals so what's big deal? Those large flat granite counter tops in the adjoining kitchen came in very handy at times as well.
    None the less, I got the "Gee, are we having pistons au gratin tonight honey?" type comments. And this was after I had sent the heads and block halves out for washing instead of using the dishwasher out of courtesy!
    Women ... ;>)
    P.S. I also store my touch-up paints and other temperature sensitve items in a small box at the back of the fridge.
    Bob S.
  24. staatsof
    95,282
    Fuggetaboutitland
    Bob
    Jim, It's all about proper training. You have to get them gradually used to the chemical smells. I now have my wife using brakecleen for heavy grease removal from clothes.
    Of course they're usually mine but occaisionally some of it creeps on to her clothing and the sh*t hits the fan. There are several cans stocked in the laundry room now.
    Bob S.
  25. F&M racing
    Feb 26, 2006
    668
    Michigan
    JimF
    Nope that won't work with me, see were Italian (old school) my wife was born there, our relatives are in the construction business ( cement ). Food only goes in the oven and dishes only in the dishwasher. Better not to take a chance! Luckily we don't have plastic on the living room furniture.
    Jim
