Bradan Coachworks | Page 6 | FerrariChat
Bradan Coachworks
Discussion in 'Bradan' started by BRADAN, Dec 7, 2017.
  1. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
  2. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  3. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Dan you are spending like a drunkin sailor :)
    Black pipe after filtration is a bad idea. Trust me on this. You will fight it.
  5. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    I'm addicted to buying tools now after watching the production in the shop jump so fast. Thank you to all our customers for the business we really appreciate it and will continue to reinvest to serve you better.
    I'm penny smart dollar dumb sometimes my friend.
  6. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Bradan is proud to announce we have invested in the best tire equipment on the market made by Hunter engineering. Our Hunter Road force balancer is unique to the market and considering a Diagnostic wheel balancer. The diagnostic roller solves vibration problems, identifies vehicle pulls and provides that “new car ride” If your tire is defective, rim is bent, or even just have the tire incorrectly install the computer will identify the fault. This really helps for guys that race there cars on the track to help solve high speed vibrations that go un noticed on public roads. Our Hunter tire machine features polymer mount head that resist marring your rims. Together we feel Hunter engineering makes the best combinations of tire mount and balancers on the market.
  7. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    We're often asked what paint guns we use to achieve our concours winning paint jobs. We use Sanitaria ("Sata") spray guns which are manufactured in Germany for all sprayable finishes. Originally, it came from the recommendation of our paint supplier Glasurit; since most of their finishes are designed to be sprayed with specific Sata guns. After trying out a few different brands the difference was tremendous. In today's modern body shop we must always work to a level of perfection while being mindful of our environmental impact. HLVP paint guns and RP are the only legal paint guns to use in a body shop. HVLP stands for High-Volume/Low-Pressure, and spray guns with this type of material transfer give you better, more consistent coverage than conventional spray guns, with minimal overspray. Rp is a Sata specific acronym for “Reduced Pressure” which is rated at a minimum of 65% transfer efficiency. The origins of Sanitaria go back to the firm Gretsch & Cie. GmbH in Stuttgart-Feuerbach, which was established in 1863 by Friedrich Carl Bauer and now operates in Kitzingen, under the name of Gretsch-Unitas. In 1914 “Sata” was registered as a trademark. In 2007 Sata celebrated a century in business. We're proud to use their spray guns in our paint department and will continue to work with them with advanced materials in years to come.
    For base coat finishes we use the Sata Jet 5000 HVLP Digital. This was designed by Porsche Design Studio in collaboration with Sata to produce a gun thats functional, aesthetically pleasing and comfortable for the operator to use. Painters are able to fine tune the spray fan control, material flow control, as well as the air micrometer. When spraying clear coat we switch to a Satajet 5000 RP which is similar but sprays slower using lower air consumption which is better for us when spraying clear coat.
    When spraying primer we use a Satajet 100 B F HVLP gun. Most body shops use cheap guns and don't really care about the primer stages, but the paint jobs base is really what determines the longevity and quality of the overall paint job. When spraying with a HVLP primer gun it's not only environmentally friendly, but also saves a lot of material which reduces required sanding effort. The air micrometer with graduations allow us to adjust the air atomisation. For polyester coatings normally sprayed over Fiberglass to do Gel coat repairs we us the Satajet 100 BF P polyester gun. To truly get a perfect finish, each stage from bare metal - to a finished surface must be fine tuned and analyzed for perfection. Otherwise, it will tumble from one weak link in the chain.
  8. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    At Bradan, we exclusively use Glasurit paint in our body shop. We are factory trained and certified, giving customers Galsurit's lifetime finish warranty. Our main paint system is Glasurit's 55 line solvent paint, which was used by most exotic vehicle manufacturers for decades. Glasurit is considered the best paint manufacturer in the world and has been in business since 1888. Their paint systems and processes which we strictly follow, are approved for refinishing by all leading vehicle manufacturers worldwide. They have the world's largest color data base, going back to the very first production cars. This allows us to convert absolute laquare colors into modern materials for a perfect paint match.
    We flew to Münster, Germany to visit the Glasurit/BASF factory in person, touring their center of production, research/developmant and marketing. It's a mini-city inside the gates, filled with scientists passionate about manufacturing the world's best refinishing products.
    Glasurit's history began in 1888 with Max Winkelmann founding a lacquers and paints company in Hamburg, Germany. The first paint was marketed under the name “Crystal White”. It was originally used for ocean liners and quickly expanded to customers in major shipyards and the German Kaiser. After being in business for 10 years, Mr. Wikelmann was making so many different products, he wanted to consolidate it under one brand name. The chosen name “Glasurit” was first trade registered over 100 years ago. The name “Glasur” means glaze or enamel, It reflects the enamel like glaze. In 1925 the parrot is registered as a protected trademark. The parrot's colors are the primary colors found in mixing paint.
    In 1964, Glasurit lead the market with the introduction of the first metallic base coat paint for the automotive market. Then followed in 1992 with one of the first waterborne basecoat systems on the market. In 2018 Glasurit Celebrates 130 years in business - a true testament of a market leader.
    Boomhauer likes this.
  9. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  10. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  11. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Bradan has now added emergency tow service to everyone in Nassau and Suffolk county. If you call out of our normal business hours of 8-5 pm Monday-Friday, you will now have an emergency option where a live operator will answer 24 hours a day 7 days a week, (even on holidays) dispatching a flatbed tow truck to your location. 631-521-0410
    Our tow truck is a Ford F650 with a 6.7 cummins diesel engine, with a century split deck tow bed. What's unique about our tow truck it has a “split deck” design bed that allows the end of the bed to pivot, decreasing the angle of the bed; this helps load low profile vehicles safely. You can rest assured that your vehicle will be safely picked up in the event of a emergency and brought to our secured location by our highly skilled transporters, and we will call you the next business day to discuss the issue.
    Don’t worry we have your family's back too and don't limit our services to just exotic vehicles. It's our goal to make you and your family's vehicle ownership as painless as possible. Please share our number 631-521-0410 with your friends and family and don't hesitate to contact us in an emergency 24 hours a day 7 days a week.
    For a transportation quote please call or text 631-521-0410.
    Our rates are 125/hour for long distance towing plus tolls. For Nassau and Suffolk county $75 hook up fee, $5 dollars a mile, and $100 min.
    We accept all credit cards and have mobile credit card reader. All insurance is accepted.
    Our truck is equipped with tow hooks for every single Ferrari, Lamborghini, BMW, Porsche, Mercedes, Corvette, Nissan GTR, Bentley, and Rolls Royce. Vehicles are strapped down using an 8 pt Nylon strap that does not touch the rim or suspension to avoid damage.
    If our truck is in use we have partnered with another well equipped towing company to handle your tow service.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  12. ttforcefed
    ttforcefed F1 World Champ
    18,881
    uve come a long way baby!!!
  13. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Thanks to customers like you supporting us over the years, can't thank everyone enough.
  14. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Our new car body repair spot welder is a Tecna 3664 DC current welding station with inverter technology. It's considered the most advanced on the market. The machine is fully automatic when in smart plus mode. The welding control is able to automatically recognize the type and thickness of the sheets to be welded, from sensors in the gun. This eliminates operator error as the software automatically sets specific welding parameters to ensure the best quality welds, without having to rely on a specific skill set. By means of a flash drive, it's also possible to upload OEM specific welding programs.
    If a fault is detected, the machine will compensate for this fault, or if it's not possible to perform a welding procedure, information is displayed explaing the fault.
  15. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  16. jjeffries
    jjeffries Formula Junior
    Sep 4, 2012
    250
    Connecticut
    John Jeffries
    That is the dog's 'gnads. Soft start technology friendlier on the local grid, right? And so quiet. Very nice. John
  17. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Yes the compressor was honestly a life quality upgrade, I was so tired of the old piston compressor banging away in the corner. We ran out of air with the growing bodyshop and the Kaeser really is a silent work horse.
  18. BRADAN
    22,661
    West Babylon, NY
    BRADAN
