This 2004 Stradale came in for paint work, mechanical repairs, upholstery, and detailing. Image Unavailable, Please Login
Replacing broken muffler heat shields. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
The car had a CEL when it came in which was diagnosed as a faulty throttle position sensor. It felt similar to fuel cut or an alarm issue but would go right back to normal after starting the car up. Symptoms were loss in power and rpms would suddenly drop. We tested the old sensor and new to confirm it was failing. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Removing the dash. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Stripping the dash to bare fiberglass. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
We use Alcantara which is a synthetic suede that does not fade and can be cleaned. Image Unavailable, Please Login
Stitching away. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Test fit. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Final fitting. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
More fitting. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Dash ready to go in. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Installing dash. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Steering rack removed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Tires removed to repair curb rash and chips. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
