355 - CA smog issue with cats or is it? | FerrariChat
355 CA smog issue with cats or is it?
Discussion in '348/355' started by diviter, Feb 10, 2019.
  1. diviter
    diviter Rookie
    Apr 2, 2009
    16
    I am reaching out to the community in the hopes that someone else has had the same issues and found a solution.
    I recently purchased a '97 355 with a well documented service history. I drove the car home over 70 miles and all was good (no CEL).
    In July 2018 the cats were changed by the previous owner and the car passed smog. When I purchased the car it had to be tested again because more than 90 days passed. The car passed the sniffer but the ECU had codes so it FAILED. I took it to a local mechanic that works on Ferraris and he checked the codes which showed catalytic failure on both banks. Since the emissions were OK we decided to reset the codes and try to drive the cycle to clear the ECU.
    I drove about 30-40 miles and then the CEL came on. We installed extenders to the oxygen sensors and tried again but the CEL came on again. We changed the cats and the CEL came on again. Previously there were numerous pending codes but now just the catalytic is failing on both banks. No oxygen sensor codes now.
    We are unsure what to do next. The mechanic is a bit perplexed as both banks always seem to fail at the same time. Is there a bigger problem?
    Thank you in advance for taking the time to read this and I hope that someone else has had a similar issue and found a solution.
  2. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
  3. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    perhaps the actual o2 sensors themselves have an issue.
  4. bcar1
    bcar1 Karting
    220
    NYC/NJ
    Bob
    What is the exact codes now & what was pending before? Any sdl? I was having a similiar issue from a miswired tcu that drove me nuts. I never got that far but replacement pre/post 02 sensors are cheap and worth a shot.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    exact codes would help.
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,656
    CT
    John Kreskovsky
    If it's a cat efficiency code 99/100 time it the post cat O2 sensor. Any decent mechanic will tell you that.
  7. Ferrarium
    5,631
    Central NJ
    Eric
    Its a bit worrisome that the mechanic scratches his head on this to be honest....
  8. yelcab
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    Can you tell us more data?
    What brand cat converters?
    What exact error codes?
    What kind of extenders and where ?
    In my experience with many 355s, nothing beats a set of working factory cats for passing Smog.
    taz355 likes this.
  9. Rifledriver
    34,021
    Austin TX
    Exactly. If you have to search the internet for a solution to this problem you are bringing the car to the wrong guy.
    taz355 likes this.
