Brake calipers same as Alfa Spider ? | FerrariChat
Discussion in '308/328' started by samba-lee, Nov 18, 2010.
  1. samba-lee
    samba-lee Formula Junior
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    I don't see anything in the cross ref thread, but since (it appears) that the front brake pads on my 308 GT4 are the same as late classic Alfa Spider then how about the Alfa front calipers ? seal kits, pistons and pad fitting kits ? anyone compared them?
    http://www.classicalfa.com/shop/category11_1.htm
    Lee
  2. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    I sure hope the master cylinder isn't the same as well. I just paid 5 times that much for one that looks identical. I thought it was a good deal until I saw this.
  3. samba-lee
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    I'm sure someone hs done this comparison before ...
    Lee
  4. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Having one of each, I doubt it. The weight difference is substancial.
  5. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    I'd be careful with the pads; a friend here installed Alfa pads in his car, and the brakes got alarmingly soft after a couple of laps on the track.
  6. samba-lee
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    Thanks, I don't track the car at all and would probably upgrade the brakes calipers etc. as well if I did.
    It seems that Sueprformance sell the Ferodo (Alfa Spider) ones I have bought - and they suggest, by the price that these are superior quality.
    With regards to the calliper we know it's the same as a 911 type A (I think from memory) which certainly has the same pistons and seal kit so that tends to make things a little cheaper.
    I found this company do replacement pistons in stainless and rebuilds a-lot cheaper than Superformance or any others:
    http://www.biggred.co.uk/
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=310265003877&ssPageName=STRK:MEWAX:IT
    When I had my calliper apart last week the measurements were the same for the pistons at 48 x 30mm
    It looks like the Alfa 1750/2000 front callipers are the same casting (although I'm not sure about mounting hold spacing) and with the extra width piece to accommodate the width of vented discs. Thus in theory one could use Alfa casting halves with your old separator piece if they do check out to be the same external dimensions. Either way it would look like the pistons and seal kits would again be the same as 911 and therefore 308.
    Lee
  7. pgarossino
    pgarossino Formula Junior
    Nov 19, 2009
    307
    Houston Tx
    Paul G.A. Garossino
    I currently have 3 Alfa's in my shop along with my 84 308. I have a few extra front and rear Alfa callipers around as well as master cylinders. I'll take a look tomorrow and post my findings.
    Paul
  8. samba-lee
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    Great. I'm thinking that the caliper halves will be the same which would open up a great source of typically cheaper brake parts.
    Lee
  9. samba-lee
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    I also gave Superformance call yesterday to discuss the price differences on brake rotors and replacement brake pistons.
    They have always been open to suggestions like this (well they would be wouldn't they) so I expect they will be buying up Bremboshops stock and looking at cheaper sources of brake parts - I had the feeling they didn't know about the Porsche brake calliper connection.
    Lee
  10. pdmracing
    pdmracing Formula Junior
    Feb 14, 2007
    755
    atlanta
    Early porsche 911 for the fronts & 914 6 for rear(parking brakes are different though) factory rebuild kit from ATE for 911 6$ from napa
  11. Eric_Shea
    Eric_Shea Karting
    Aug 9, 2009
    71
    Sandy, UT
    Eric Shea
    The front caliper is referred to as an A-Caliper in Porscheland. 911SC from 78-83. Very common pad size and don't be at all suprised if it is the same as the Alfa. BMW's and Mercedes use this popular caliper. It's the heaviest caliper ever put on a 911 (would love to see a 308 with S-Calipers).
    The rear caliper is "almost" identical to the 914-6. The bleeders are on opposite ends and the Ferrari version has 10mm spacers to allow for the vented rotor.
  12. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    For any pad you can buy different compounds, plus there are more Alfa Romeos racing around race tracks in the world than Ferraris ... so there will be an appropriate pad somewhere.
    You can get competition pads for a Toyota Camry if you ask the right people so you can get them for anything.
    Pete
  13. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    As I recall, the front rotors on my alfa spider were solid rotors, so, I would guess that while the basic caliper halves are likely to be the same, the spacer may be of a different thickness (or not present at all).
  14. samba-lee
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    I suppose that point is that it opens up a good source of calliper spares which don't have the Ferrari or Porsche tax.
    With some cross checking last night for example I reckon VW Derby/Polo front pads will fit the rear and can be had on ebay for $0.99 a set.
    Compound is irrelevant to me right now as I don't track the car.
    Lee
  15. Eric_Shea
    Eric_Shea Karting
    Aug 9, 2009
    71
    Sandy, UT
    Eric Shea
    You do plan on stopping the car right?
    Good brakes mean everything. They are one of, if not "the" most important saftey devices on your car. Compounds can literally alter your braking performance (one way or the other) $0.99 pads on your Ferrari? Aaaaah... OK :confused:
    Porterfields are the best pad I've found for the money.
    Cliff, spot on. I've built these for Alfa's and they have no spacers.
    The Porsche versions can be had for around $2-300.00 per pair. Not a big deal. There are two versions so be carefull if you look for spares in that arena.
    78-83 - A-Caliper. 7mm spacers. Fits over a 20mm vented rotor
    84-88 - Wide A-Caliper (or Carrera Caliper) - 11mm spacers. Fits over a 24mm vented rotor
    One of my least favoite calipers because it's so heavy. A lot of Porsche guys replace them hence the lower price. Also, the M9 fasteners are NLA. They are a poor fastener design because they have so much thread engagement, especially troublesome with age and rust, vs. the small Ribe R6 head design.
  16. samba-lee
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    I agree on compounds, but since the pads I have on there are literally falling to bits then a new set of whatever will be better - hence the "right now"
    The fact that they are $0.99 just means that no-one, it seems, has thought much about alternatives on this and those selling VW Derby pads just don't know they are the same fitment as a 308 so you don't get sueprcar tax on top. For many of our cars that really do little more than go on occasional weekend drives then I see little point in spending unecessarily, but of course agree that if you are going to "drive" your car then make sure you have pads that can take the abuse.
    The Ferodo pads seem to be pushed my many sellers as the most common replacement and acceptable replacements, but when you look through their catalogue you realise that it really is often just the shape that's different - that's surely not worth paying so much more.
    I know it's not huge differences on pads, but replacement pistons is perhaps a better comparison with Superformance wanting around £40 per piston but others wanted more like £24 just because they are cited for another car - it adds up when you need four and I'd rather spend the difference on fixing something else on the car.
    The brakes are certainly really heavy - maybe some of our far Eastern friends could start casting repro 911 S ones...
    Lee
  17. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    If the genuine ATE calipers are too heavy, simply replace them with front calipers from an Alfa Romeo 75/Milano. Exactly the same caliper but cast in alloy, or if not exactly the same they mount up exactly the same, and fit, etc.
    Alfa Romeo guys have been making this swap for decades ... there is a benefit from all that racing ;).
    Pete
  18. Eric_Shea
    Eric_Shea Karting
    Aug 9, 2009
    71
    Sandy, UT
    Eric Shea
    The ATE calipers for the Ferrari and Porsche have 3.5" mounting ears. The Alfa version has 3" ears.
    I use the Milano Brembos almost exclusively for "early" 911 conversions (911T cars with the 3" mounts). They rock as they're only 4lbs. 6oz. compared to the 9lb ATE's.
  19. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    #19 chrismorse, Nov 22, 2010
    The ubiquitous 911S aluminum, (as well as the "M" and "A" calipers) all have 48 mm pistons. Typicaly, the aluminum calipers require a 3.5 bolt mounting center. I am considering upgrading my bequeathed 74 911 with better brakes.
    As far as "heavy", check this out: I weighed the stock 308 disc and caliper, (front) and it weighed MORE than the 14 inch disc and caliper from the F-50, (including the full floating hat and the custom caliper brackets.
    The rotational inertia, however is a "bit" more;-)
    Most pads are adequate - but- some squeel and/or dust more. Some are very linear in their stopping power, cold through hot. Some are bulletproof at track temps but eat rotors for lunch. Some don't work when cold/wet. Some will last two track weekends, some forever. Some cost almost nothing, (beware the old addage); and some cost a ton.
    I have opted for a fairly linear, (temp/co-efficient of friction) pad of high quality, the Pagid R4s, (if memory servs) and am very happy with it.
    Half way through track sessions when the 360s and 430s are slowing early for the end of straight turn, i am still hard on the gas - big smiles.
    Brake pads may literally make the difference between life and death and if you drive even a bit hard, the money spent is well worth it. Save money anywhere else.
    Seriously bent about brakes,
    chris
  20. samba-lee
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    That sounds an interesting lead. Thanks it seems we are gathering good intel. on the matter now.
    Lee
  21. samba-lee
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    #21 samba-lee, Nov 23, 2010
    Thanks for the input to the discussion Chris. So what did you do for the rear caliper ebrake solution ? as that looks like a brembo on the rear too ...? I have them all round on my 993 - they are certainly a good setup, but of course the 911 has the shoes inside the rotor arrangement for the ebrake.
    I guess these are the holy grail in some ways if you want to stick with period look.
    http://forums.pelicanparts.com/uploads18/911S+neue+Aluminum+bremsen+am+suspension1281722028.jpg
    Lee
  22. Eric_Shea
    Eric_Shea Karting
    Aug 9, 2009
    71
    Sandy, UT
    Eric Shea
    #22 Eric_Shea, Nov 23, 2010
    Read the post below it... they (Alfa Brembo's) don't fit. They have 3" vs. 3.5" spacing on the mounting ears.
    The picture in the link are S-Calipers we restored for Max Sluiter. Those should bolt right on to a Ferrari and save almost 10lbs. of unsprung weight. They are cast of the famous 908 caliper casting.
    With the rears the problem is usually exactly as you've stated. What to do with the handbrake. Not sure about the Ferrari's but the 914 and 914-6 crowd struggles with this. The minute you bolt anything on the front, the bias is thrown off. So... you have to do something similar to the rear. That usually means eliminating the handbrake. With mid-engine and polar moment inertia... a bias mis-match can be a DISASTER.
    Love to see what's done in this case...
  23. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    #23 chrismorse, Nov 23, 2010
    Hi Lee,
    That question, "What can be done about the rear brakes" was my very first post - even before i bought the green car. I had noticed a lot of interest in 308, (and pretty much most other guys tracking ferraris, in upgrading the brakes.
    My 74 911, which weighs 2400 pounds, has the same F 48 / R 38 mm caliper pistons - as the 308 at about 3200 pounds. True, the 308 has power bost, but the 911 has to be a lot easier on the brakes than the 308.
    Anyway, after i scrounged the used calipers and discs off of ebay, i worked with Martin at Girodisc to make them fit. Martin found some 36-40 mm pistoned brembos, (same caliper brembo uses on their front 308 big brake upgrade), and some used 360 rear parking brake calipers. I bought new 360 drilled rear discs, 328 x 28 mm for the rear, Martin made the caliper adaptors and full floating hats.
    Once this was done, i looked up a local CNC machinist to spot face and helicoil the front ears on the rear upright. With the caliper and disc now in place, He was able to reverse engineer a very slick bracket, (also helicoiled) to mount the brembo 360 parking brake in place of the rear stock caliper. The parking brake cable needed to be lengthened about a foot to work on the 360 P brake actuating arm, (see trial fit photo).
    Even with the monster F-50 front caliper, the rear still had too much rear bias, so i bypassed the stock rear pressure proportioning valve and installed a used tilton lever style prop vaalve in the front of the car by the new Wilwood 1-1/16th master cylinder. Adapting that took about 1000 in machine work, (new-longer pushrod, pair of mounting ears, special nuts to secure mounts and a small bit of machining of the new mc).
    Initially, i tried Mintex Extreme brake pads, but they were too hard on the discs when cold and they would not stop the car if cold and rain soaked, so i went back to the Pagid R4s that came with the used calipers and all is well.
    Used components: all calipers, front discs and prop valve; new custom hats and 6 mounting brackets, master cylinder and steel brake lines. Cost, including machining, with me doing all of the assembly, $7000. Not cheap, but seriously bulletproof.
    hth,
    chris
  24. samba-lee
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    Hi Colin and welcome to Ferrarichat - this is where it all happens.
    I think we all appreciated it when when can have genuine dialogue with significant traders like yourself. I'm feeling that customer service is the only thing these days that differentiates sellers on the internet. I recall before buying my GT4 five years ago being really pleased to find that there was such a comprehensive after-market parts source and in the UK too! sorry everyone else :)
    I guess I had to tell you about the rotors and pistons as these are the two items that stuck out as being a fair bit more expensive. Yes I am a little bored and the nights are long and cold so browsing through the Ferodo catalogue is interesting and illuminating too! Times are a little harder than they were so I look a little harder for a cheaper source for the same product now.
    Chris, nice pictures and interesting mod. I didn't know the 360 had this parking brake set-up. I guess it looks a little strange with two callipers on the axle, but the benefits will clearly out way the looks.
    Lee
  25. samba-lee
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    #25 samba-lee, Dec 3, 2010
    So I just received these nice new stainless steel front pistons.
    Question is, where do you point the milled-out section when you install the piston ? does it matter ? and what is it for ?
    Lee
