Bleeding brakes Question | FerrariChat
Discussion in '360/430' started by ncjetskier, Nov 20, 2013.
  1. ncjetskier
    ncjetskier Formula 3
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    I purchased the Motive brake bleeding system (on line). Watching the video on youtube, it states that you suck as much brake fluid out of the master cylinder resevoir as possible, fill the Motive tank with your brake fluid, connect to the master cylinder screw cap, then pump to pressurize the tank.
    My question is: Wouldn't the air in the master cylinder and the air in the line connected to the resevoir be pushed into the lines before the brake fluid?
    KVerow likes this.
  2. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    I have never had that issue with my Motive
  3. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Thanks Mike - did you prefill the line from the Motive before connecting it to the master Cylinder resevoir?
  4. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    Nope. Think about it. Assuming you live in a place with normal gravity, any fluid will be at the bottom of the reservoir and any air will be at the top. Assuming you don't drain the reservoir down to the point where it holds less fluid than the feed line from your bleeder bottle and assuming your bleeder container holds a good bit of fluid, the fluid will fall to the bottom of the reservoir as it flows out of the bleeder container, through the feed line, and into the top of the brake system reservoir. As you might expect, the air will be at the top and all the fluid will immediately fall toward the center of the earth, since the density of air is less than that of brake fluid.
    So, when you open the bleeder screw down at the caliper, fluid flows through the system and is replenished from your bleeder container and a big bubble of air remains in reservoir, but it is at the top, not down near the bottom where it's connected to the brake lines and ultimately to the calipers. So, only fluid enters the lines. Assuming you stop before you empty the pressure bleeder container, you're OK.
    Some people apparently just top off the reservoir and use the pressure bleeder as a source for pressure, not fluid. The idea is to keep the tool clean but that doesn't make a lot of sense to me. Anyway, in that case, you have to use caution to stop before you empty the car's fluid reservoir. Either way works fine.
    Of course, if and when gravity fails, all bets are off. ;)
  5. Jeffg11
    Jeffg11 Formula Junior
    May 31, 2004
    564
    Michigan
    Jeff Grabowski
    Word of warning to you with this system, be very careful with the cap to reservoir interface. I was unable to get a solid connection. Motive recommended wrapping the threads in teflon tape to get a tighter fit. In the end I was never able to get a solid connection. If I had filled the Motive tank with brake fluid it would have spilled fluid all over the car. Good luck! YMMV.
    I successfully used this system on an Elise, Spec Miata and Z28. Their European cap just didn't fit my 360.
    Jeff
  6. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Jeffg11, did you have the billet cap or plastic? Even those the euro plastic cap isn't the right size, it holds the pressure I need.
    I don't take any fluid out before bleeding... just fill up the motive, pressurize, and go.
  7. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Mozella - thanks makes perfect sense. I should have sat next to you during physics exams.
    I ordered the 45MM billet cap -will that fit the 360?
  8. tazandjan
    39,006
    #8 tazandjan, Nov 20, 2013
  9. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Don't really have to if you never let air in the system... It is a good thing to do, and I've had to do it a couple times, but a pain since it's behind the front trunk carpet and vapor thing.
    I hear the billet cap doesn't work, and the plastic cap has deeper threads so even though it's incorrect it works.
  10. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Just got off the phone with Motive (nice people to talk with). The person explained that SOME of the 2003 360 came with a 3/4 inch cap for the brake resevoir instead of the stock 1 3/4 inch caps. He stated that it was only 2003 models and there are no other car manufacturers that use a 3/4 inch brake res cap. Basically you will need to find ANY cap that will screw on and he stated that he would tell me where to get the other parts (locally) to help make it work.
  11. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    #11 FerrariDublin, Nov 20, 2013
    I'd highly recommend this product. Comes with sufficient reservoir capacity to do the whole system flush with a single fill and has the correct cap also.....
    Linky:- Sealey
  12. up4speed
    up4speed F1 Rookie
    3,637
    Long Island, NY
    Chris
    Some good advice here.
    One more piece of advice I would like to add. Make sure that you do a trial fit of everything before adding brake fluid to the bleeder canister.
    Screw the cap for the bleeder on the car and pressurize the system, then leave it for a while to make sure that it maintains the pressure. You don't want to find a leak AFTER the brake fluid is added!
  13. bisel
    bisel Formula 3
    1,138
    Scottsdale, Arizona
    Steve Bisel
    When using the Motive pressurized brake bleeder, I found that if suspend the resrevoir above the fluid reservoir, it seems to work better. And, do make sure to pressure test the set up before you fill with brake fluid.
    One more thing .... the instructions for the Motive state to pressurize to 10 psi. Although you may be tempted to think that if 10 psi is good, then 20 psi would be better to gain more rapid flow when you open the bleed screws, don't do that. Ask me how I know this.
    Steve
  14. Mardi Gras
    Mardi Gras Rookie
    Dec 25, 2009
    38
    I have a motive pressure bleeder that I use to flush the brake system. I have always used my vacuum bleeder (connected to a compressor) to drain the old fluid out of the master cylinder. One should then fill the master with fresh fluid before connecting the Motive to the M/C. As stated earlier, this method prevents the introduction of air, therefore a M/C bleed shouldn't be necessary. While you can get it, Ate super blue at one flush and amber at the next would give you a visual of complete change of fluid.
  15. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    UPS just delivered the the Motive. Checked last night and I have the 1 3/4 inch cap - so hopefully I will get a good fit.
    Steve-what happens at 20 PSI?
  16. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    1+3/4 Inch on your reservoir or on kit winging it's way to you?
    My car is 360 euro model but I suspect it's the same throughout the globe. The threads on the reservoir measure circa 43.2 mm (difficult to get the calipers on cleanly). The inner diameter of the cap that fits correctly is 42mm (approx 1.65 inches).
  17. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Just put the Motive on and pressurized the tank. I did put Teflon tape on the connection of the two pieces of tubing. Has held the air pressure well - appears to be a good fit.
  18. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Sounds like you have the wrong cap. It's "do-able" the way you describe but it's not really a great solution. Brake fluid under pressure with a make shift connection and fresh Ferrari paintwork have reasonable potential for calamity.
    What tends to happen is that there will be a slight air leak around your connection. As the air escapes (which is not a problem for your brake system) it's replaced with fluid and gradually over several minutes the reservoir air will be entirely replaced with fluid until such time as it's fluid, not air, that's escaping.
    Better to get the 42mm cap if you can.
