This Trans Am came in for rust and paint repair. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Exterior trim removed and rust sanded to expose damage. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Rusted section cut out. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Patch panel welded in. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Grinding out T-top rust. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sanding down rough tape lines all over the car. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Body work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sanded down to bare metal exposing rust damage. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Yuck. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Found a rip and welded it. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
More body work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Very interesting to see the body production engineering/techniques used by GM at that time. With that joint between the quarter and rocker panel on each side, they didn't do anyone any favors, huh? It seems designed to rot. As for those T-Top jambs...all I can say is "better you than me!"...those of us who play with MIGs know those were some delicately laid welds on that repair section. With the BASF products you use I'm assuming the surface pitting can be safely sealed-up. Thanks for showing us this stuff, no matter what brand of car/truck...all fascinating. John
Thank you we really appreciate it. Any car I post thats not a Ferrari is normally a fchat members car so its fun for them to watch. Yeah the cars not to bad just some sloppy work of the years we had to remove. The autobody specific welders are so advanced now its really not hard at all to weld anything even advanced hybrid metals if you have the right equipment.
epoxy primer over the repair areas. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Seam sealer to prevent rust build up again. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Setup and mixing paint. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Gun metal gray paint Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Silver base coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Glasuirt clear. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sanded and polished. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sanding and polishing. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
