Broken light switch and a frozen hub (85 Testarossa) | FerrariChat
Discussion in 'Boxers/TR/M' started by teveo, Sep 30, 2018.
  1. teveo
    teveo Formula Junior
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    I could usually jog the light stalk/switch to turn on and off light but it just gave in now and is stuck in parking light whatever is turned or twisted.
    According to information in the cross-ref thread I am ordering a Lancia part (176314180) and hope to fit it. My plan is to identify, cur and transfer the Ferrari contacts as they are quite different from what I see on Lancia stalks.
    First problem was a frozen steering wheel hub, in short I tried oil, cold shock, heat but whatever I did it was stuck. I used a puller but the force destroyed the hub to a point where I may be able to straighten the top cage.
    I have found a few vendors that sell the hub but does anyone have a link or info about potential "cross references" on the hub? The hub is not splined, it is a single "slot" that is slide onto. I will be using some antifreeze oil-grease when I mount it the next time.
    The only special tool needed was the ring nut socket at 28 mm, I got it from a UK specialist. I had to use a "strongarm" to release the nut it was mounted with a lot of torque.
    Below is a photo summary showing the white rotating spindle that was split.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. teveo
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    Warlock likes this.
  3. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    Eager to see how this goes. At about $199 that Lancia stalk is a great value, hope its straight forward.
    Melvok likes this.
  4. WestCoasta
    WestCoasta Karting
    220
    california
    I’m several months into shopping for a TR and this post just made pucker haha. Part of the game tho.... gotta love it!:). Good luck with the fix
  5. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    626
    Massachusetts
    Joe
    Verell at unobtainiumsupply.com will rebuild your Testarosa switch.
  6. teveo
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    Thanks but I'll try to convert the Lancia piece, its already ordered.
    Now on the hub, there is bad news. I've gotten 3 responses so far about the part no longer available.
    Somewhat "good news" , Luisi still make the adapter for their steering wheels and it may be fine while searching for a salvaged hub. I'll order a Luisi one so that I can move the car around.
    https://www.volantiluisi.it/categoria-prodotto/mozzi/
    Melvok likes this.
  7. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    Contact GT Car Parts in Arizona. They have many TR's in inventory for used parts.
    Rose Red likes this.
  8. teveo
    Oct 1, 2005
    403
    Norway
    Trond Vidar
  9. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,245
    Mel
    Good work !
    The oem stalks seem to be $1500 or even more …. I have seen people paying that ….
    Natkingcolebasket69 likes this.
  10. teveo
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    Got the parts and tried to use the Lancia piece but after 2-3 hours trying all cabling combos I recon:
    • Lancia stalk has significantly less cables going to the loom
    • Lancia stalks wiring is of smaller diameter than the Testarosssa wiring
    • There is a difference in the mechanical part of the wiper switch(brass parts) and I could not get intermittent to work
    I ended up carefully drilling out the four brass "rivets" around headlamp "switch/housing" and swapping the lever w/cam and surrounding plastics over to the old "Ferrari stalk".
    Secured the housing with 3 small diameter bolts and nuts and a small self tapping screw for the last rivet since this one is kind of hidden inside the housing. Works like a charm.
    At approx $140 the small plastic cam is expensive ;) but at least the indicator is the same and perhaps quite a few parts from the wiper side also can be used in case something brakes.
    Over to the Luisi hub/boss. This piece is perfect fit, it even comes with new screws. The only challenge is the ring securing the horn button, you will have to work this one a little, I ended up modifying it slightly to make it work. This piece is a fine alternativ to the expensive / out of stock Momo piece if you ever need a new one.
    NEW LANCIA STALK
    IDENTICAL IN SIZE AND NUMBERING, LANCIA IN THE BOTTOM
    MUCH LESS WIRING IN LANCIA STALK AND SMALLER DIAMETER ... HMM
    LUISI HUB - BOSS - THIS ONE IS WELL WORTH THE 45-50 EUROS
    BRASS RING FOR HORN IS INTEGRATED
    HILL ENGINEERING SOCKET - 28 MM (FOR 85 TESTAROSSA), GBP 45 AND A NECCESSARY TOOL
    LUISI HUB BLEND IN AND LOOKS ORIGINAL (BLACK SHRINK PAINT)
  11. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    I posted this same post last year and did the same.
    Eventually the issue will be that the plastic will break again so i ended up sending it to oddparts in California for restorarion.
  12. teveo
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    The plastic part may be somewhat better "formulated" now but yes I, it's bound to break again in 2045! ;)
  13. Elberoth
    Elberoth Karting
    Feb 12, 2022
    114
    Warsaw, Poland
    Adam
    Did you manage to make it work? I bought the Lancia Delta Integrale Evo stack, but the very white part (gear) that breaks is slightly different, and as a result, after swapping the parts the lights do not work as intended (parking lights are ON in the 0 position etc).
  14. teveo
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    Yes, mine is working as expected after the "transplantation".
  15. jmaienza
    Jan 8, 2009
    626
    Massachusetts
    Joe
    Verell at Unobtainiumsupply.com can mold a new cam and rebuild the rest of the switch if necessary.
    testarossaeddie79 likes this.
  16. Elberoth
    Elberoth Karting
    Feb 12, 2022
    114
    Warsaw, Poland
    Adam
    OK, it seems I have bought the wrong light switch. The part differs for Lacia Delta Integrale and Integrale Evo models. You need one for the non-Evo (regular) Integrale - part # 176314180.
    The part # given in this thread was correct - it was a misunderstanding in the communiction with the shop (a Lancia specialist).
  17. testarossaeddie79
    Jun 19, 2022
    6
    Germany
    Eduard Pogea
    I repaired mine (headlight switch) and showcased this in our new YouTube video just because of you guys. Thank you so much!!! Www.Youtube.Com/c/pogearacingtv
  18. Elberoth
    Elberoth Karting
    Feb 12, 2022
    114
    Warsaw, Poland
    Adam
    How is the EZ-Electric Powersteering working?
    At what speed does it switch off ? 40km/h ?
    Does it fade away after a certain speed or is it simple on/off after a certain speed ?
  19. testarossaeddie79
    Jun 19, 2022
    6
    Germany
    Eduard Pogea
    I will have to subtitle all my Ferrari Freitag videos. We are super busy at the moment and YouTube is a pain in the ass time consuming task. I apologize for this delay and I do my best with the translations. We are at Episode 7 now and both cars are at different locations for prototyping and development.
    The EZ powersteering can be programmed to your needs. To be honest, I would never change anything as it is right now. It is purely fantastic. It goes away at 41km/h slowly and is gone at 60 km/h. You can ask them to program what ever you want, but they did so much R&D before that they found an incredible solution. My both Testarossas have them installed and I can not tell you how much more fun it is!
    Elberoth likes this.
  20. testarossaeddie79
    Jun 19, 2022
    6
    Germany
    Eduard Pogea
  21. Elberoth
    Elberoth Karting
    Feb 12, 2022
    114
    Warsaw, Poland
    Adam
    Thanks!
    I have orderd one via Wolfgang Hüttner.
    The steering effort takes away the joy of running this car around town for me .
  22. lagunacc
    lagunacc F1 Rookie
    4,015
    #23 lagunacc, Mar 21, 2025
    Another Lancia part number for the stalk is 176286980
    Cables connections look more like the Ferrari part.
