By pass Ignition Switch | FerrariChat
Discussion in '308/328' started by Falcon, May 13, 2017.
  1. Falcon
    Falcon Formula 3
    Aug 19, 2008
    1,304
    New England Region
    Falcon
    #1 Falcon, May 13, 2017
    I've been chasing an intermittent problem. My car's starter will not consistently engage when the key is turned. I've cleaned all the connections and the grounds. I even changed the starter. I am now focused on the ignition switch. I would like to bypass it. I know that the white wire is going to the starter. I can't tell from the wiring diagram what wire I need to connect to the white wire to engage the starter. Does anyone know how to hot wire a 1986 328?
  2. Archer911
    Archer911 Formula Junior
    Sep 26, 2016
    907
    New England
    Tim
    I have a 308 so things might not be the same but when I was trouble shooting this past winter I remember that the wires had different gauges so on a blind guess the heavier wires would handle the starter motor current. Hope that clue helps.
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    Dean,
    There should be 2 wires to the started solenoid. As Tim said, the heavy one is the power to the starter. That wire is connected directly to the battery. The lighter weight wire supplies current to the solenoid when the ignition switch is turned. It engages the starter gear and closes the circuit supplying current to the starter motor.
    To jump it, disconnect the lighter wire and tape over the end so as to insulate it. Then you can rig a remote starter by running a wire from the battery through a starter button an then to the solenoid. Press the button and it will activate the starter to crank the engine. To start engine the ignition switch must be in the run position.
    Make sure you disconnect the battery before messing with this.
  4. Falcon
    Falcon Formula 3
    Aug 19, 2008
    1,304
    New England Region
    Falcon
    Thank you for the responses. I think the easy way to do this is to make the connection when the key is in position III, the start position. I need to know what wires are connected in position III, then remove the wires and make a direct connection. I know the wire to the starter is the white one. Which wire closes the start circuit?
  5. johnk...
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    The white wire is going from the ig switch to starter. Connecting the white wire to any 12V source will by pass the switch. For the 308 the red wire connected to the ig switch is 12V, directly from the battery. So at the ig switch, jumping red to white should engage the starter if it's the same as the 308. Red should also be a heavier gage wire than white.
    If you disconnect red form the ig switch you will also cut power to all other switch controlled functions.
  6. Sigmacars
    Sigmacars Formula 3
    1,187
    I have a used egnition switch out of a 1988 328 working ok let me know if you are interr.
    PM me
  7. Falcon
    Falcon Formula 3
    Aug 19, 2008
    1,304
    New England Region
    Falcon
    So I need to y off the red wire or find a different source for 12v.
  8. johnk...
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    That's the way I see it.
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    Assumi g this is the same set up as the 87 mondial, there is a kit to sort this out. Consists of a relay you mount near the starter motor and feed this 12 volts from a good source. Use the original 12 volt signal wire to trigger the relay and use its out put to activate the starter motor solenoid.
  10. GordonC
    GordonC F1 Rookie
    4,152
    Calgary, AB, Canada
    Gordon
    I was going to suggest this as well - hot starting problems are more common in the Mondial, and the known good solution is to install a Bosch relay kit that runs around $25. Instead of bypassing the ignition switch, it's retained and connected to the relay, which sends the high current direct to the starter, you don't want it running through a starter button!
    Here you go - a quick search in the Mondial section for keywords "starter relay kit" found this thread with photos, instructions, and successful results: http://www.ferrarichat.com/forum/mondial/483899-starter-relay-kit-arrived.html?highlight=mondial+starter+relay+kit
    The kit is the Bosch WR1 part number - here it is on Amazon for $25: https://www.amazon.com/Bosch-WR1-Starter-Relay/dp/B001COAX78/ref=sr_1_2?ie=UTF8&qid=1494704693&sr=8-2&keywords=bosch+wr1+relay+kit
  11. Falcon
    Falcon Formula 3
    Aug 19, 2008
    1,304
    New England Region
    Falcon
    I had actually considered doing this. I didn't know there was a kit, thanks for the link. I may buy one to have on hand. I've concluded that I want to locate the problem and fit it. I think the switch is faulty. The factory system works. I would prefer to fix what's wrong instead of doing a work around solution. If I can't sort it out a may revert to the relay.
  12. Falcon
    Falcon Formula 3
    Aug 19, 2008
    1,304
    New England Region
    Falcon
    I put in a new ignition switch. So far it has started every time, even when hot. Maybe it's fixed.
