This turbo S came in with some damage from over the winter. Bumped in the back bumped and tailgate and a suspension vibration. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
The shock is bent causing the axle to rub against the lower fork. Image Unavailable, Please Login Image Unavailable, Please Login
Rear tailgate disassembled for paint. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Mirror trim installed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Mirror cover replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Trunk and rear bumper prepped for paint. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Body work. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Shock and axle damaged from hitting a pot hole. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Glasurit 285-20 primer sprayed with Sata 100 BF HVLP gun. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Mixing paint using Glasurit solvent 55 line . Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Setup for paint Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Base color sprayed using Sata 5000 digital HVLP gun with a 1.3 tip. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Glasurit clear sprayed with a Sata 5500 RP with a 1.3 tip. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
