Getting a head start on this service and rebuilding the flywheel. The flywheel surface will be machined, repacked with grease, and O-rings replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Leaking shocks removed and sent for rebuilding. Image Unavailable, Please Login Image Unavailable, Please Login
Removing leaking power steering rack. Image Unavailable, Please Login Image Unavailable, Please Login
Coolant hoses and water pump removed. Image Unavailable, Please Login Image Unavailable, Please Login
Old tensioners and timing belts. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Camshafts removed to inspect lifters. We found 2 in need of replacement. Image Unavailable, Please Login
The left lower timing bearing is leaking. Both will be replaced which requires removing the front cover and oil pan. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Valve covers media blasted and primed. Image Unavailable, Please Login Image Unavailable, Please Login
Replacement lower timing bearings and front cover gasket. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
