Bradan 550 engine rebuild | Page 3 | FerrariChat
Discussion in 'Bradan' started by BRADAN, Mar 12, 2014.
  1. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    #51 BRADAN, Mar 14, 2014
  2. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #52 BRADAN, Mar 14, 2014
    This is what we believed happened. The small bearing on the front of the oil pump driveshaft fell apart. It caused the oil pump shaft to wobble and strip the teeth off which connect it to the pump. This starved the motor of oil causing the camshaft previously shown to seize in place. Once the camshaft seized it kicked the belt off locking up the driver side bank.
    Missing bearing with outer race still inside the hole.
  3. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #53 BRADAN, Mar 14, 2014
  4. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #54 BRADAN, Mar 14, 2014
  5. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #55 BRADAN, Mar 14, 2014
  6. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #56 BRADAN, Mar 14, 2014
  7. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #57 BRADAN, Mar 14, 2014
  8. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #58 BRADAN, Mar 14, 2014
  9. moorfan
    moorfan Formula Junior
    May 11, 2009
    809
    Central Virginia
    Pete
    Thank you for this thread. Great information. So I'm trying to decide what to take away from this for me, and I believe that we probably should be checking that oil pump shaft bearing behind the sprocket.
    Last major I did I did not remove the sprocket to remove the front timing cover, but this time I will :)
  10. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Thank you.
    Honestly it's a freak accident. I don't think you would even be able to tell if the bearing is about to fail or not before it does. It's a shame a $15 dollar bearing caused all of this.
  11. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #61 BRADAN, Mar 14, 2014
  12. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #62 BRADAN, Mar 14, 2014
  13. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #63 BRADAN, Mar 14, 2014
  14. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    #64 BRADAN, Mar 14, 2014
  15. moorfan
    May 11, 2009
    809
    Central Virginia
    Pete
    I know, right? Frustrating.
    I guess we could make the case for prophylactic replacement of this bearing but what about the other one at the back of the shaft where it connects to the oil pump??? Can't turn every major into a complete teardown.
  16. DWG
    DWG Karting
    Sep 26, 2013
    76
    Porter Ranch,CA
    Greg Groom
    #66 DWG, Mar 14, 2014
  17. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Yeah there is no way to prevent this. At the end of the day it's a machine made of a hundreds of individual parts. Things fail.
    Later in this thread you will find a few design changes interesting in the new parts we bought. Looks like either Ferrari picked up on a few possible issues.
  18. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    Wow. I absolutely did not see that coming based on the first post. As always, thanks for sharing.
  19. Barbapapa
    Barbapapa Rookie
    Jun 23, 2006
    9
    Atlanta
    Michael S.
    Do you mean the teeth were worn down and no longer mesh in order to drive the oil pump?
    I can't believe the bearing would just fall apart on it's own. Was there debris that lodged in the pump itself causing high drive effort?
  20. fatbillybob
    Aug 10, 2002
    26,417
    socal
    It will be interesting to see how you handle the bearing 170787 issue. I hope you can give us some guidance.
  21. George Vosburgh
    George Vosburgh F1 Rookie
    WOW! That is shockingly low mileage. When we tore open my '77 308 it didn't look too much different than this engine, but mine had 67,000 on it.
  22. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    with last major. bad job.
  23. Nurburgringer
    Nurburgringer F1 World Champ
    Jan 3, 2009
    11,032
    Texass
    Great pics of a sad machine...
    Thanks for sharing.
    How long do you think it ran without oil?
    Shouldn't an oil pressure light have come on right away?
    Must have sounded awful :(
  24. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    less than one min. at 6,000
  25. Barbapapa
    Barbapapa Rookie
    Jun 23, 2006
    9
    Atlanta
    Michael S.
    Another possible problem is a sticking relief valve. There's not a lot of effort required to drive an oil pump with normal pressure but if the relief valve sticks it could get sky high.
    Is the coupler split?
