Brake fluid flush 458 | FerrariChat
Discussion in '458 Italia/488/F8' started by vincep99, Jun 1, 2017.
  1. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,930
    #1 vincep99, Jun 1, 2017
    I flushed my brake fluid out last weekend; it went very quickly and effortlessly. I used a Motive Power flusher. The brakes are significantly better (less travel), probably not due to the new fluid but may have been some air in the system. You can see the difference in color (the one on the right is the old fluid)
    I wrote an entire procedure which I will post later.
  2. 100badboy100
    100badboy100 Formula Junior
    Sep 15, 2016
    825
    Devon- U.K.
    Michael
    Hi Vince
    When was the fluid last changed?
    Be interesting to understand the interval that caused that much degradation of the fluid
    Regards
    Michael
  3. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,930
    Good question. I only met the original owner once, and I don't have his # to ask him. I will ask the dealer next time I am there.
  4. justthebest
    justthebest Formula Junior
    May 14, 2014
    319
    Denver, CO
    Looking forward to your write up.
  5. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,930
    #5 vincep99, Jun 5, 2017
    F485 likes this.
  6. justthebest
    May 14, 2014
    319
    Denver, CO
    Awesome - thanks for providing such a thorough write up.
  7. Expat458
    Expat458 Karting
    Feb 27, 2017
    68
    The Sand Pit
    Paul Healey
    Very informative. The more we can DIY the better for everyone....
  8. Hoagers
    Hoagers Karting
    Dec 4, 2016
    166
    Very well done. The only other suggestion I'd make is to make sure you keep a spray bottle or hose nearby just in case of fluid spillage to quickly remove anything that touches paint or black plastic.
    I also use a Motive and LOVE that thing! Used it only motorcycles and all my cars except it doesn't work on Honda cars
  9. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,111
    Mel
    According the oem service I doubt that seeing the colours.
    Which DOT did you use Vince ? DOT 5 ?
  10. Bowtye8
    Bowtye8 Karting
    Dec 28, 2013
    61
    Very interesting...
    I have a story I will have to type up on my dealer brake bleed experience that did not do as easy as this.
    Cliff notes.
    Bought a 458..Brake had a soft pedal. Brought to F-Dealer for Annual maint. Had them chk brakes. Agreed soft pedal and I cold bleed for 200.00. I did . Still soft pedal. Said it could be ABS pump for 9500 or mater cylinder for 2k. With advice I went with Master cylinder. 2k laer still soft pedal said I need ABS pump...All that's left in system. I held off.
    Tlak to dealer where I bought car . Sent me to private dealer...Used to work at F-dealer(old timer)
    They bleed brakes. Said it took a lot of time but flushing about 8 times did the trick. So 850.00 later pedal is perfect and good to go.
    Said possible varnish build up. Put in Full synthetic brake fluid.
    I did take action on the F-dealer and we worked out some resolution after some leg work on my end....BBB etc...
    all good now and enjoying my first F-car.
    greg328 likes this.
  11. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,930
    Mel,
    I used DOT 4. I double-checked what it said on the cap with what was in the owner's manual.
    I used NAPA brand simply because I have been using it for years.
    Reminds me: whatever equipment you use, make sure to flush it with denatured alcohol as soon as you are done
  12. justthebest
    May 14, 2014
    319
    Denver, CO
    What volume of fluid did it take you to flush the system?
  13. Melvok
    Jul 25, 2008
    14,111
    Mel
    Otherwise the DOT 4 eats the caliper paint ... :(
  14. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,645
    Silicon Valley
    Won't the alcohol eat the Ferrari decal on the caliper?
  15. Melvok
    Jul 25, 2008
    14,111
    Mel
    It (decalls + calipers) should all have been spayed with clear paint 2 layers or more ... (anyhow, I have spare decalls here if needed :) )
  16. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,930
    It takes 1 quart. Maybe could have done it with less but once you open the can you should throw the remainder out anyway.
    On the DOT4 eating caliper paint: Mel,. you are so right! I just took a brake seminar (which prompted me to take brake fluid more seriously) and he stressed that a lot.
    On denatured alcohol: the instructor at the seminar said to use this (vs. e.g. brake cleaner). I don;t know if he was thinking about the decals, but I am glad to hear that the calipers are clear-coated.
    On another note: I am putting my car in the Italian Happening at M! Concourse in Detroit this Sunday; maybe I will get an award for the cleanest brake fluid!
  17. Melvok
    Jul 25, 2008
    14,111
    Mel
    :D
  18. justthebest
    May 14, 2014
    319
    Denver, CO
    So I've done a little research, and the 458 has an ABS system that will hold some small amount of fluid captive unless / until the ABS is cycled. While the volume of that fluid is relatively small, I was wondering if anyone has experience performing that part of the flush / bleed and could recommend a compatible OBD tool.
  19. Melvok
    Jul 25, 2008
    14,111
    Mel
    Read post # 1 here, Vince flushed complete system ! Incl ABS.
  20. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,930
    Mel,
    Thanks for the kudos but justthebest brings up a good point. I did some research and this site sheds some insight:
    Bleeding ABS Brake Systems
    So if we want the 100% solution, we need to cycle the ABS valves. I looked also at the WSM and it does say that to flush the passages from the ABS portion, you need their tool to cycle the ABS valve.
    As far as an OBD2 tool that can do that: I think that even most of the better ones that do handle ABS can only read and erase the codes, not cycle the valves. And from I remember of mine (INNOVA), it can only handle ABS/SRS for the "Big 5" OEMs.
    I'll hook up the INNOVA this weekend
  21. Solid State
    Solid State F1 Veteran
    9,635
    Maximus Decimus Meridius
    I have always done the vacuum method for many decades. Would like to try the pressure method but have to ask - aren't you pushing air into the system when you first hook-up to the reservoir cap with the plastic line filled with air? What method do you use to get the air out of the plastic line, the top of the pressure tank and the part of the brake reservoir that contains air above the fluid?
    Seems you must evacuate all air in your device as well as the plastic lines and the reservoir before applying pressure otherwise a lot of air will push through the full system which is very much undesired. Thanks.
  22. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,930
    Very good question; all I can say is that it is not a problem. You can see the brake fluid flowing through the clear line to the reservoir and there is no entrapped air. Could be osmosis but I don't know for sure.
  23. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    You should bleed the pressure bleeder line. I have a much heavy duty unit and it has a bleeder. Also, you can set the bleeder right in the trunk that way no risk of fluid on body work.
  24. Solid State
    9,635
    Not sold on this. Bleeding the line for sure but what about the air under the cap? I have on occasion let the reservoir suck a very small amount of air during the vacuum method and you basically have to start over and re-flush the entire system. On some vehicles it leads to a nasty soft pedal that's hard to get firm again. If you have anti-lock and a complex master cylinder and cross-over system then I would not let any air at all in there. Will stick with the vacuum method. Thanks for all the info.
  25. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    It would not be difficult to add a bleeder valve to the line. As far as air under the cap - simple: top off the resivior before connection the pressure bleeder.
    greg328 likes this.
