Beware of Gallardo Spyder LF06KTD in the UK | FerrariChat
Discussion in 'United Kingdom' started by F360_Spider, Jul 4, 2017.
  1. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    People who are based in the UK just wanted to make everyone aware in case they are thinking of buying a Gallardo Spyder beware of this one
    You might recall my Lambo that I have it was white then I wrapped it gold well that had endless issues with the engine and we ended up getting a report done and the following faults were found NONE OF WHICH were mentioned at selling point. In the end I managed to reject the car and it has now gone back.
    The number plate is LF06KTD
    Vin: ZHWGE22T16LA03753
    This car is messed up below is the report:
    AC Mechanical Repairs
    Lamborghini Gallardo 5.0 Spyder
    (LF06KTD) ZHWGE22T16LA03753 - 38?942.
    Diagnostic Report/Vehicle Condition Report.
    On initial inspection vehicle found to have excessive oil/blue smoke admitting from exhaust banks, more
    noticeable on the right side exhaust tail pipe trim/oil deposits.
    Further testing revealed average cylinder compression results of between 8 ? 9.5 bar (120 -145 psi), Visual
    inspection ?borescope? revealed right hand engine cylinder head damage marks (Possible valve to head
    damaged) and possible machining marks from cylinder head work, heavy oil deposits, scoring on cylinder
    bores ?pictures attached? Left hand engine cylinder revealed much the same with oil run marks within the
    combustion chamber, light scoring marks and heavy oil deposits within the combustion chamber and valve
    train assembly's on both banks.
    ?Possible damaged block/piston rings.
    ?Cylinder head damage/excessive oil deposits within combustion chamber.
    ?Engine block seems to be a different colour compared to the axillary's bolted to it.
    ?Cylinder heads stamped with engineering shop id?s, after head work/repairs.
    ?Steering rack not located corrected and nearside track rod end Gaitor split.
    ?Offside inner CV Gaitor split leaking grease.
    ?Coolant dripping from underbody metal coolant pipes.
    ?Silicone Located on top of coli pack engine covers.
    ?Poorly refitted Boot lid.
    ?Gear change poor/erratic
    ?General Engine bay condition/cleanness, pipes covered in oil, air intake pipes damaged/broken
    ?Engine bay trim broken/damaged ?see pictures?
    In my professional opinion would recommend full engine strip and further investigation into the ongoing issue,
    but can clearly see that the engine is worn, allowing the oil to pass by the piston rings and being burnt within
    the combustion chamber resulting in the heavy deposits in the combustion chamber and valve train.
    Please find attached pictures and compression results recorded.
    I feel for anyone that will be tricked into buying this car, please DO NOT do it, DM me I will tell you everything about the car as I have lost thousands of Pounds over this
    This is to simply make everyone aware of the car as I don't want anyone else to go through what I have.
  2. willcrook
    willcrook Formula 3
    Feb 3, 2009
    2,129
    this the car that was at Shaks Specialist Cars ?
  3. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,506
    Somewhere, anywhere
    Eddie B
    Not a very complete report though. Why no cylinder leakage test? And the engine blocks on those are always shiny in appearance compared to their surrounding castings...nonetheless, glad you got your money back, shocking that garages are getting away with selling cars with so many issues!
  4. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    I HAVEN'T got my money back, now received threats due to me giving bad review on auto trader, they have relisted the car on auto trader for £79,995 with the car still faulty.
    I dont understand how garage's get away with this seriously.
  5. derekmines
    derekmines Formula Junior
    Dec 12, 2013
    284
    Melksham, UK
    Derek
    Sadly things like this happen far too often...
    I was reading a post on Pistonheads this morning requesting information about a particular 360 Spider that a chap was looking at - the first reply was that it was a recorded write-off 9 years ago..
    Unsurprisingly this hadn't been mentioned in the sales blurb!
  6. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    I am not a member of pistonheads but this should be reposted on there to avoid someone being in my position
  7. 100badboy100
    100badboy100 Formula Junior
    Sep 15, 2016
    825
    Devon- U.K.
    Michael
    Hi
    I can't believe you haven't got your cash back- is it imminent or now a legal matter?
    Regards
    Michael
  8. F360_Spider
    F360_Spider Karting
    Mar 7, 2011
    180
    So after I left a autotrader review after they had already relisted the car and are in possession of it I received threats that "you have escalated this to a whole new level" and was told I wont be getting any money and going to go to the legal team now.
  9. daytona355
    daytona355 F1 World Champ
    12,655
    London
    Sid Korshak
    You gave them the car without getting repayment, and left a bad review? You should've waited a while in my opinion, but you are still entitled to a refund. Hopefully you have proof of everything you stated in a review for public ingestion? Go see a lawyer quick as you can, be sure to identify the original posted review and get it saved (in case anyone nefariously changes it) and get the documentation in order for the issues and faults. Diarise every event, and try to record (or at least time/date write down) any communications from them especially any even innocuous that could indicate threats to retain your monies or anything else.
    I've had similar situations, but I've always been able to get my money, I can't disclose my methods fully here, but it does depend upon the type of characters you are dealing with, and when I've had issues, it was a long time ago, as a younger man, buying £5000-£10000 cars, not £70-100,000 lambos at the time, and that means the dealerships with whom you were dealing tended to be more illegitimate and therefore more likely to take my 'customed' approach to repayment when a car was less than honestly advertised
