Brake Booster Almost Out - HELP! | FerrariChat
Discussion in 'Mondial' started by Mondial 1985, Jul 3, 2015.
  1. Mondial 1985
    Mondial 1985 Formula Junior
    Jun 13, 2012
    344
    Greenville, SC
    Mark Alan Day
    Hey guys, I've got the brake booster loose now. I've got all 4 nylon nuts off (the one inside the car is sort of a bear, but came off). Now, the booster is loose. One question (and the answer may be obvious) is that in order to pull the booster free of the car, looks like I have to remove a cotter pin and then knock a rod out that connects the brake booster linkage (from inside the booster) to the pedal rod? Looks like I do. Any suggestions to make it easier?
  2. Mondial 1985
    Jun 13, 2012
    344
    Greenville, SC
    Mark Alan Day
    Got it. Now where to send it?
  3. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,816
    Old Dominion
    #3 soucorp, Jul 6, 2015
    Try White Post restoration, they do great work: Brake Cylinder Solutions
  4. 123howie
    123howie F1 World Champ
    Jul 3, 2014
    16,017
    El Segundo CA
    Howie
    You should change your name to "Mr Mondial"
  5. 350HPMondial
    350HPMondial F1 Veteran
    5,339
    Edwardo
    Whitepost did my brakes on my 1985 QV.
    They do good work.
    Report your Experiance.
    Edwardo
    Thanks.
  6. Mondial 1985
    Jun 13, 2012
    344
    Greenville, SC
    Mark Alan Day
    Thanks guys. White Post it is.
  7. Mondial 1985
    Jun 13, 2012
    344
    Greenville, SC
    Mark Alan Day
    If I may, I think I've found an easier way to remove the Brake Booster I'd like to share. After removing the master cylinder, I went under the dash using a 1/4" drive socket and ratchet. I loosened the nut, then went up top and removed the three remaining nuts. Now, I went back under the dash and began removing that last nut. As I was ratcheting it out, I had to have sweet thing pull on the booster because once the bolt is out at the end of its threads, you cannot remove the ratchet/socket; but as she pulled, it kept the bolt up against the fire wall, thus I was able to get the nut and socket off.
    Secondly, you have to remove a cotter pin and the funky thing about this one is: the rod is in with the pin away from you. Well, after messing with it a while, I was able to remove it. When I re-install it, I'll have the cotter pin facing out toward me for easier removal in the future. Finally, I took a drift and drove out the other shaft instead of trying top remove that cotter pin. That would've been impossible with it still in the car. FYI - You have to take the spare out. With a little finagling, I was able to pull the whole unit out. Now that it's out, I can remove the remaining lever assembly.
