430 - Brake Recall | FerrariChat
430 Brake Recall
Discussion in '360/430' started by AandSC, Aug 5, 2022.
  1. AandSC
    AandSC Formula Junior
    916
    Jax, FL
    Allen
    https://www.motor1.com/news/602537/ferrari-recalls-cars-brake-failure/
    Looks as if our F430s will have to go to the dealer for the brake recall, which is really just a new brake cap.
    My nearest dealer is three hours away, which isn’t helpful, but there are worst things than spending six hours in a Ferrari.
    Surprised 430s are part of this recall as I haven’t seen any brake issues on our cars.
    TommyTheV, Qavion and colorfull like this.
  2. colorfull
    colorfull Formula 3
    2,280
    Franklin Park, New Jersey
    John Napoli
  3. mjposner
    mjposner Karting
    Dec 1, 2021
    197
    Florida
    Michael J Posner
  4. colorfull
    colorfull Formula 3
    2,280
    John Napoli
    It did say notification goes out in Sep, maybe it's not posted yet? Dunno
  5. mjposner
    mjposner Karting
    Dec 1, 2021
    197
    Florida
    Michael J Posner
    I also put my vin in the Ferrari Website, still nothing.
  6. tazandjan
    39,007
    Here is the actual notice. Owner notifications do not go out until late September.
    AandSC likes this.
  7. mike_747
    mike_747 Formula Junior
    Dec 15, 2008
    794
    Seattle
    Note: the recall said "certain F430s". If you had a defective brake reservoir cap that wasn't venting, you or your service provider would have noticed by now I would think.
    JSP likes this.
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    They have been looking at 458+488 previously and notices issued, this must be a full follow on
  9. mike_747
    Dec 15, 2008
    794
    Seattle
    Better to be overly cautious than face possible litigation....
  10. colorfull
    colorfull Formula 3
    2,280
    John Napoli
    Stupid question, does that mean they all use the same cap? Or they all have the same problem?
  11. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,751
    England
    Mark
    The cap on my manual was identical to that on my F1, so I assume it's a common part.
    colorfull likes this.
  12. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    379
    NC
    Good thing I have a F430 and not a 430 :D
  13. f355spider
    f355spider F1 World Champ
    18,026
  14. f355spider
    18,026
    Description of Remedy : Description of Remedy Program :
    The repair consists of replacing the brake fluid reservoir cap and updating the software in the affected vehicles to provide for a different warning message if the vehicle should lose sufficient brake fluid. Ferrari will send a notice letter to all affected vehicle owners to warn them of this issue, and instruct them 1) to contact an authorized Ferrari dealer to schedule the free recall repair, and 2) that in the meantime, remind them that if the “low Brake Fluid” warning message appears on the vehicle dashboard, the driver should pull off the road as soon as it is safe to do so, and then contact Ferrari Roadside Assistance and get towed to the nearest authorized Ferrari dealer.
    How Remedy Component Differs from Recalled Component :
    The venting of the brake fluid reservoir cap has been modified.
    Identify How/When Recall Condition was Corrected in Production :
    All vehicles currently in production will be fitted with a different brake fluid reservoir cap and new upgraded software.
  15. Flea7
    Flea7 Formula 3
    1,962
    PNW
    SKIM
    Not taking my cars in unless there is an issue.
    Purch23 likes this.
  16. Qavion
    Qavion F1 World Champ
    13,803
    Ian Riddell
    I wonder how the displays will be affected. I see there is already a warning for worn brake pads and low fluid on the speedometer.
    The wiring on the F430 won't allow differentiation between brake pad wear and low brake fluid, so I assume there will be a generic warning on the tachometer display on the updated system (perhaps with an aural warning, if the software allows it).
  17. mjposner
    mjposner Karting
    Dec 1, 2021
    197
    Florida
    Michael J Posner
    Qavion likes this.
  18. LorenzoR
    LorenzoR F1 Rookie
    I'm not near my car that I can look so is there a weep hole or vent in the cap?
  19. tstuli
    Jun 12, 2018
    379
    NC
    #19 tstuli, Aug 6, 2022
    No there isn’t and shouldn’t be. You don’t want (moist) air getting in. I think thats what this recall is about - a new cap with a diaphragm so that as the level in the reservoir goes down (wearing pads), you don’t create a vacuum. The diaphragm could allow that to happen without introducing outside air.
    one4torque and LorenzoR like this.
  20. LorenzoR
    LorenzoR F1 Rookie
    oh ok makes sense.
  21. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I believe they will get the same replacement cap as on the 458 recall. Top one in black.
    AandSC and Qavion like this.
  22. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    I may just order the new cap and not bother bring in car ..is that stupid of me ?
  23. Qavion
    13,803
    Ian Riddell
    1) Can you buy the cap on its own?
    2) Don't you want the software update or will you just wait until an opportunity arises to go a dealer service centre?
  24. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    1,- have to check ..not sure if possible
    2 - don't have any rush fir the software update ..
  25. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,378
    Santa Clarita, CA
    Anyone else concerned what the software update will change or screw up? I am.
    DOWORKFCAR and Purch23 like this.
