Boxer Brake System Upgrades | FerrariChat
Discussion in 'Boxers/TR/M' started by Frank R. Masiarz, Jun 23, 2004.
  1. Frank R. Masiarz
    Nov 10, 2003
    126
    Frank R. Masiarz
    Hi...........
    Anyone ever perform a Boxer brake system upgrade ?? What are the best sources for slotted rotors and calipers ?? Do any of these modifications require installation of new wheels for clearance ??
    What about aftermarket brake pads ?? Are there any noise- and dust-free high performance street pads for the Boxers ??
    Do all Boxers in the series require the same pads ?? Did the BB/LM cars have "trick" brake systems ??
    Is there any possible complication with the stock hydraulic system and would an upgrade require a brake bias adjustment via a proportioning valve ?
    These heavy vehicles could use better brakes.
    Frank............23005
    www.masiarz.net/bb_resource
  2. boxerman
    boxerman F1 World Champ
    18,780
    FL
    Sean
    On the caribou performance website they advertise Brembo rotors drilled and solid for boxers as well as various pad options. Maybee they would have some info.
  3. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,216
    MO
    Do not forget SS lines, they should help give much better pedal feel.
  4. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Big AP or Brembo calipers can be squeezed inside the Boxer wheel, but you need to be doing a lot of track work to justify the expense.
    Good fluid, good pads, steel braided lines, slotted discs (not drilled) and good condition shock absorbers will keep stopping distances acceptable for most occasions........
  5. boxerman
    18,780
    FL
    Sean
    Any ideas on wheels and tires?
  6. ferraripete
    ferraripete F1 World Champ
    proir to his passing, i was under the impression that george jonas had done a brake upgrade to his boxer. his company still exists "stainless steel brake corp" ask for michael jonas. he may remember what was done to upgrade.
    pcb
  7. ferrarifixer
    8,520
    Melbourne
    Phil Hughes
    What use do you have in mind?
    For road/track, you can scratch around and find some usefull 15" tyres and retain the std wheel, but if you want to go hard on the track, you'll need to get some 16" wheels built to give greater tyre choice.
    My almost std road/track 512BB has Pirelli P600 front and P7R rear on the std wheels, I can lap all day within cooee of 355's on std tyres at Silverstone or Thruxton or the long track at Brands Hatch. Slower tracks make it harder though.
