BG 44K fuel system cleaner | Page 2 | FerrariChat
Discussion in '348/355' started by SoCal1, Sep 1, 2014.
  1. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    I just got my can of BG 44K
    Bottom of can has a date stamp of 06/13.
    Is there a use by date for this stuff?
    Is my can too old to use?
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    SoCal LA/OC/New Mexico
    Tim Dee
    long as its sealed your ok
    Put it in and use it dont let it sit overnight opened lots will evaporate
  3. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,136
    So. CA & NV
    Peter
    Tim, anywhere to buy this locally or does it need to be ordered?
  4. plugzit
    plugzit F1 Veteran
    7,745
    Redondo Beach, CA
    Bruce Bogart
    How can a direct injected engine get carbon deposits on the intake valves?
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Because they are exposed to the combustion chamber?
  6. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,817
    Richmond
    Pete
    Pcv system. Sucks the crankcase vapors in and they then attach to the valve, and with no fuel wash they carbon up. I had to do a top end rebuild on my wife's mini s at 130k miles, the carbon was so bad it broke a valve. I have pics of it somewhere, the carbon build up was unbelievable. Toyota added a shower injector to their di engines to clean the valves, seems to work well.
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    Yes it's become a big problem. 3M designed a system thats sold under many brands its called 3M 39089 Fuel System Tune-Up Kit
    You wet soak the top of the valves
    [ame=http://www.youtube.com/watch?v=q6G0zb4QcIs]3M? Do-It-Yourself Fuel System Tune-Up Kit - YouTube[/ame]
  8. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    You can get it at amazom, years back its all we used at the dealerships and a commercial product. They dont list all the ingredients for a reason
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    This has been the leading cause of service bulletins besides check floor mat condition of every car that goes through the doors
  10. WATSON
    23,459
    WI
    SeaFoam is the same stuff correct?
  11. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    No, seafoam is a lot more gentle product
    BG or 3M cleaners have always been the gold standard in that order. The more PEA is better and they have some propriety stuff also that makes it deep clean longer.
    The GM X66P is said to be quite amazing also with the latest formula change
  12. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
    According to the MSDS BG 44K is a mixture of CAS 64742-47-8 which is a product called Kensol 48H, also known as Aluminum Rolling Oil or Ink Oil, and CAS 8052-41-3 which is Mineral Sprits. Nothing special. Just typical petroleum base solvents, but in pretty high concentration.
    Here is the link to the BG 44K msds. http://www.petrotech.co.il/PetroTech//userdata/SendFile.asp?DBID=1&LNGID=2&GID=470
    FYI, it is almost identical to Techron except Techron has a little naphtha and benzene added in. Techron MSDS https://cglapps.chevron.com/msdspds/MSDSDetailPage.aspx?docDataId=283264
    Techron is pretty much available everywhere.
  13. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Ty
  14. brendon0
    brendon0 Formula Junior
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    Guys check this out:
    [ame=http://www.youtube.com/watch?v=ByV8y1mPv7k&feature=player_detailpage]Terraclean Promo Video Edd China Wheeler Dealers - YouTube[/ame]
    (ignore the first 45 seconds, watch the entire video).
    This guy runs a "fuel system cleaning" deal and actually measures how its
    working by doing a hydro-carbon reading before and after.
    I wonder how this compares to the dump-it-in-the-tank products? That
    and where can I get this done locally?
    This seems to me it would clean the intake valves as well.
  15. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    Pretty much any good service shop have these. The BG site you can put your zip code and will give you shops. Looks like the same system from the 80's with a prettier machine
    I really don't recommend this unless its a last resort before a teardown. Its not a fix all
  16. BOKE
    BOKE Beaks' Gun Rabbi
    33,965
    600 East Fremont Street
    Lucky
    I have used this product for a number of years in my cars and bikes.
    BND ACES IV Gasoline Formula
    ACES IV Gasoline Formula Fuel Catalyst
    No more rebuilding British bike carbs for me. Really a great all around fuel additive.
    If I'm out, Techron is my second choice.
    Your mileage may vary.
