Brake bleeding sequence & tricks 250 Gte | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by christc, Dec 19, 2019.
  1. christc
    christc Formula Junior
    Mar 3, 2013
    444
    Germany
    Dear Al,
    I will fill the brake system on my 250 Gte S3 (see photos) soon and have some questions:
    1. What fluid do you recommend? Silicon or normal Dot4?
    2. What is the best sequence for bleeding 250 brakes?
    3. Are there any tricks which make it easier?
    I do have a hand pressurised bleeder which connects to the reservoir.
    Christopher
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,922
    romano schwabel
    all brake parts connected with the brake fluid are new? then I would use silicone brake fluid
    picture of your pressurised bleeder would be great, there are several different on the market.
    first you may bleed the 2 bleeders at the booster, then RR, RL, FR and FL, but also would be good to bleed at the front first the multiplyer ( right word? bremskraftverstärker ) in the middle of the car front of the front axle
    normaly an easy job to do all
    jimlt4383 likes this.
  3. christc
    Mar 3, 2013
    444
    Germany
    Dear turbo-joe,
    Thanks for the ultra fast answer. Yes, everything is reconditioned or new. All seals or rubber parts are new.
    I will post a picture of the bleeder, it is a simple pressurised tank containing fluid. Pressure is build up using a integrated hand pump.
    I heard different names for the part you mean, multiplyer or very often brake balancer or brake balancer valve.
    Christopher
  4. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,831
    It is a hydraulic brake booster. It adds pressure to the front brakes.
    turbo-joe likes this.
  5. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,831
    I would also recommend silicone fluid, with the following tips:
    1. Do not shake or agitate the fluid when in the container or in pouring it into the reservoir.
    2. If you have trouble bleeding, go to the old gravity method, and take your time. Gravity bleeding is ALWAYS the safest method.
    3. Give any remaining bubbles of air time to migrate up through the system to the reservoir. Let the system set overnight after your bleeding and then recheck it.
    Nuvolari likes this.
  6. christc
    Mar 3, 2013
    444
    Germany
    Thanks a lot! Will follow your advice.
  7. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,399
    Toronto / SoCal
    Rob C.
    Absolutely use silicone brake fluid if the system is new. Silicone brake fluid does not damage paint and lasts much longer than regular brake fluid.
    One piece of advice is to be careful when bleeding the system to not take the master cylinder through its full travel when bleeding unless the cylinder bore is brand new. Old reconditioned cylinders sometimes have pitting in the extreme areas of the cylinder that is not normally used. When you bleed the brakes it allows the seals to run on these pitted areas and can damage them. It is always safe practice to avoid taking the brake pedal through its full travel when the brake bleeders are open.
  8. turbo-joe
    Apr 6, 2008
    8,922
    romano schwabel
    this only will happen when you bleed by pushing the brake pedal but will not happen with a pressurised bleeder
  9. GSJFerrari
    GSJFerrari Formula Junior
    328
    Stuart, FL
    Greg Jones
    I use these self bleeder type screws that have a check valve and threads are sealed and for brake fluid i use the DOT 4 fluid for best performance and if kept fresh by draining the reservoir with a turkey baser every 6 months and start from the booster working your way down and only using **short jabs** with the brake peddle especially on older master cyl. and be sure to remove the ball before installing new screws
    https://www.amazon.com/RUSSELL-639590-Russell-Speed-Bleeder/dp/B000CPCOBQ/ref=pd_bap_rp_11?_encoding=UTF8&psc=1&refRID=RGT4XWEBXSWYQ9NEGRMP
    https://www.amazon.com/gp/product/B018GGV28S/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
  10. christc
    Mar 3, 2013
    444
    Germany
    Dear turbo-joe,
    here is a picture of the simple bleeder I will use. I had a professional bleeding system but it turned bad as I did not use it that often and the brake fluid in the system ruined it. This works quiet well I was told by a user.
    BR
    Christopher
