Sanded and primed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Interior trim sent for refinishing. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Bumper sprayed with Spies Poly primer to help even out the surface using a Sata 100 B P with a 2.0 tip. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Leather before reupholstery. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Bumper sanded with guide coat. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
I like following your progress, thanks for sharing. Question: is the whole car going to be painted or can you paint the bumpers and door and still match the rest of the car?
Sprayed with Glasurit primer using a Sata 100 spray gun. Left outside to cure for 2 days. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Prepped for paint. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Mixing Glasurit 55 line solvent paint in tour de france blue. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Bumper and door sprayed with Glasurit base coat. The door was spot sprayed with color to help blend the repair coloring. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Clear coated using Glasurit 923-255 HS multi clear with a Sata 5000 RP gun with a 1.3 tip. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Black trim paint. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Custom expel full nose wrap. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Dash recovered in dark blue leather with blue thread. Image Unavailable, Please Login Image Unavailable, Please Login
Ball joints replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Fluids drained, engine oil smells like gasoline. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Shifter linkage leaking and silicone draining from the gearbox... Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
