Brake Pad replacement at 15k KM! | FerrariChat
Discussion in 'California/Portofino/Roma' started by aazizkhalid, Feb 5, 2013.
  1. aazizkhalid
    aazizkhalid Karting
    Aug 4, 2012
    72
    DUBAI UAE
    Just put my car in for a brakepad replacement, apparently all worn out... did any of you had this issue soo early?
    I dont track the car, but do drive it pretty aggressively and very regularly..
    fyi the car is the new cali 30 about 8mths old now..
  2. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,807
    How many miles do you have?
    My brakes are still okay and I have 52,000 miles.
    I have heard that certain cleaning product may be bad for the carbon ceramic rotos and pads.
    Are the pads expensive?
    DO your rotors need to be replaced too?
  3. Scude
    Scude Formula Junior
    Nov 7, 2010
    616
    Southern California
    Scuderia Ferrari
    My guess is OP doesnt have CCB?
  4. deppi0
    deppi0 Formula 3
    Jun 30, 2010
    1,246
    London, UK
    Edmondo
    He has about 15,000km which is less than 10,000 miles....Something must be wrong if he doesn't track it unless his aggressive driving style is seriously aggressive ;-)
  5. YAMVS6
    YAMVS6 Karting
    Jan 26, 2011
    138
    ohio
    front pads are about 1400$
  6. aazizkhalid
    aazizkhalid Karting
    Aug 4, 2012
    72
    DUBAI UAE
    USD5800 to replace all 4 (this is dubai so must have a big premium)!! including parts/labor
    The dealer commented that he has never seen a california before that needed brake pads replaced at 15,000km....
    been trying to break speed barriers in this car a bit much and listen to the downshifts way too often... price paid!
  7. Webber45
    Webber45 Karting
    Oct 2, 2011
    217
    Bavaria / Germany
    You should have the 7 years service included. So, from my understanding, they are just allowed to invoice the material!
    The material can't be 5.800 US$.
  8. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Rear pads are around $1800 USD at Ricambi America, but I assume should be included in the maintenance package for California 30s.
    I seem to recall reading that the ASR uses the brakes, especially the rear ones, as part of the control over the car when cornering fast. This effect is most pronounced in Comfort mode, where the system intervenes more often and earlier, so if you drive aggressively around a lot of corners in that mode, the brakes may wear faster than "normal". Perhaps this is what happened to the OP. I know my Jag XFR has a similar system (complete with e-diff!), and people have reported similar fast rear brake wear on their cars (some less than 10k miles - I got around 18k miles out of mine, but I use Dynamic Mode whenever taking twisty roads, and probably more often than most drivers).
    This is where I wish there were a separate shock setting on our cars, because there are times when I would prefer a comfort setting for bad roads, but nonetheless want sport mode level (late, less often) traction intervention. If you are an aggressive driver, you might consider turning the mannetino to Sport as your default mode, but the more aggressive throttle response in that mode is a bit harder to modulate in heavy traffic.
    All this said, 15k KM seems really low miles to have worn out the rear pads. I'd have them checked thoroughly to see if they are sticking. All Californias have CCBs, don't they?
  9. RickLederman
    RickLederman F1 Rookie
    2,836
    Swanton Ohio
    Rick Lederman
    Two days on the Mid-Ohio race track and my 2010 California ate 1/2 of the brake life. I changed them at 21,000 miles (32,000 k) as I remember. I looked at the pads before I did the track thing then looked again when I got home, wow what a difference! $3,000 for a full set of pads all the way around + $400 labor. And I got 10% discount since I am retired military.
    So if you are REALLY having FUN driving your Cali I would expect them to last as long as you said.
    Now, my FF info says the FF brakes should last the life of the car under normal use :D we will see about that!
    Rick
  10. hotbmwm3
    hotbmwm3 Formula Junior
    Jan 11, 2006
    554
    Melbourne and London
    Owner -09 California
    When I was at college I used to go on track days in my crappy car
    Before a track day I bought new front brake pads
    No need to replace the drum brakes at the rear :)
    I bought the cheapest pads so could find as a struggling student
    I went through about 4 or 5 hours of track driving
    And I heard a scraping metallic noise under braking
    Sent to the pits, and the brake pads were touching metal on the discs because there was no friction material left :(
    Moral of Story, don't buy the cheapest pads because I had to stop driving and go home early
    I expect replacing the discs on a Cali would be $10-20k
    Anyone know how much the retail price for the carbon discs?
  11. tazandjan
    39,016
    Stability control uses ABS on all four wheels and can drastically shorten pad life, but 15K kms seems a bit excessive. Brake pads are wear items and not covered by warranty or the 7 year maintenance plan, as far as I know.
  12. YAMVS6
    YAMVS6 Karting
    Jan 26, 2011
    138
    ohio
    close to 20k for 4 disc
  13. hotbmwm3
    Jan 11, 2006
    554
    I might press the brakes a bit softer now I know that
    I paid $10k for my BMW M5 :)
    So do I get the replacement discs or two BMW M5's for the same price?
  14. RickLederman
    2,836
    Swanton Ohio
    Rick Lederman
    California discs have a weight marked on them and after a certain computed amount of use the computer will say it is time to weigh them and if too light you replace the rotors. Yep, $5K each. The carbon slowly leaches out of them so they get lighter.
    Rick
  15. tazandjan
    39,016
    Lowest price I found on rear rotors (257102) was ~$2800 from Maranello Classic Parts. Ricambi has the fronts for $6500 each and another Euro sourcs has them listed at ~2300 euros. Ouch. Makes me glad I have Mov'It ceramics and not Brembos. Rotors do not wear much at all.
  16. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    The high cost is why serious track hounds often switch to steel brakes. But most Cali owners will not track their cars much if at all. I think it's repeated heavy braking that keeps the rotors and pads at elevated temps for extended periods that wear them quickly, so ordinary or even vigorous street driving, including canyon carving, should not be a problem.
  17. MalibuGuy
    Sep 18, 2007
    5,807
    There was a fierce debate over the advantages of CCB vs Steel. Some claimed it was a weight advantage. Others, a matter of performance.
    In the final analysis, CCB brakes are better than steel in terms of performance on the track.
    Steel are cheaper and may last longer . But in a race, CCB win.
    Of course they cost more and may not last as long, but there is a reason why no F1 teams use steel anymore.
  18. TheMayor
    104,822
    Vegas baby
    Honestly, not that bad.
    Seriously guys... if you can afford to buy a car for $225K, you can afford $1500 in brake pads for it every couple of years. Ask guys with older model F cars what they pay for in maintenance and upkeep on their cars. They would say they wish they spent only this much to keep it on the road.
    I did a brake job on my Mini Cooper S at 30K miles. The cost: $1200. Cars are expensive today.
  19. yoda
    yoda F1 Rookie
    Sep 27, 2004
    2,598
    UT
    Does the California have a non-carbon option? I know some people who like to track often opt for steel rotors to keep the costs down on other Ferraris.
  20. tazandjan
    39,016
    Mayor- Only trouble is Ferrari wants to say the rotors are shot after two pad changes. That can get expensive when Ricambi wants $6500 per front rotor and they are more at the dealer.
  21. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I never said steel rotors are better, just cheaper!
  22. LARRYH
    LARRYH F1 Veteran
    9,520
    virginia usa
    I have experience with both my california and my ZR1 corvette. I thought i would mention they use the same brake system and probably the same size . It is my understanding that currently a company you maybe familiar with that has ZR1 corvettes that are used 100% for track they say they get about 15000 track miles on a set of pads . Chevrolet apparently claims the rotors should last the life of the car (assuming they do not get damaged by wear through etc.) I know i went to Spring mountain motorsports in Las vegas for a 2 day ZR1 roadcourse using their car and they are run pretty hard I know I was running around 145 on a road course then down to 25 or 30 for a hairpin etc this for several laps it seems we did ten lap sessions that car had several thousand mile on it. Also I looked up replacement rotors and they were around 1800 per . Now before everyone corrects me they may be different sizes but the point is they ARE the same product .
    the Ferrari could have a softer pad and with a little more weight I could see it wearing faster but 15000KM for a set seems excessive.
    Sammi likes this.
  23. tazandjan
    39,016
    Larry- The Corvette rotors are ~392 mm, IIRC, vs 398 for the later Ferraris, but owners have had luck using those rotor rings with the Ferrari hats. Front rotors are $1200 from online wholesalers, way less than the $6500 for OEM from Ricambi.
    Had not heard any longevity numbers on the ZR1/Z06 rotors, so maybe Chevrolet has different pad materials or a Gen 2 system. The GTOs came with Gen 3, so I always wondered what happened to Gen 2.
  24. LARRYH
    LARRYH F1 Veteran
    9,520
    virginia usa
    Fair enough I would think there is some difference. The california also weighs in a little higher which could contribute some to tread wear. I know at spring mountain which runs the car pretty hard more or less all day long had should be as rough as anyone would expect on a car. By the way if you want a great time they have a nice course and you get to break their car and tires sure beats gambling 2K away.
    LarryH
  25. spyderman
    spyderman Formula 3
    1,621
    Toronto - Canada
    Spyderman
    Good inform on cost of brake pads. Are they the same pads that go on the 458?
