Best Way to Remove Wheel Center Cap? | FerrariChat
Discussion in '206/246' started by UroTrash, May 10, 2014.
  1. UroTrash
    Jan 20, 2004
    40,198
    Purgatory
    Clifford Gunboat
    I'm getting ready to put new tires on.
    I'm going to take the wheels (and old tires) to the tire place in pairs (I don't trust them putting my car on a lift).
    That is the best technique for removing the Dino center cap from the alloy wheel without scratching the wheel?
    Thanks!
  2. UroTrash
    Jan 20, 2004
    40,198
    Purgatory
    Clifford Gunboat
    I will answer my own question since no help here.
    I learned how to do it with zero chance of scratching your wheels.
    PM if interested.
  3. rynoshark
    rynoshark Formula 3
    1,031
    Pacific Northwest
    What's the secret!!?
    Also, what is the best technique for polishing the center caps? Or is that a bad idea and should just leave alone? The black center paint from mine has started chipping slightly in the corners and there are several spots where someone removing lug nuts in the past banged the metal with their tools marring the surface.
  4. tx246
    tx246 F1 Veteran
    6,634
    Texas
    Shawn
    We would love to know how to pull it off, I have always used a screw driver and gently pried it off.
  5. UroTrash
    Jan 20, 2004
    40,198
    Purgatory
    Clifford Gunboat
    I pried one off years ago by wrapping a screwdriver with a bunch of tape, tried to pry it like an old fashioned beer can opener, i.e., tip in slot lifted handle toward the center.
    This didn't work, so I twisted the screwdriver in the slot and, of course, gouged the alloy.
    The correct way:
    Wheel on floor.
    Kneel with your right knee on the right side of the tire to hold it down. (I'm a lefty, reverse if you were not born so lucky)
    Use long, wide screwdriver with tip stuck inside a loose folded cloth, put cloth covered tip in one of the slots on the left.
    Push the handle down sharply, toward the floor, USING ONLY THE RUBBER TIRE AS A FULCRUM.
    My experience, the first slot pops it up about 3 mm, second effort in the next slot pops it off.
    Screwdriver doesn't press on the wheel at all.
  6. rynoshark
    rynoshark Formula 3
    1,031
    Pacific Northwest
    How do folks solve rattling of the center caps when driving? Two of mine were quite noisy years ago and I put double sided sticky tape behind which completely dampened the rattling. Is this expected?
