Brake resovoir hose “sweating” ? | FerrariChat
Discussion in '206/246' started by Skippr1999, Apr 28, 2018.
  1. Skippr1999
    Skippr1999 F1 Rookie
    4,475
  2. racerboy9
    racerboy9 F1 Rookie
    2,632
  3. Skippr1999
    4,475
    Thanks I’ll check it out. Looks to be either 6mm or 8mm
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,342
    Frederick, Maryland
    Brian Brown
    The brake hose has to be made of out EPDM material, which is compatible with brake fluid. If fuel hose is used (which is made from Buna-N) for a brake fluid reservoir application, then it will sweat brake fluid over time. The seals inside the braking system are also made from EPDM rubber. You can purchase EPDM hose in various sizes from Mc-Master Carr.
  5. Skippr1999
    4,475
    Thanks Brian. I ordered some from Superformance. Hopefully it’s correct.
