California Dash Top Panel Removal | FerrariChat
Discussion in 'California/Portofino/Roma' started by SoFLFerrari, Dec 30, 2017.
  1. SoFLFerrari
    SoFLFerrari Karting
    Apr 23, 2015
    202
    South FL
    I have a 2010 California and would like to remove the two top panels above the dash to be able to access and clean the stickies around the tach and speedometer.
    I'm able to remove the small top center panel but can't figure out how to remove the larger panel below it. I see two Allen Wrench screws on the far end, but is there anything else holding it in place that I need to look out for?
    I've attached an image of the panel I'd like to remove. Thanks in advance.
  2. robinb
    robinb Rookie
    Dec 20, 2013
    5
    Hi,
    I would be interested to know how you removed the small top center, is it possible without removing the larger panel?
  3. SoFLFerrari
    SoFLFerrari Karting
    Apr 23, 2015
    202
    South FL
    The small panel just pops out. Push it towards you and lift from the back.
    A Pasha likes this.
  4. robinb
    robinb Rookie
    Dec 20, 2013
    5
  5. Mike8Wang
    Mike8Wang Rookie
    Feb 12, 2019
    7
    orlando,fl
    Mike Wang
    Did it work for you? I have 2015 Cali T and trying to pop that off too to realign the leather that's slightly stretched out of place. I found two screws just below and they seem to hold the larger piece in place.
  6. JeremyE30
    JeremyE30 Karting
    Jun 12, 2013
    50
    GA
    Jeremy
    Not sure on the Cali T, but on my 13 Cali, the top peice pops off from the back and slides forward slightly to remove.
  7. fibreraid
    fibreraid Rookie
    Oct 24, 2017
    1
    Hi All, I too have the same issue where the leather has peeled back a bit. I removed the smaller top piece without any issues. I also removed the 2 allen screws that appear to be holding down the larger piece. But I still cannot seem to get the larger piece to come out. Any advice would be greatly appreciated!
  8. Leathertech
    Leathertech Rookie
    Jan 10, 2020
    1
    David
    To remove the binnacle you must remove the screws for the instrument cluster then there are 3 pins holding it down. Once you've done the two top Allen bolts and front cluster screws it pops off.
  9. wfw
    wfw Rookie
    Apr 22, 2017
    14
    Florida
    Bill
    I also wanted to clean off the sticky gunk on my dash assembly. After many, many, many searches, I found an amazing video showing exactly how to remove the complete instrument cluster. From there, I disassembled the instrument cluster into about six individual components. Then, using hand sanitizer and a couple of rolls of paper towels, I cleaned each component. I don't know if the forum allows typing the actual website. But the company is called SKF (super kilometer filter). If you take the instrument cluster apart, I think the speedometer lens is curved. So make sure you note if it is concave or convex facing outward. I believe this is to reduce glare. I did not pay attention to this and had to experiment under different lighting conditions to determine the best guess orientation (concave outward). Also, when disassembling the speedometer, be careful to collect at least four 1/2 inch long x 1/32 inch round rubber tube spacers that go between the lens and the plastic lens housing to prevent rattling. Also, pay close attention to the video removal sequence. I think the video shows the left side of the assembly is pulled up, then the right side. At any rate, follow the sequence. In the end, I was able to clean up everything, reinstall, and everything worked. Good luck!
    SoFLFerrari likes this.
  10. SoFLFerrari
    SoFLFerrari Karting
    Apr 23, 2015
    202
    South FL
    Very helpful. Thanks for the post.
  11. wfw
    wfw Rookie
    Apr 22, 2017
    14
    Florida
    Bill
    Happy to help. If you have any questions when you get into your cluster components, let me know.
  12. alex
    alex Formula Junior
    674
    Crystal Lake, Illinois
    Alex
    Stickies and peeling leather seem to be the hallmarks of Ferraris! Thanks for the helpful info.
  13. James cln
    James cln Formula Junior
    Dec 20, 2015
    283
    San Antonio
    James cline
    Hi Mr Leather Tech On my 2015 Cali T , trying to figure out how to remove top leather cover over instrument panel. I found 2 screws at top above instruments but not sure how to remove it from there. Are there more screws I must remove ? Thanks so much in advance for your help .
  14. James cln
    Dec 20, 2015
    283
    San Antonio
    James cline
  15. James cln
    Dec 20, 2015
    283
    San Antonio
    James cline
    Hi , still not sure how to remove top cluster cover?? Yep found the two screws in top front and after removing them cover doesn’t come off. Are there more I must remove ??
  16. Andrew Pour
    Andrew Pour Karting
    Oct 7, 2019
    63
    I am wondering the answer to this as well. I see a screw below each of the leather pieces. Is it a slide and pull thing to get out or are there other screws?
  17. Andrew Pour
    Andrew Pour Karting
    Oct 7, 2019
    63
    James, did you try sliding and pulling out after you unbolted the screws? I am thinking maybe it is similar to the prior Cali, where some pieces have to be unbolted then pulled or pushed.
  18. James cln
    Dec 20, 2015
    283
    San Antonio
    James cline
    Yep just have to pull up really hard - there are snap fittings . I carefully used a plastic trim wedge and they snapped open . Thanks
  19. SLViper1
    SLViper1 Formula Junior
    Mar 25, 2014
    742
    Nashville/Destin
    Steve
    Any Pics of the Cali T cover to show the clip locations? Are the only screws the two small ones above the gauges?
    Thanks in advance
  20. Bill Phillips
    Bill Phillips Formula Junior
    478
    New Orleans
    Bill
    I’m also trying to remove the instrument cluster on my ‘13 Cali and I’ve read this post and watched the video carefully. I’ve gotten the top binnacle off and removed the two screws at the bottom of the gauges then pried up the steering column upper clamshell but the unit will not come out. I’ve pulled and pried but no luck. It’s somewhat loose at the front - I can rock it slightly but it sure feels like it’s still anchored at the back. I’ve seen the video and done everything the same way, but their unit (instruments and attached upper dash clam shell) just pops right out.
    Has anyone removed the entire instrument cluster? Thanks.
  21. Bill Phillips
    478
    New Orleans
    Bill
    I finally got it after finding a picture of the underside of the dash cover so I could see what was holding it in place. There are two metal pins at the 10:30 and 1:30 position of the rear of the cover (the part closest to the windshield when it’s installed) as shown in the photo, and they are the devil to pry up. Do one at a time with both hands, sliding your fingers under the edge and pull up as hard as you can. The dash cover is attached to the instrument cluster with the two black screws near the pins, so the only reason to remove the dash panel is to remove the instrument cluster.
  22. mdooley
    mdooley Rookie
    Apr 11, 2021
    1
    Mark Dooley
    What was the website where you found this instructional video?
  23. Bill Phillips
    478
    New Orleans
    Bill
    #23 Bill Phillips, Apr 11, 2021
    DISCLAIMER: It’s a video about how to block your odometer, which obviously is immoral if not illegal, so don’t do it.
    But it’s also a very good tutorial on removing the instrument cluster. I’ll tell you from experience that when you remove the two screws underneath the instruments, use a magnetic tool or they will fall into a difficult place to retrieve them. It’s also impossible to put them back in unless you can keep them attached to the tool while you insert them. They are set back about four inches from the face of the dash.
    Also be aware that the instrument cluster itself is bolted to the turtle back section of the dash. So you can remove the binnacle (the smaller section on top) by itself, but the larger base section can only be removed by taking the instrument cluster with it. They can then be separated. See the picture in my post above with the whole thing sitting in my lap upside down.
    sherrillt and whatheheck like this.
