Spal radiator fans are incorrect for the Dino. We will be swapping these out for Lucas fans that we were able to source from a Jag parts supplier. Image Unavailable, Please Login
The trumpets are made by FIAMM but as some point someone swapped in a UNUS air compressor. This will be removed from the system and replace with a FIAMM period correct compressor. Image Unavailable, Please Login
Trumpets disassembled. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Media blasted to remove all paint and dirt. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Tail light chrome removed to be refinished. The rubber seals are all dry rotted and will be replaced. Two of the red rear lights are cracked so we will try to find replacements. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
The HVAC case has a nasty tendency to break at the drainage nipple. If you are in need of a fiberglass reproduction that will last infinitely longer, I have a source for you. Please pm me for further information. Regards, Alberto
The whole case is already cracked in multiple locations. I was going to plastic weld on the inside so you would only see fine lines up close. Does your reproduction have the wrinkle look to it?
We decided to remove the front and rear clip to clean out all rust damage. It got to a point where we would keep finding more and more hidden in the corners of the frame and body. The frame also needs more tubing and sheet metal replaced. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Removing rear clip. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Peddle box disassembled. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Photos of the bare frame. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Front grill disassembled. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
