Bradan 550 engine rebuild | Page 4 | FerrariChat
Discussion in 'Bradan' started by BRADAN, Mar 12, 2014.
  1. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    A failure like this can only come from 1) bad design, 2) bad alignment or load on the bearing, 3) bad installation or 4) parts problem.
    1) can be ruled out since this is a first for this failure, that leaves a choice of those other three.
    That shaft [42] is suspended by those two bearings, the front one is fixated axially, the rear is not - which makes sense as the aluminium of the engine will grow more than the shaft. But does the rear bearing run into a stop somewhere? And is there a way to check the shaft alignment?
    I would also be interested to know where the debris of the bearing went.
    The damage while bad now could have been worse. Hope for the owner that that head is recoverable.
    Nice pictures of the innards by the way, that crank looks the part.
  2. fatbillybob
    Aug 10, 2002
    28,890
    socal
    Don't understand post. This happened to your car too or this is your car?
  3. fatbillybob
    Aug 10, 2002
    28,890
    socal
    Is this damage due to the failure or is this wear characteristic of mileage like on 348's
    How many miles on this motor?
  4. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    It looks to me as if the chain guide damage is due to the failure. it would have created much more slack in the chain and the pull from the chain would force the gear upward, also toward that tensioner. but I am sure Bradan has seen more of these chain guides to definitely answer that.
    With such a low mileage, it could be that the bearing failed very early on in the cars life due to misalignment or another reason, and it simply went undetected till now.
  5. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    just commenting
  6. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    I believe so.
  7. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Yes. Nothing inside of the pump but we will rebuild regardless while its out.
  8. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    I originally thought a bolt backed off the lower timing drive or cam gears but this was not the case. The last major was not the reason this engine failed.
  9. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    He killed the motor basically right away which avoided burning up all the bearings and more damage.
  10. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Coupler is fine so is the pressure spring. I've seen them get stuck on other cars when something gets inside but this one was fine.
  11. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Honestly we will never know what exactly happened but a few people I respect agreed the bearing fell apart and a domino affect was a result.
    Parts just fail sometimes. You have to think in any manufactured part in the world from paper to Ferraris there is a certain percentage of failure or defect. It just happens.
  12. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    It's from the chain slapping around during the failure. I've seen other 550 chain guides and all show basically no wear. On the 348 I only really see the early style pads wear out.
  13. Barbapapa
    Barbapapa Rookie
    Jun 23, 2006
    9
    Atlanta
    Michael S.
    Is the item in the foreground pic in post #54 the coupler? It's not focused but looks cracked.
    I still feel that this was caused by resistance from the pump(s) and not a bearing simply falling apart on its own.
    If there was high resistance to drive the pump, the torque from the chain and sprocket would put very high side loads on that bearing which doesn't look like one that can handle high loads. it would pull the sprocket right up against the guide.
    Something would have to give, either the chain breaking or the coupler splitting or teeth shearing.
  14. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    OH, OUCH!
  15. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Great (if painful) thread. Thanks for sharing the details and responding to the questions posed.
    Philip
  16. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    I understand your theory and it makes sense. I just have to disagree based off what we see later in the thread. More updates to come.
  17. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Anytime! I'm enjoying posting again and looking over all the work we have done in the past year.
  18. DONRON
    DONRON Karting
    Dec 21, 2012
    74
    Westchester County
    Ron
    There's a Ferrari part that only costs 15 dollars ?
  19. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Yes keep in mind thats what we believed caused the failure. They F*ck you being to expensive and f*ck you being to cheap. Can't win either way.
  20. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    This was a fun thread I never got to finish out. Enjoy the remaining pics.
  21. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  22. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  23. BRADAN
    22,661
    West Babylon, NY
    BRADAN
  24. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #99 BRADAN, Dec 12, 2016
