Cali T Binnacle removal | FerrariChat
Discussion in 'California/Portofino/Roma' started by James cln, Jun 17, 2020.
  1. James cln
    James cln Formula Junior
    Dec 20, 2015
    283
    San Antonio
    James cline
    So does ANYONE know how to remove this thing ?? Have asked repeatedly to no avail. Some folks have told me to pull / push some how to get this piece off . I have pulled as much as I can and seems to be fastened in the back somehow - has anyone removed one of these?? Any help would be really appreciated. james in Tx
  2. Stercrazy
    Stercrazy Karting
    Sep 29, 2017
    115
    NC and FL
    Paul Winchester
    Image Unavailable, Please Login On the center piece, over the tach, you pull up at the end furthest from the steering wheel, that will then allow you to pull the piece toward you to separate it from the gauge housing. I have not tried this on the piece over the speedometer. May be the same.
  3. James cln
    Dec 20, 2015
    283
    San Antonio
    James cline
    Hi Mr Ster , Man I pulled and pulled but it wouldn’t let go ! Thanks so much , james
  4. Andrew Pour
    Andrew Pour Karting
    Oct 7, 2019
    63
    Were you able to remove that piece? I am wanting to take that and the reciprocal piece on the left side off. After unscrewing the left bolt, I couldn't take the piece out. Was worried I would damage it. I was going to unscrew the bolt on the right side like yours but didn't since I had no luck on the left.
  5. lotusstv
    lotusstv Rookie
    Jun 9, 2019
    33
    Parkland FL
    Steve Stenglein
    Subscribing, need to remove mine as well. Center piece on top is sticky!
  6. James cln
    Dec 20, 2015
    283
    San Antonio
    James cline
    Hi Andrew once you undo the screws under the bezel - then push it ( the middle plastic bezel) back a little so it clears the speedometer housing and slide it out. Then what I did was used some plastic wedges like you use on upholstery and wedged them under one side at a time on the left and right leather covered pieces. They snap in at the front there is a snap male piece going down into a snap fitting and another at back . If you use edge you can find where it is - takes some force to snap it apart but it will release . Not an easy thing to do til you figure it out but it will come . Wish you great success - let me know if I can help more, james in San Antonio :))
  7. Andrew Pour
    Andrew Pour Karting
    Oct 7, 2019
    63
    Thanks James. Confirming these instructions are for the Cali T correct? I ask because when you say push the middle plastic bezel, I do not believe I have this. I have a centerpiece which shows my rpm. And on the each side I have the leather pieces which I am trying to remove.
    Kevin GILLISPIE likes this.
  8. Defmeister
    Defmeister Karting
    Aug 3, 2019
    51
    Scotland
    Gordon
    Check youtube. The piece over your tachometer comes off without tools. The part you’re trying to get off is attached to the instrument cluster with screws from underneath. You’ll need to remove the full cluster to get it off.
    Def.
    PS. Sent you a PM with video link
  9. James cln
    Dec 20, 2015
    283
    San Antonio
    James cline
    Yep I should have said tach housing .To get the leather pieces on each side off , just have to use the wedge and they snap out, on the Cali T :))
    whatheheck likes this.
  10. Defmeister
    Defmeister Karting
    Aug 3, 2019
    51
    Scotland
    Gordon
    Cali T, D'Oh, I should have read the question properly. My reply refers to the original Cali. The clusters look similar though. Cheers anyway.
    Sent from my SM-G960F using FerrariChat.com mobile app
  11. Andrew Pour
    Andrew Pour Karting
    Oct 7, 2019
    63
    Awesome, thank you sir!
    Anyone know of a leather glue I can use? Need to rebind a small part of the leather on those removable pieces. I was thinking of a cement type glue.
  12. jopke
    jopke Rookie
    Aug 18, 2014
    43
    I have used Barge contact cement on leather and it worked great. It wasn’t an automotive application though.
  13. SLViper1
    SLViper1 Formula Junior
    Mar 25, 2014
    744
    Nashville/Destin
    Steve
    To be Clear, on 2015 Cali T, to remove the L & R leather portion of the Instrument cluster covers,
    1. Remove screw on front underside
    2. Pry off the individual leather covered dash pieces, without removing the center tach cover?
  14. James cln
    Dec 20, 2015
    283
    San Antonio
    James cline
    Naw , you should remove tach cover . It just sort of slides out . Push back on it toward windshield to get it free from front of tach then wiggle around and it will come off - hope this helps. James in San Antonio Tx
  15. James cln
    Dec 20, 2015
    283
    San Antonio
    James cline
    I have used just regular contact cement that comes in a small bottle with brush in cap from Lowe’s on leather On other cars . Just apply light coating on both sides press together - will never come apart! :) james in San Antonio Tx
    Andrew Pour likes this.
  16. lotusstv
    lotusstv Rookie
    Jun 9, 2019
    33
    Parkland FL
    Steve Stenglein
    Hi all,
    I am attempting to remove the gauge cluster on my 2015 California T, the black framework is sticky and I also want to remove the black piece that is over the tach. To get the tach cover out do I need to remove the side leather pieces first? Just trying to get the sequence in order so I don’t break anything!
    Also prior posts refer to a wedge, do they mean plastic pry tool?
    Thanks in advance
    Steve
  17. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    The left and right leather covers on my 2016 Cali T have shrunk on the edges so I need to remove mine soon to get them recovered with a new leather piece.
    I found this video on the internet for a Cali, not Cali T but Im thinking it should be the same approach or similar. Hoping someone that has done it can chime in on proper removal too Image Unavailable, Please Login Image Unavailable, Please Login .
  18. Bill Phillips
    Bill Phillips Formula Junior
    Nov 4, 2019
    478
    New Orleans
    Bill
    I’ve done it on a ‘13 Cali and it looks to be the same set-up. There are two pointed metal prongs going straight down into a metal receptacle at the 10:30 and 1:30 positions closest to the windshield. Getting leverage is the problem, you have to work your fingers under the edge and pull up hard, and I mean very hard. I had to use both hands on each side, one at a time.
  19. Bill Phillips
    Nov 4, 2019
    478
    New Orleans
    Bill
    Sorry, that describes the larger turtle-back removal, the piece under the binnacle. To remove the binnacle you pull up at the back edge (closest to the windshield) then slide it toward you. You still have to pull hard, but not nearly as hard as on the lower section.
  20. Bill Phillips
    Nov 4, 2019
    478
    New Orleans
    Bill
    I did this repair recently to the cowling over the instrument cluster, the glue I used is in the last photo. It was recommended as the best in a consumer test I read.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  21. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Bill Phillips likes this.
  22. Bill Phillips
    Nov 4, 2019
    478
    New Orleans
    Bill
    Thanks, it’s a ‘13 Cali-30
