Brake light mods | Page 5 | FerrariChat
Brake light mods
Discussion in 'California/Portofino/Roma' started by mrbon007, Aug 17, 2017.
  1. SB27
    SB27 Karting
    Dec 2, 2015
    125
    Thanks, Todd. Amazing write up.
    Anyone know if this process is the same for a California T? Thank you.
  2. thomastrain
    thomastrain Rookie
    Oct 30, 2019
    28
    Steve CI
    one would think there would be a way to put a jumper at the fuse box to connect the trunk circular lights to operate as a brake lights.
    Seth Gillespie likes this.
  3. ToddMick
    ToddMick Karting
    Sep 30, 2019
    57
    Las Vegas
    Todd M
    No problem and glad it can help so many others. I’d assume it must be similar. Try pulling the panels off and looking - that should only take maybe an hour.
  4. rob.kruiswijk
    rob.kruiswijk Formula 3
    Jun 15, 2014
    1,370
    Netherlands
    Rob
    bus you are still compliant with three brake lights when your trunk is not open. Which is mandatory for safety.
  5. res1afbe
    res1afbe Rookie
    Sep 6, 2011
    5
    I followed the directions with success. Pretty much everything you mentioned, Todd, was true - especially the part about the tight quarters in the flexible rubber harness. My Cali is a ‘10 so I decided to add a backup camera at the same time and THAT wire set was impossible to get through the rubber so I did a bit of a piggyback on the backside of the factory route which works just fine.
    Bill Phillips likes this.
  6. Bill Phillips
    Bill Phillips Formula Junior
    Nov 4, 2019
    478
    New Orleans
    Bill
    That's a really nice looking job.
    res1afbe likes this.
  7. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
  8. D-Gunz
    D-Gunz Rookie
    Apr 9, 2013
    41
    San Diego
    David W.
    hi,
    are you in California? I'm in Nor-cal atm but moving down to SD in a few weeks. Would love to see your car. I have a 2011
    thx
    David
  9. D-Gunz
    D-Gunz Rookie
    Apr 9, 2013
    41
    San Diego
    David W.
    where are you located???
  10. irakles
    irakles Rookie
    Jan 11, 2023
    12
    Alex Rentzis
    695, Randy R and MacNugget like this.
  11. richkh
    richkh Rookie
    Jul 25, 2023
    21
    R H
    Andrew, did you get your modification to work and do you have a guide on what to do?
    Many thanks
