Bradan F355 Roll cage + 6 spd conversion | Page 2 | FerrariChat
Discussion in '348/355' started by BRADAN, Sep 28, 2016.
  1. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    #26 BRADAN, Sep 30, 2016
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Grab yourself a nice abrasive wheel chop saw - works way better and faster than a band saw :)
  3. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    No way haha I need my guy to have his fingers and hands for another decade or two plus I hate that smell! We have one the guys use to cut up jigging material with. We have a Vertical band saw, Horizontal band saw, cold saw, pipe notcher for all tubing cuts.
  4. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #29 BRADAN, Sep 30, 2016
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Many ways to get the job done but when I was building dragster chassis, I was cutting and notching A LOT of tubes and nothing does it quicker than an abrasive chop saw.
    For the record - I have all my fingers :)
    I also would notch many tubes on a grinder and got them right first try :)
    No argument regarding the smell - you are correct, burnt 4130 really smells and it's hard to get that smell out of your skin :)
  6. fatbillybob
    Aug 10, 2002
    26,430
    socal
    It is rare to see a halo bar
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,571
    SoCal LA/OC/New Mexico
    Tim Dee
    Smell? LOL I live for those smells
    We need more cages
  8. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Interested to know how your guy managed to weld all around the tube so close to that flammable roof lining?
  9. 97 Spider
    97 Spider Formula 3
    2,241
    Texas
    Brian
    Pretty sure he was talking about the shift shafts they made for the conversion kits. :)
  10. tres55
    tres55 F1 Rookie
    3,496
    Canada
    I love these Bradan workshop threads. Wish I lived on the east coast...I'd bring my car to you guys.
  11. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    The back side of the pipes would be welded first.....you have to be very strategic with your welding.
    As for the roof lining and other delicate parts.....I'm guessing they used flame proof blankets......thats what I would do.
  12. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    #37 PAUL500, Oct 1, 2016
    The tubes are too close to the roof etc to be able to get a 100% weld around them regardless of whether you could slide a heat blanket into the gap or not, and weld spatter will burn the lining as well.
    My understanding is that normal procedure is you cut holes in the floor, allow the whole tacked assembly to drop, weld the awkward parts then slide it back up into position, plate the holes and finalise the welds, but that does not look possible with the plates already fitted to the floor.
    Not being critical here, just trying to understand the process that was carried out in this example.
    I have two cages going into 2 355 bare chassis in the next few weeks but have the advantage as mine have no roof :)
    edit
    actually it looks like that is what the guys have already done and the cage is just resting on the bases for now and they will be slid out of the way once its all tacked up in order to allow the cage to drop. Not sure how they will tackle the rear facing bars though.
  13. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,505
    Lake Villa IL
    Agreed on being able to drop it down^^ That would give you access with a micro torch. Should be zero weld spatter however if everything is clean.
    Could use 3M 05916 to be safe.
  14. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,571
    Tim Dee
    Drop cage off perches, remove interior, weld
    reinstall
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Agreed (assuming, and hoping, TIG welding) :)
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
  17. phrogs
    phrogs F1 Veteran
    7,130
    Michigan
    #42 phrogs, Oct 1, 2016
    Nope nope.I was talking about the shift shaft, its one piece thats different on the f1 to 6 speed swap.
    Im kinda accumulating the spare parts since my GTS is a euro and has F1 trans, its already a bastard why not make it a manual..maybe
    Or accumulate everything and sell it as a kit if I never use it.
  18. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Johnny, that part should be available used. And, to be precise, it's a sub-assembly (several parts)
    You are referring to the shaft that goes from the shift are to the gearbox - correct?
  19. phrogs
    phrogs F1 Veteran
    7,130
    Michigan
    Its never pulled from a transmission that I have seen, so it looks like a little time on a lathe to get me one. Not a big deal.
    Specifically the shaft that goes inside the transmission.
    Ill post pics of my stick vs F1 for peoples info.
    Give me a few min.
  20. phrogs
    phrogs F1 Veteran
    7,130
    Michigan
    #45 phrogs, Oct 1, 2016
  21. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Correct.
  22. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  23. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #48 BRADAN, Oct 4, 2016
  24. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  25. 355dreamer
    355dreamer F1 World Champ
    10,469
    DC Metro
    L.C.
    Is the new owner planning on tracking this car? If so, I'm just trying to understand why he chose a freshly restored F1 to convert to manual. Seems like there would have been a lot of other, less expensive options if that was his ultimate goal.
