bump start/pop clutch with a dead battery | FerrariChat
Discussion in 'General Automotive Discussion' started by ClydeM, Sep 1, 2017.
  1. ClydeM
    ClydeM F1 World Champ
    10,462
    Wayne, NJ
    Clyde E. McMurdy
    I'm old skool. Battery dead? no problem. turn the key to on, put her in first, press the clutch, push her as fast as you can, then pop the clutch.
    zoom-zoom.
    But my 2015 Mazda 3 battery went dead last night. It has a push start button. not even an LED in the dash when you push it in. Dead-dead.
    So how to bump start it? can you?
    I did jump start it with cables, but if I was stranded...how to do it?
  2. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    15,476
    Dumpster Fire #31
    SMG
    I'm not sure bump starting works on new vehicles anymore. Another thing to note is that jump starting or bump starting a dead battery vehicle is profoundly hard on the alternator. The current draw is very large and for older say pre-90's vehicles while it's tough on them it's not being monitored by any ECU, today's new management system would most likely prevent any starting on a dead or low battery due to the high current draw the alternator would experience. My wife's '14 VW diesel had a dying battery, the vehicle refused to start unless the battery was within spec, new battery resolved the issue. Or it could be like BMW where it requires a bloody tow to the dealer to re-sync the alarm system once the battery dies... freaking technology.
    The more expensive aftermarket ECU's I use for the race vehicles now incorporate remote and push button start. The ECU monitors batt voltage and current draw, I can assign a 'chart' that the ECU's uses for look up values and will deny starting if it's too low, by either cutting fuel or ignition or even the starter relay if so wired.
  3. sca037
    sca037 Formula Junior
    Mar 16, 2009
    520
    Northville, MI
    Brian
    With all the electronics in cars these days, bump starting from a dead battery would be like using a defibrillator the restart a heart with no brain function (probably pointless ;-)
  4. MalcQV
    MalcQV F1 Rookie
    Oct 11, 2004
    3,292
    Manchester, UK
    Malc Holden
    Push button start I think you need to push the button once and push the car.. No personal experience of any though.
    Flapping paddles and you're bust of course.
    However keyless entry I'm not sure.
  5. Nativetroy
    Nativetroy F1 Veteran
    Nov 29, 2010
    5,941
    central fl
    Troy
    With a push button start you should be able to turn the car on and bump it like it had a key.
