360 - Bradan 360 repair | FerrariChat
360 Bradan 360 repair
Discussion in '360/430' started by BRADAN, Oct 22, 2019.
  1. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    tifosi101, billy.gif and E60 M5 like this.
  2. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    tifosi101, f355spider and E60 M5 like this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,563
    Central NJ
    Dominick
    When you put atf in did you run it , drive it , for how long ?
    Thanks in advance
    Sent from my moto g(7) using Tapatalk
  4. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Just on the lift for 5 min at a time free spinning to cycle it through the system.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,563
    Central NJ
    Dominick
    Thanks ..and then i assume you ran gearoil in twice /flush or more ?
  6. RedNeck
    RedNeck F1 Veteran
    BANNED Silver Subscribed
    Jul 8, 2016
    9,875
    The CSA
    Me
    I did this last year as a proactive measure....seeing all these failures, I’m glad I did
    billy.gif Formula Junior
    Mar 9, 2017
    259
    Finland
    I'm curious what were the symptoms that customer noticed, just the spilling of milky oil? Would the F1 system work with such a stuff inside the gearbox?
  8. imahorse
    imahorse F1 Rookie
    2,648
    WI
    Dustin
    When mine failed, trans fluid mixed with coolant making a really thick sludge in the coolant reservoir. As it heated it bubbled out of the overflow hose.
  9. wbt
    wbt Karting
    Nov 28, 2014
    231
    New Zealand
    Wayne
    Everybody with a 360 that hasn't done this change should do it immediately. My car had a great service history and when I pulled mine out it wasn't far from failure. The heat exchanger was absolutely full of crud on the oil side.
  10. BRADAN
    22,661
    West Babylon, NY
    BRADAN
    Spitting milky oil on the ground from the overflow tube. The car started to overheat also since it was pumping all the coolant into the gearbox.
  11. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,719
    Memphis, TN
    Since the replacement part has the same potential for failure, and since careful monitoring can alert the owner to leakage, it's better to just keep an eye on the heat exchanger and replace when it fails. The gunk you've found when you removed the heat exchanger isn't a sign of failure. It's a sign of gunk in the heat exchanger. If it's not leaking, then it's fine. If it is, then it has to be replaced. You might have gone another 10+ years before it failed, if ever.
    To check your heat exchanger, simply open the coolant overflow tank and check for oil film. No oil in the coolant tank equals a good heat exchanger.
    If your coolant and transmission oil are changed on schedule and the car is not abused, the heat exchanger could last forever.
    hondar and Apollo 11 like this.
  12. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    341
    Bay Area
    The issue is that the 360 doesn't have a schedule for coolant change. The reason it's not a failure point in the F355 (same heat exchanger design) is that a major service with engine out forces you to replace the coolant as you have to drain to take the engine out. So you're correct, if coolant is changed "regularly", the heat exchanger should last a long time.
    As for the "car is not abused" comment. I'm not sure what to do of it. I take mine to redline every time I drive it (once it's up to temp of course) and wouldn't call that abusing.
    flash32 likes this.
  13. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,336
    On the Limit
    Dino
    The dead giveaway is the smell of gear oil when you open the coolant expansion tank.
  14. vrsurgeon
    vrsurgeon F1 World Champ
    15,875
    Charleston, SC
    Curt
    The problem with the heat exchanger is fundamentally a problem with Ferrari owners.
    1. They don't actually drive their cars and they sit in the garage, whereby parts corrode internally as owners wistfully gaze at their cars: "I own a Ferrari".
    2. They then read about failures on the internet and proclaim that it "should be done in ALL cars"
    3. Whereby they replace the part and the car sits in the garage with the new part corroding away to fail in the same way the old did.
    4. And then when the new owner buys a car, they want the lowest mileage possible
    5. Rinse and repeat
    66k going 67k miles. 20 years old. Original Heat Exchanger. Functioning perfect. to be replaced if and when it fails.
    hondar, s1owcoach, tonino ct and 4 others like this.
  15. one4torque
    one4torque F1 Veteran
    5,090
    Houston
    One4torque
    Vr—- so true!
    tonino ct and vrsurgeon like this.
  16. tonino ct
    tonino ct Karting
    Mar 1, 2018
    127
    tonino tony
    Doing mine now. Do to a small leak on one of the boot. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    kes7u likes this.
