Sway bar end links replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Lower strut bushing. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Failed motor mounts converted to 575 style. They have a plate that catches the motor if the mount fails. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Sway bar end link and strut bushing replaced. Image Unavailable, Please Login Image Unavailable, Please Login
Scanned and fault codes pulled. The car had a cat temp thats not possible just from idling a few min so we will be replacing the thermocouple ECU and probes. They have been tampered with already. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Fluids drained. Gearbox filter looks like its never been cleaned before. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Disassembly. Note how pushed out the plenum and valve cover gaskets are. Timing belts are aftermarket. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
removing cams and belts. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Forgot to order an o-ring? Might as well use a tube of silicone....its only a Ferrari after all. Image Unavailable, Please Login
Front cover removed, notice the wear on the chain tensioner pad. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Valve cover chemical strip. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Replacement lower strut bushing. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Someone ran a new wire going to the fuel pumps. This is from failing fuel pumps drawing to much power. Were going to replace the pumps, remove the wire, and repair the old wiring. Image Unavailable, Please Login
