Braided Stainless steel brake lines 348 | FerrariChat
Discussion in '348/355' started by fatbillybob, Feb 8, 2008.
  1. fatbillybob
    Aug 10, 2002
    28,563
    socal
    This is posted for future searches.
    Jeremy L found the best brake lines. Stoptech makes them and stocks them as a dot OEM replacement. The best parts about these lines is that they have swivel ends so they do not bind upon install. Ebay vendors have them for 130 bucks and they may be cheaper with more searching.
    Rotorwork.com 714-554-7320
    http://cgi.ebay.com/ebaymotors/Ferra...2em118Q2el1247
  2. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,424
    CT
    Jay
    +1, I ordered Stoptech lines from the same vendor a few days ago.
  3. F512M
    F512M Formula Junior
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    I just finished up the installation of my Stoptech lines this week and after a 348 oil change party today with Sameer and Jason we went to a little drive and grabbed lunch. Three 348's in my driveway was a pretty cool sight. :) Sameer took some photos.... The new brake lines made a HUGE improvement in the stopping power of the car. I can get the ABS to kick in with ease now and I hear the tires chatter a little..... Daddy like!!!!
  4. fatbillybob
    Aug 10, 2002
    28,563
    socal
    Stoptech part numbers are 95003001 and 95003500
  5. TheOnlyest
    TheOnlyest Formula 3
    Sep 25, 2007
    1,686
    Las Vegas Nevada, US
    Steve
    This link is no good... could you check it and repost?
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  7. brent Lachelt
    brent Lachelt Formula 3
    Dec 6, 2003
    1,831
    Brownsburg, INDIANA
    Brent R.Lachelt
    Do the two part number represent front and rear lines?
  8. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #8 No Doubt, May 12, 2008
    This is what they sent me for a full 348 upgrade, 950.03001=front and 950.03500=back:
    (17mm and 14mm fittings)
  9. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    Just ordered a set for my 355, $139.90 total for front and rear......Good deal
  10. PAP 348
    Dec 10, 2005
    100,199
    Mount Isa, Australia
    Pap
    Mmmm....very tempting!! :D:D
  11. F512M
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    Everything is included to complete both front and rear. I love mine!!! If I am not careful the ABS will kick on. I had only experienced that once or twice with the old lines. They really do make a difference.
  12. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    In which end of the new lines did you mount the black plastic brake fluid strainers/supporters? I take it that they are only plugs for reducing dripping during the installation process, and not meant to be left in?
  13. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    can someone document the installation? How hard is it? If I've managed to change the tranny fluid and the 02 sensors on my car, is this much more difficult?
    thanks!
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    No problem!
  15. F512M
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    Just used to reduce dripping. Worked fairly well..
  16. F512M
    Dec 9, 2003
    504
    Houston, TX
    Jeremy Lawrence
    Very easy project. But as with everything on these cars, it requires some patience. And a power brake bleeder helps too but not required. :)
  17. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #17 No Doubt, Jun 5, 2008
    Here you go.
    First, loosen the lug bolts on your wheel (right rear in this case), then jack up that side/end of your car, then remove the lug bolts and remove the wheel. Use jackstands for safety and use chockblocks in front and behind your *front* tires because with the rear lifted, you have no parking brake holding a 348.
    Now put your 11mm brakeline wrench onto the engine side of the brake-line to rubber brake hose connection, as shown below:
  18. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #18 No Doubt, Jun 5, 2008
    The above is just under your exhaust ECU, by the way...and you do *not* have to remove the inner fender liners for this job.
    Next, put your 17mm brake-line wrench on the underside of the rubber brake line fitting, as show here:
  19. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #19 No Doubt, Jun 5, 2008
    OK, maybe not "as shown!" You've got to actually put your wrench onto the nut, after all.
    Anyway, hold both wrenches and loosen the top metal fitting nut with your 11mm wrench. Once disconnected, tape or plug the line, if desired, to minimize brake fluid dripping (no big deal if you don't, though).
    Remove your wrenches and grab your channel lock, next.
    Clamp your channel lock onto the retaining clip that holds the rubber brake line to the post shown in the pictures above.
    Simply pull this retaining clip off of the brake line.
    The pictures below show the clip.
  20. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #20 No Doubt, Jun 5, 2008
  21. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Install your new stainless steel brake hose with your 11mm and 17mm wrenches, then push the retaining clip onto that connection (in the machined groove), and use your 9/16" or 14mm wrench to install the caliper-side of your new brake line, as well.
    Now bleed your brake fluid for this caliper, check for any leaks, correct if any are noticed, and reinstall your wheel (hand tighten your lug bolts). Lower your car and then tighten your lug bolts to spec or as desired.
    Repeat for each other wheel.
    Done.
  22. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    NIce! Great job ND and thanks for sharing. Looks easy enough...any braking difference?
  23. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    When you pull the OEM lines off how much weepage of brake fluid is there? I imagine without pushing a pedals its whatever drips out with gravity?
    Sent using FerrariChat.com mobile app
  24. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,522
    Jeff
  25. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Good that sounds promising the stop tech lines come with a little plastic plugs I suspect I can use those to stem the flow also.
