This is a 98 F355 spider with 15k miles that is in for a major service. Enjoy. Image Unavailable, Please Login
Disassembled. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Engine coming apart. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Hill engineering skid plates installed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
New cam seals, timing belts, and hill engineering tensioners installed. Image Unavailable, Please Login Image Unavailable, Please Login
A few leaks will be address outside of the major service. The rear main seal and triple seal will be replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Transmission removed and cleaned. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Gaskets and rear main seal replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Headers removed to pressure test for leaks and clean the engine block. Image Unavailable, Please Login
Valve covers installed with new gaskets. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Spark plug wires installed and valve covers closed up. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
A bearing noise was found coming from the Alternator pulley. The old bearing was removed and a new one will be pressed in. Image Unavailable, Please Login
Wrapped up and handed off to detailing. Wheels cleaned inside and out. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Interior carpeting cleaned and conditioned. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Leather cleaned and conditioned. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
