California Clutch | FerrariChat
California Clutch
Discussion in 'California/Portofino/Roma' started by Frank_N, May 12, 2020.
  1. Frank_N
    Frank_N Rookie
    Apr 20, 2020
    13
    Frank
    Hello,
    Today i went at my trusted technician and we made a diagnosis on my 2011 California, i've got the code 270A0501... someone knows what could be?
    A gearbox issue today (sometimes shifting it misses to engage the gear then a second later it engages) also turned on the light of the engine and limited it to 3500RPMs, when we made the diagnosis in the engine module, the only error showed says "Check Clutch Status" and in the clutch the error is 270A0501, do you think it could be the Clutch Speed Sensor?
    Thank you so much
    Frank
  2. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    25,895
    DFW, Texas
    Tom C
    Hi Frank...Sorry to hear this. I do not recognize those codes. If you go to Google and search the following...
    site:ferrarichat.com MDEL california speed sensor
    you will find several threads by user @MDEL, which detail DCT failure cases from about 3 or 4 years ago.
    Good luck w/ your Cali...T
  3. Frank_N
    Frank_N Rookie
    Apr 20, 2020
    13
    Frank
    Thank you!
    It seems P0501 as error, Clutch Speed Sensor.
    What do you guys think?
  4. tomc
    Apr 13, 2014
    25,895
    DFW, Texas
    Tom C
    I fear you have the dreaded DCT sensor issue. How many miles on your Cali?
    T
  5. Frank_N
    Frank_N Rookie
    Apr 20, 2020
    13
    Frank
    35k miles, from few searches I need to buy the level 3 clutch speed sensor kit, do you agree?
    thanks
  6. tomc
    Apr 13, 2014
    25,895
    DFW, Texas
    Tom C
    ^Not knowledgable enough to say...T
  7. GNU
    GNU Rookie
    Sep 28, 2014
    27
    Has it been sitting for a while?
    I would consider letting a Ferrari shop run through the clutch calibration process before looking into opening things up.
    tomc likes this.
